[ORDER] ZeroScope, 6hp scope that's almost not even there
Luap
Post by Luap » Tue Apr 17, 2018 4:16 pm
av500 wrote:
Luap wrote:I see some mutterings over in the eurocrack forum about a v1.6 firmware update?
Does updating require a programmer of some description? If so then i'll probably make do without, but if theres no special tools or rocket science involved to update then i'd give it a go :guinness:
it depends on what firmware you have. new firmwares since 1.5 have a bootloader and allow SW updates via a WAV file. for older ones you would need an STLINK programmer. see the manual here about how to perform the update via WAV:
https://vpme.de/zeroscope/
Mine is an early'ish one I think, with v1.3 on it.
I'll look into the STLINK thing however.
While im here.. Is there a firmware change log to be found somewhere? I had a quick look around but didn't happen to find one.
Thanks :tu:
av500
Post by av500 » Tue Apr 17, 2018 4:17 pm
Luap wrote:^ Mine is an early'ish one I think, with v1.3 on it.
Thanks :tu:
there have not been many changes before 1.5, just minor bug fixes. and the new features are in the 1.5 manual
Luap
Post by Luap » Mon May 07, 2018 11:38 am
I couldn't help but notice.. 'Four Scope' ?
I happened to spot it in DivKids video, altho it is about 2 other modules..
av500
Post by av500 » Mon May 07, 2018 11:40 am
Luap wrote:I couldn't help but notice.. 'Four Scope' ?
it's a concept study, not a product yet ;)
Luap
Post by Luap » Mon May 07, 2018 11:49 am
! I think you are faster at replying to product threads than Mr Mutable! :tu:
Silver
Post by Silver » Mon May 07, 2018 12:00 pm
I thought I saw a 1u zeroscope somewhere too???
euromorcego
Post by euromorcego » Mon May 07, 2018 1:04 pm
Silver wrote:I thought I saw a 1u zeroscope somewhere too???
Intellijel showed a 1u scope based on the zeroscope ... he wants to turn it into a product (or so he said).
av500
Post by av500 » Tue May 08, 2018 1:08 am
Silver
Post by Silver » Tue May 08, 2018 7:14 am
:yay:
so does this mean no DIY version of it though? or any chance there will be a pulp logic 1u format?
av500
Post by av500 » Tue May 08, 2018 7:25 am
Silver wrote::yay:
I doubt IJ will make a pulp format 1U. as for DIY I cannot say at the moment. but it does not take readily available OLEDs on carrier PCBs anyway
euromorcego
Post by euromorcego » Tue May 08, 2018 8:00 am
Silver wrote::yay:
i'd also say an IJ DIY version is very very unlikely. But the IJ 1U modules can be easily adapted to pulplogic specs (all you need is a custom faceplate). Vice verse this is not possible.
So if the price of the IJ scope is good, it may be worthwhile to make a few custom panels.
av500
Post by av500 » Wed May 30, 2018 5:21 am
Updated the DIY BOM and build guide for the 2.2 version, this one moves the components from the back of the front panel to the main PCB. parts are more or less all the same. order away :)
gadgadasvara
question about BOM board rev1.4
Post by gadgadasvara » Sat Jun 02, 2018 2:06 am
hi guys,
i just got my kit from modular addict, i was about to assemble all the parts then i noticed there’s a different component between the BOM and the pre-installed one.
from the BOM version 1.3,
R12 : 330R
R14 : 10K
are pre-assembled. but when i looked at the board, it got installed different value, which are 2.2K at R12 and R14. am i missing some information regarding the board rev 1.4? (i couldn’t find any document about rev 1.4, only v1.3, and then v.2.2 in this forum). or is this a wrong pre-assembled resistor that i should change?
thank you.
gadgadasvara
Post by gadgadasvara » Sat Jun 02, 2018 12:19 pm
nevermind then, i just emailed vladimir, and got a quick response. my bad about the 2.2K, it is 220R.
thanks so much!
here's his reply
Hi there,
it's not 2.2k but 220R and it's ok, it will work just fine. for both resistors the exact value does not matter
Regards,
Vladimir
muffjuiggler
Post by muffjuiggler » Wed Jul 04, 2018 10:55 am
av500 wrote:Updated the DIY BOM and build guide for the 2.2 version, this one moves the components from the back of the front panel to the main PCB. parts are more or less all the same. order away :)
Hi
is the link on the firstpage to mousercart the updated bomlist??
i really do want to order the Zeroscope... but i have problems ordering the parts...
the Mouserparts on the firstsite link dont be manufactured anymore...
i would love to order all the parts needed on 1 site on the internet? (i have 4 parts from mouser 3-4 parts from tayda and so on)
is there a update possible on that link or can anybody give a hand to order the right parts?
Best Regards
PEACE and NO WAR is the right of everybody...
You greedy moneyhungry Mesantroph...
-Buy yourself a House near the Forrest
-Grow your owns
-Get yourself a Cow a Goat some Chickens and a Dog
-Buy yourself the sweetest Instruments for your Ears
Forget about money and that you need it...
thats the key to Happiness
av500
Post by av500 » Thu Jul 05, 2018 1:03 am
Mouser Cart updated:
https://www.mouser.com/ProjectManager/P ... essID=f758 dfd583
for the 10uF, solder 2x 4.7uF on top of each other or get 10uF/16V or 25V from some other place...
muffjuiggler
Post by muffjuiggler » Thu Jul 05, 2018 9:23 am
thank you very much for this info... really preciated
-Grow your owns
Heliophile
Schottky diodes
Post by Heliophile » Mon Oct 15, 2018 7:56 am
Hi Vladimir,
I ordered these Schottky diodes. They are different from the ones listed in your Mouser cart, but will they work too? https://nl.mouser.com/ProductDetail/78-SSA23L-M35AT
So far I'm enjoying the build. It's my first SMD project, but I think I'm doing okay :-).
Heliophile - synthpop
http://heliophile.bandcamp.com/
av500
Post by av500 » Mon Oct 15, 2018 8:28 am
should be fine :banana:
synthcube
you will be assimilated
Post by synthcube » Wed Oct 17, 2018 10:06 am
very happy to make the pcb/panel sets available as well as full kits! thanks to vpme.de for collaborating with us!!
https://synthcube.com/cart/vpme-de-zero ... ption=true
c0ntr4d1ct10n
Post by c0ntr4d1ct10n » Fri Oct 19, 2018 8:37 pm
Is there any possibility of buying just the pcb set without the panel?
av500
Post by av500 » Fri Oct 19, 2018 11:38 pm
c0ntr4d1ct10n wrote:Is there any possibility of buying just the pcb set without the panel?
you mean just the back PCB?
c0ntr4d1ct10n
Post by c0ntr4d1ct10n » Fri Oct 26, 2018 8:36 pm
Yeh, so I could just cut my own panels.
secrethero303
Post by secrethero303 » Sat Oct 27, 2018 10:32 pm
Any updates on the Intellijel 1U version?
av500
Post by av500 » Mon Oct 29, 2018 1:14 am
yes, but the OLED is soldered to the front PCB panel
