Juno 6 part
Author Juno 6 part
delayed
Hi,
Would anyone know of a place to find a 100K slider for a JUNO 6? I understand that a JUNO 60 might also fit, but not the 106 nor the HS60 models.
It is for the VR12 position R, of the ADSR.
I also need a 3way switch that the bat has been broken off of. That would be a plus to get them at the same place.
Don T
delayed wrote:
Hi,
I may have both, but I'll have to dig through a couple boxes. I'll let you know if you don't find them elsewhere first.
delayed
Thanks a bunch, that would be super nice of you.
Don T
No luck yet, things have been moved around in the garage quite a bit, but I haven't given up yet!
arkaydez@gmail.com
Resurrecting a pretty old topic but facing the same issue...i picked up a juno-6 with a desoldered ads(R) fader and the 100kb 30 mm Slide potentiometer is still out of stock confused https://syntaur.com/Items.php?Item=1209
Can anyone point me towards a way to pick one up?
thanks
-Jason Dead Banana
dinkuspony
Hey @Delayed and @Don T, was wondering if either of you had any luck with this. I'm in the same situation myself
synthpriest
I could also use some replacement Juno 60 sliders if someone has them lying around. hyper
Sunshine Jones
Looks like Syntaur have all the Juno 6, 60 and 106 slide pots in stock right now.
https://syntaur.com/roland_juno.html
synthpriest
Thank you, I got the ones for my Juno 60. hyper
