Connecting Modular to Ableton: What gear should I be using?
Live patching, designs, and techniques that push the performance envelope.
raptorantics
Post by raptorantics » Wed Feb 03, 2016 11:47 am
Helloooo, I have a silly question for you guys
So i've just got my box filled with a few modules now, starting to resemble a synth. Eventually I will be saving up for a drum machine but for the meantime I want to save my money for modules so I'm thinking of playing drums/sequencing from ableton.
My question is what kind of gear would I need if my requirements are only drums/sequencing/sync from the laptop? I've seen different cv/midi interfaces, external interfaces like the Kenton USB Solo and sound cards though theres so many options I was just wonderng what would be best for me.
Appreciate any answers :goo:
https://soundcloud.com/daeko_music
With enough VCA's you have voltage control over the amount of voltage control you use to change the amount of voltage control.
337is
Post by 337is » Fri Feb 05, 2016 3:52 pm
This is a wonder-land full of many options for doing what you describe:
http://www.expert-sleepers.co.uk/
SCloud
Vimeo
YTube
MGrid
I've had great B/S/T transactions with: ryandfl, Soy Sos, metaBit, haven, swordsect, goiks, FSK1138, numan7, dubno, VanEck, rico loverde, C14ru5, spunkytoofers, paults, vonbonenstein, soundwave106, d.thomas, dropmotif, Cadence, & TheNavigator
simonlubie
Post by simonlubie » Fri Feb 05, 2016 4:26 pm
Am kind of wondering a similar thing. Can the FH1 be used to connect ableton to modular, or do you need the ES3?
spudboyblues
Post by spudboyblues » Mon Feb 08, 2016 3:07 pm
Expert sleepers is definitely the default here, but I've had great success using the Roland UM-One as USB -> MIDI and then routing into Yarns. Food for thought as an alternative to the default! Plus then you get a whole sequencer for when you *don't* want to be plugged into the computer...
artistcalled6
Post by artistcalled6 » Wed Feb 17, 2016 12:05 pm
Yarns has done me well throughout my journey. Currently I'm using yarns for midi -> trigger to pop drums from an OT, and then PGH Midi3 for the very little voice sequencing that we do. Seems to be a great combo.
spudboyblues
Post by spudboyblues » Fri Feb 19, 2016 12:26 am
Nice! What're your voices?
My dream rig is going to be this guy: https://www.modulargrid.net/e/racks/view/250167 with MIDI going into Yarns, which sends a gate to Tempi such that they can bock clock all of the things. That plus a Push to trigger MIDI sequences, and other samples / backing tracks / drum sequences. (Maybe a DS1 to control internal FX sends and levels!) Modular + Ableton into a mixer (6/8 track) and out from there.
artistcalled6
Post by artistcalled6 » Sun Feb 21, 2016 6:14 pm
spudboyblues wrote:Nice! What're your voices?
One is a make noise voice (dpo, sto, rxmx and other mn stuff), the other is a subcon voice (m15, m37, m52, m53).
tthogs
Post by tthogs » Sat Mar 19, 2016 4:54 pm
I sampled the sound of a gate and put it into simpler. Put it on a midi track and send it out and extra output on my interface. It's just loud enough that most modules will clock with it. Its a shaky workaround but it hasnt failed yet
bluemeanie
wiggle me wiggle me wee
Re: Connecting Modular to Ableton: What gear should I be usi
Post by bluemeanie » Sun Mar 20, 2016 9:08 pm
raptorantics wrote:so I'm thinking of playing drums/sequencing from ableton.
i run from abelton thru my computers midi interface and then midi on to my doepfer midi to cv module.
i can write sequence's on ableton that play the modular
and send midi sync clock to sync the modular's sequencers / clock div etc
nodules on my modules
www.soundcloud.com/s-k-p
Noizy Robot
Post by Noizy Robot » Fri Apr 15, 2016 11:17 am
simonlubie wrote:Am kind of wondering a similar thing. Can the FH1 be used to connect ableton to modular, or do you need the ES3?
It can via something like an iConnectMIDI interface, but this will only give you CV, gate, and other such CV based controls. If you want to send audio in and out as well you'll need the ES3.
Willowhaus
Post by Willowhaus » Mon Apr 18, 2016 9:14 am
Good topic. Been considering Expert Sleepers as well for other modular stuff I'm assembling. Right now I have a Mother32, so MIDI clocking works there - could always use that as the CV clock, I guess, but I think I'd rather not have to rely on it alone (although I haven't tested it that much yet...).
From the Ableton side, I either run MIDI out from my interface (Focusrite Pro 40) or from a simple USB interface, similar to the Roland, if I'm going lite & not taking the interface out. The Push works great as a controller - I also have an APC40, and prefer to use that so the Push can be more of an instrument.
I do like doing drums from the Push, although I'm also looking at adding some modules for percussive stuff.
kwaidan
Post by kwaidan » Mon Apr 18, 2016 9:36 am
If you just want to sequence drums, there are cheaper options than going with Expert Sleepers. I use an old Analog Solutions MIDI to 16 trigger output that I got used for seventy bucks. While they do not pop up often, there are a few MIDI to 8 trigger out modules that you can get new for under $200. I think Erica has one.
I also have a Yarns, and it is great for chords. However, unless they changed the software, it will only give you four trigger outs, two gate outs, and clock start/stop.
Hexinverter makes a MIDI kit with eight outputs that you may want to investigate. I don't remember how many trigger outs are available with it, but it does have four note and four gate outputs.
Another option is to get a Motu Audio interface. Some of them like the Ultralite or 828 have DC coupled outputs, so you can use them with Expert Sleepers without a module.
Also note that the latest version of Reaktor can send CV out and there are quite a few people starting to use it with Eurorack.
Alteredlandscapes
Post by Alteredlandscapes » Thu May 05, 2016 11:14 am
Get a yarns... You can sync to the bpm in ableton and it will allow you to have 4 gate and 4 cv outs. Each of the 4 sequencers allow you to adjust swing, sequence, and clk divide separately as well as other parameters. You can mult the signals and send them throughout your euro. It works great in the setup I have.
hellfeatures
Post by hellfeatures » Fri May 13, 2016 7:55 pm
+1 on yarns.. great flexibility in what information you can send to your modular. it also has a half decent oscillator on board and some very interesting arpeggiating options
spudboyblues
Post by spudboyblues » Mon May 16, 2016 3:11 pm
I'm on an ES-3 with the USB Streamer B by miniDSP and it's worked wonders for me. Much better and more configurable than Yarns, IMO, for pure DAW <> Modular, if that's all you're looking for. It's also a much stronger sync than MIDI, if you care about syncing other gear.
Hansi026
Post by Hansi026 » Fri Jan 19, 2018 8:35 am
the plugin throb from shaduzlabs is really tight .... but only for syncing
http://github.com/shaduzlabs/throb/blob ... /README.md
needlz
Post by needlz » Sun Feb 18, 2018 3:25 am
Get a Soundcraft Signature 12 Mixer and run all your analog effects through aux send/receive + 12 I/O channels to bring your module's voices into the box for recording or further processing.
eddock
Push 2 with modular, potential latency and other troubles
Post by eddock » Fri Feb 23, 2018 7:40 pm
Hi men! I'm new in modular synth and in muffwiggler. I'm (potentially :despair: ) in trouble with latency problems. Just a simple question. I'm planning what to buy to write sequences and playing directly with ableton push 2 on my (future) modular synth. In my mind the midi chain will be: push - > macbook - > M-Audio MidiSport 1x1 - > befaco midi thing. Then the audio in a focusrite scarlett 2i2 and then again in ableton live. I'm going to have latency if I play a note on the push? I've just got the push, the MacBook and the scarlett of all these things that I've named, but I want to save me from the cost of the expert sleepers ES-8. There are other expert sleepers modules that can help me? I need at least 4 cv's out (to control 4 voice modules with 1v/oct). Wich is the best way? Wich the cheaper?
weekdayworrier
Post by weekdayworrier » Sat Feb 24, 2018 2:21 am
I use an ES-3 with Ableton and CV Toolkit, which I mostly use for utility and sequencing duties. Very flexible, and saves some valuable real estate in my rack (not to mention some $$).
Return to “Play Out! Performance Modulars”
