Mutant Glue compressor speed mod?
MUFF WIGGLER Forum Index -> Hexinverter Electronique
Author Mutant Glue compressor speed mod?
trimix
Hey guys - just building a Mutant Hot Glue, modding for installation as MOTM.
There is a jumper connect that determines the compressor speed, setting hi,med,low. I KNOW I would want to change this setting frequently, and I think this is just begging for a switch on the panel....but I don't know enough about circuit bending to safely go ahead. Can anyone help? seriously, i just don't get it
I'm thinking a toggle, three position [on-on-on] would work, so...is that a DP3T ? Is it safe to simply run leads to the jumper locations?
Hazium
I would love to know the answer to this also. Great idea!
orlog24
Im pretty sure thats all you need to do. Definitely safe.
Basically you are just replacing the physical removal and placing of the jumper with a switch instead.
