New One Shot sample library from ignatius -
MUFF WIGGLER Forum Index -> Music Software Goto page 1, 2, 3, 4  Next [all]
Author New One Shot sample library from ignatius -
hey sample fiends.. i released another one shot library today.
1861 drum/percussion/FX samples to feed your soft/hardware samplers. Unlike my previous sample library "Circuit Malfunction" on Sample Phonics, I'm self releasing this one to keep the cost low and as an experiment to see if bandcamp works for this kind of project.
There's a link on the page for 64 free samples so you can get a bird's eye view of what's in the library.
Full details here
https://buriedintime.bandcamp.com/album/undo-sample-library
thumbs up thumbs up thumbs up thumbs up
All sounds are mono and 24/44 (24 bit, 44.1 kHz sample rate) except the octatrack sample chains which are stereo
the samples are named with the prefixes below.
BD (160) = Bass Drum
Bass (339) = bass/sub bass/harmonic bass
SNR (236) = Snare
MTL (345) = Metal/bells/crash/cymbal and metallic sounds
HAT (72) = Hi hat and hat like sounds
PRC (379) = Percussion - all kinds of percussive sounds
FX (330) = various percussive FX sounds
The below kits/chains/instruments are only a portion of the 1861 samples in the library.
10 Ableton drum racks
12 Battery Kits (battery 4)
14 EXS format kits
14 Keymap format (now defunct Redmatica)
14 Kontakt 5 kits
14 Reason format kits
14 Structure format kits
5 UVI Falcon kits
14 Reaktor Sample maps (randomly generated)
10 Octatrack sample chains. 64 sounds per chain
12 Geist Drum Kits
mt3
w00t
oisin
sounds great - thanks for sharing..
thanks for taking a look. it was a fun, labor intensive, project. I'm stoked how the sounds turned out. there's some pretty weird FM bass vactrol stuff in there and punchy in your face things all over the map.
i know it's all going to end up in my octatrack for another Ep or something.
scottmoon
I need to check them out when I'm back to my computer. Thanks thumbs up
nienhuis47
Demos sound great, thanks!
so far response has been pleasant. this bandcamp thing may work out for sample libraries. time will tell. thumbs up
Bonefish67
Thanks. Just purchased this today. Should be some fun times building some Ultraloop and Ableton kits with the drum samples.
-Mike
here's a freebie for wigglers. 10 download codes for free download of 'UnDo' sample library.
first come first served.
use the codes at this link:
https://buriedintime.bandcamp.com/yum
zhjm-v6f3
zqb7-6gv4
n8xx-yuza
wk4p-7vk7
ezpb-e9tv
b29w-3tf9
axt4-hnjz
8ezq-5e9g
tr26-bbgu
xnmk-5ymr
mckenic
Why Thank You sir!
Just redeemed the last code - xnmk-5ymr - (but forgot to enter my email addy!)
Can I send you a copy of my ancient 8bit sample lib as a thank you?
ezpb-e9tv
Done used it. Thanks, dude.
Matos
So rad! Thanks!
mckenic wrote:
Why Thank You sir!
sure smile
jbuonacc
used 'b29w-3tf9', looks like it worked?
thanks for this, much appreciated!
mt3
From trying out the demo pack these are very high quality.
CountZero
Used 8ezq-5e9g
Thank you, sir!
Illiac
Also used xnmk-5ymr, but it appears to be downloading. Huge thank you for this, homie!! Looks like a tremendous undertaking.
mt3
I also used xnmk-5ymr and worked.
a glitch in the matrix Guinness ftw!
Virgil
Thank you :-)
Anor
I just used tr26-bbgu, thanks ignatius!
catchpenny
just used 8ezq-5e9g thanks! I look forward to checking them out
hyena
8ezq-5e9g
I used this one me too. it worked. thanks for the freebie Ignatius!
Endling
I used the xnmk-5ymr code a few days ago. SlayerBadger!
mt3
Since we exceeded the 10 free codes, I ended up buying it for $10 (used to be $25!).
Blame my Canadian conscience. It's peanut butter jelly time!
Page 1 of 4
