Juno 66 / how to set arpeggiator tempo via midi
MUFF WIGGLER Forum Index -> Tubbutec
Author Juno 66 / how to set arpeggiator tempo via midi
dam
Hey there. Was wondering if there is a way to set the arpeggiator tempo via midi. How would one go about doing this? Thanks! This upgrade is AMAZING btw.
tubbutec
Hi,
if the arp is synced to midi clock you can set the clock divider / tempo via midi or via the config menu.
If you mean: Set the tempo of the internal arp clock via midi:
It depends. Do you have a Juno-60 or a Juno-6 ?
It is possible for the Juno-60, if you omit one of the Juno-66 CV outs (filter or pitch bend).
If you have a Juno-6, it is however so complicated I wouldn't bother to try it...
edit: Correction. The arp-clock speed can not be CV-controlled. The LFO speed however can in case of the Juno-60. If anyone wants to know how, ask here and I'll post an explanation...
dam
Ok. That is what I thought. I have the Juno 6. Will rely on midi sync. Thanks for the quick reply
alalal
Hi there
I think I get how to change the Arp timing via MIDI cc but can I turn on the arp via MIDI CC?
