In an attempt to give something back to this community Ive decided to release all of my Eurorack Flatpack Lasercut Case Designs (over 30 of them). I see the expensive modular case as a kind of barrier on entry into this great world of sound and I hope noobs as well as experts alike will get some benefit out of these free/open source designs.
Also its my subversive ploy to hasten and accelerate our impending post-capitalist future…
Ive put them up on www.thingiverse.com
Do a search for "Eurorack Lasercut Case” there to see the whole collection.
Included are .skp files that you can open and modify these designs in Sketchup (http://www.sketchup.com) its a free and easy 3D modelling program.
Also included are .dxf files that can be sent straight to a laser cutter for cutting. All these designs are for 7mm thick sheet material, plywood - MDF - Acrylic.
Lasercutting services are becoming quite commonplace nowadays. Lots of hackerspaces and FabLabs have them and online services like https://www.ponoko.com/ are quite decent in their pricing. Please report back to this thread if you find cheap/good services so others can be informed.
There are other documents in the downloads to give tips and advice regarding these cases, please read them.
All designs are free for your personal use, (credit where necessary is appreciated) however please be kind and don’t redistribute or resell them.
Most rails work with these designs but no responsibility is taken if, for any reason, there is an issue with alignment or spacing.
Ill list the designs here with links to the download page to make it easy for you to find what you want (the mm measurement in the title designates the internal depth of the case):
42HP 3U Skiff 70mm - http://www.thingiverse.com/thing:1205874
42HP 4U 123mm - http://www.thingiverse.com/thing:1205901
84HP 3U 93mm - http://www.thingiverse.com/thing:1205913
84HP 3U 123mm - http://www.thingiverse.com/thing:1205983
84HP 3U 63mm - http://www.thingiverse.com/thing:1206004
84HP 3U 10mm Acrylic - http://www.thingiverse.com/thing:1206029
84HP 4U 123mm - http://www.thingiverse.com/thing:1206047
84HP 4U 133mm 10mm Acrylic - http://www.thingiverse.com/thing:1206051
84HP 6U 80mm Skiff and Lid - http://www.thingiverse.com/thing:1206069
84HP 6U 93mm - http://www.thingiverse.com/thing:1206075
84HP 6U 123mm - http://www.thingiverse.com/thing:1206087
84HP 6U Skiff 63mm - http://www.thingiverse.com/thing:1206102
84HP 6U Studio - http://www.thingiverse.com/thing:1206118
84HP 7U 93mm - http://www.thingiverse.com/thing:1206125
84HP 7U 123mm 10mm Acrylic - http://www.thingiverse.com/thing:1206141
84HP 7U 123mm with Lid - http://www.thingiverse.com/thing:1206275
84HP 9U 123mm - http://www.thingiverse.com/thing:1206304
84HP 9U Studio - http://www.thingiverse.com/thing:1206307
84HP 11U 123mm - http://www.thingiverse.com/thing:1206311
104HP 3U Skiff 63mm - http://www.thingiverse.com/thing:1206319
104HP 8U 83mm - http://www.thingiverse.com/thing:1206325
104HP 12U Studio Case - http://www.thingiverse.com/thing:1206334
42HP Vectrex Synth Case - http://www.thingiverse.com/thing:1206348
84HP 7U Studio 10mm Acrylic - http://www.thingiverse.com/thing:1207296
84HP 21U Studio Tower - http://www.thingiverse.com/thing:1207319
104HP 13U Skiff 83mm - http://www.thingiverse.com/thing:1207335
168HP 6U Skiff 83mm - http://www.thingiverse.com/thing:1207342
Holes for rails accept M5 bolts. 10-12mm recommended.
For Ponoko. Try converting the .dxf to .eps with http://www.office-converter.com/DXF-to-EPS then in illustrator or GIMP change the cut lines to blue. Check size before cut. Ponoko have 6.4mm ply that can be used with these designs. If you are concerned about the 0.5mm overlap on the joins it should be easy to sand back with reasonably course sandpaper.
Polotu charges $118 to cut/supply the 6U with lid.(from d.lewis1190)
Post your tips/tricks and finding to this thread.
For modifying these files in Sketchup. Play around a while, lengths, sizes, hinges, handles, latches and locks are all possible with a little work... Work I dont want to do.
Enjoy
