mutant hot glue compression problem
MUFF WIGGLER Forum Index -> Hexinverter Electronique
Author mutant hot glue compression problem
bruital
hello
i just finish to built my mutant hot glue!
every thing is ok but compression is out:
i have calibrate it but the comp made a very bad distorsion with a gain of 0 to +20db and after nothing!!!
have you an idea?
thanks
bruital
so i have a problem with the comp : the sound distort a lot with a little gain, and shut down with a middle gain (like too much of gain)
i check the sound on the that 4301, the sound distort at the output of the VCA ( pin 13).
on the pin EC- (16) of the that 4301, i mesure 0v with 0 gain and -2.3v at max gain.
the sound stop at -0.59V.
are this values normal or it's to big???
magiseoane
I have the same problem....
seriously, i just don't get it seriously, i just don't get it seriously, i just don't get it seriously, i just don't get it seriously, i just don't get it
