[ORDER] ZeroScope, 6hp scope that's almost not even there
Gunnar333
Post by Gunnar333 » Mon Nov 25, 2019 12:35 pm
av500 wrote:try increasing that C6 cap to 1uF, see a few posts above
Thanks for the reply. I will do.
Gunnar333
Post by Gunnar333 » Tue Nov 26, 2019 4:19 am
changing c6 to 1uF seems to fix it.
cbellevie
Post by cbellevie » Fri Nov 29, 2019 10:46 pm
For a beginner, anyone comment on how hard a build the Synthcube kit would be? (https://synthcube.com/cart/vpme-de-zerosccope). Couldn't find instructions for the kit so not sure what needs to be soldered. I've only built a mult otherwise.
I really want to pick one of these up, but think it would be far more fun to build my own instead of picking up complete.
av500
Post by av500 » Sat Nov 30, 2019 12:29 pm
cbellevie wrote:For a beginner, anyone comment on how hard a build the Synthcube kit would be? (https://synthcube.com/cart/vpme-de-zerosccope). Couldn't find instructions for the kit so not sure what needs to be soldered. I've only built a mult otherwise.
the build guide is linked in the first post on page one
cbellevie
Post by cbellevie » Sat Nov 30, 2019 12:36 pm
Thanks, I didn't know if the Synthcube kit was the same build or not.
av500
Post by av500 » Sat Nov 30, 2019 12:39 pm
cbellevie wrote:Thanks, I didn't know if the Synthcube kit was the same build or not.
they buy PCBs from me, so I dear hope it is :)
jrhillma
Post by jrhillma » Sun Dec 01, 2019 3:04 pm
This was my first SMD DIY kit. I do have a hot air reflow/normal iron solder station, so was a good chance to use the half of the unit that hadn't been employed before.
The kit went together quickly, with the only issue being a near indetectable (to me) solder bridge on the two right-hand legs of IC5. I only noticed it when I sent a picture to Vladimir and happened to zoom in. Once I cleaned that bridge up, everything worked as advertised.
My build was done with the SynthCube kit, but I've since purchased another set of boards direct from Vladimir, all the components from Mouser (screens from eBay) and have no (immediate) use for a second one. That was my backup plan if I'd completely mucked up the first. Maybe I should start another case. ;)
Huge thanks to Vladimir for helping me, via email, working through troubleshooting and for the quick ship on the second set of boards!
Mr.Username
Re: [ORDER] ZeroScope, 6hp scope that's almost not even there
Post by Mr.Username » Tue Feb 04, 2020 1:07 pm
Dear AV500
I put together my ZeroScope,
It is amazing.
My second channel isn't working, I thought maybe I flipped C2 and R2.
I messed up the board a bit trying to fix it.
Could I have a the board trace drawing so I can figure out how to fix this?
Thanks so much!
Dan
av500
Post by av500 » Tue Feb 04, 2020 2:05 pm
C2 and R2 can be swapped. schematics are in the build guide
Mr.Username
Post by Mr.Username » Tue Feb 04, 2020 2:27 pm
Thank you!
Philth
Post by Philth » Wed Feb 12, 2020 1:26 am
Got the Synthcube kit and it went together great. Great little utility and a fantastic form factor for the cost.
HellRaiser
Re:
Post by HellRaiser » Sat Apr 04, 2020 8:24 am
av500 wrote:
Tue Apr 17, 2018 4:17 pm
Luap wrote:^ Mine is an early'ish one I think, with v1.3 on it.
I'll look into the STLINK thing however.
While im here.. Is there a firmware change log to be found somewhere? I had a quick look around but didn't happen to find one.
Thanks :tu:
there have not been many changes before 1.5, just minor bug fixes. and the new features are in the 1.5 manual
Hi
I have just updated my zero scope with the WAV file but seem to have now lost the highlight box that goes around the note when you are tuning.
Sorry if I have missed this in the thread.
av500
Post by av500 » Sat Apr 04, 2020 9:25 am
the highlight box should still be there when the tuning is "exact"
HellRaiser
Post by HellRaiser » Sat Apr 04, 2020 11:33 am
Hi
Thanks for getting back. I have tried 2 different oscillators (Braids and Shapeshifter) the vertical line is there to the far left but doesn't move when I'm tuning. The note just changes as I got through the fine tune until it changes onto the next note. :hmm:
av500
Post by av500 » Sat Apr 04, 2020 1:05 pm
hmm, this is strange. I just uploaded latest v1.7 here: https://drive.google.com/drive/folders/ ... sp=sharing
and this one works OK for me in tuner mode.
HellRaiser
Post by HellRaiser » Sat Apr 04, 2020 2:05 pm
Hey! All good now! It was stuck again when I first updated it but then it jumped into life. Not sure what was happening.
Thanks again for your quick responses. :sb:
Username
Post by Username » Mon May 18, 2020 2:29 am
Hi
i have some trouble with my Zeroscopes; has anyone maybe faced similiar problems and knows where to look first for troubleshoot??
I build two zeroscopes; a white and a blue screened. While the white one is working fine (pic 1), the blue one stopped working properly after some months of usage.
In the attached images both zeroscopes receiving the same signal, with the same settings for the display (pic 3&4).
The blue one is putting the signal out correctly while nothing is displayed (pic 3&4).
When i tweak the display settings for the blue one, one can see a signal with a strong offset of the Y-Axis and the triangle signal is flattened out (pic 2; positive values missing?)
Where should i look first? What parts could be replaced for troubleshooting this?
One thing's for sure, the blue screened was the first built and the SMD soldering is much poorer quality as on the white one ;)
Thanks in advance!
Username
av500
Post by av500 » Mon May 18, 2020 4:07 am
check the negative -2.5V around IC5 / R13
Username
Post by Username » Mon May 18, 2020 6:01 am
measured against ground R13 shows -12V on the one side and on the side facing IC5 its 2,5mV.
Interestingly, when pressing down R13 a bit with the tip of the probe while measuring it jumps to -2,5V... so i guess i have to resolder this guy?
av500
Post by av500 » Mon May 18, 2020 6:05 am
yup
Username
Post by Username » Mon May 18, 2020 6:25 am
resoldered the conn. points of R13, measuring -2,5V.
signal is displayed normal again!
This was an easy one with your help! Thank you so much :-) !
KittenVillage
Post by KittenVillage » Tue Jun 30, 2020 6:28 pm
I seem to be getting some noise on mine... on channel one I think? Is there some calibration I'm missing?
Eurorack is an exercise in delayed desire.
av500
Post by av500 » Thu Jul 02, 2020 5:21 am
there is no calibration for noise, but try to thoroughly clean the PCB around the CPU and the opamp
