[Stocked] Noise! pcb / kit
FetidEye
demonic space drone
Post by FetidEye » Wed Mar 16, 2016 4:33 pm
Hi!
I've made a noise source, called "ReverseLandfill Noise!"
It's my first design. It uses CMOS ic's, Lunetta style.
The Synth has 4 squarewave oscillators that modulate each other,
go through a clock divider and are mixed together to create harsh noise and random control voltage. It also has a pseudo ringmod and a extensive patchbay to route the 12 clockdivider outputs to OUT2 (ringmod) or OUT3 (direct out)
The sounds fluctuate and change over time.
Noise! has got 4 knobs for frequency, 4 CV inputs, 3 outputs (audio rate noise, cmos ringmod and cv random) and several modding possibilities.
With the CV4 input you can gate the noise, so it becomes a percussive voice that can sync with drums.
All pots act as attenuators for the CV input.
sound clips playlist:
[soundcloud url="https://api.soundcloud.com/playlists/189248166" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
It has an Eurorack power footprint and a battery connection if you want to make a standalone version.
And I've made a wooden panel too :)
more info, build guide, sounds, etc:
http://reverselandfill.org/modular.html
The new PCB's are in!
Options:
PCB: 8,- euro
panel: 10,- euro
Eurorack full kit: 40,- euro
9v full kit: 40,- euro
build module: 80,- euro
+ shipping.
PM me if you want one!
Amer1231
Post by Amer1231 » Wed Mar 16, 2016 6:21 pm
interested but i've thrown so much cash this month i need to stap!
I have the cake.
geecen
Post by geecen » Wed Mar 16, 2016 6:34 pm
Sounds cool!
acgenerator
Post by acgenerator » Wed Mar 16, 2016 8:11 pm
I saw these on errorinstruments which has additional demos for other interested parties.
Also FetidEye the official website is having trouble loading States-side.... "ERR_CONNECTION_TIMED_OUT"
FetidEye
demonic space drone
Post by FetidEye » Thu Mar 17, 2016 2:35 am
acgenerator wrote:I saw these on errorinstruments which has additional demos for other interested parties.
I'm on it, mailed my host
errorinstruments has made some video's:
das_Produkt
Post by das_Produkt » Thu Mar 17, 2016 4:46 am
You are in the Netherlands, I presume?
Could you estimate the shipping rates to Germany?
lasesentaysiete
Post by lasesentaysiete » Thu Mar 17, 2016 5:05 am
ordered the pcb+panel a few weeks ago from Martijn, and completed the build a few days ago. Very straightforward and inexpensive build. Nice quality on the pcb and panel, too. I chose the green one (not sure if there are any pics of it?)
And the sound... well, very too noise! :sb:
Abigfatcat
Post by Abigfatcat » Thu Mar 17, 2016 5:17 am
Awesome board! The timing patch bay is brilliant. :nana:
Quick demo right after I built it. Sorry about the vert video.
Grumskiz
Post by Grumskiz » Thu Mar 17, 2016 5:57 am
One PCB for me!
FetidEye
demonic space drone
Post by FetidEye » Thu Mar 17, 2016 6:51 am
Grumskiz wrote:One PCB for me!
Please PM me for orders :party:
pic of the green acryl panel (I got 3 of these left)
FetidEye
demonic space drone
Post by FetidEye » Thu Mar 17, 2016 6:52 am
das_Produkt wrote:You are in the Netherlands, I presume?
3,- euro for the pcb only, with the panel it is 4,- euro
masterofstuff124
Post by masterofstuff124 » Thu Mar 17, 2016 11:50 pm
Bought the pcb! reading through the build docs I have some questions. both y1 and y2 have three solder points. Even though in the docs you specify connecting two patch points to either y1 or y2 im curious about connecting more. Do they just correlate to the two outputs? what about running them all out to patch points(3.5mm) and all the Y's to patchpoints. maybe they would have no use at other places within my modular? another interesting idea I had would be to connect all 12 of the division points to spdt switches. randomly flipping ones from center to make interesting combinations to either y1 or y2. would be cool to have a module with so many switches lol.
FetidEye
demonic space drone
Post by FetidEye » Fri Mar 18, 2016 3:36 am
hi
the patch points are a fun extra part of this synth.
If you patch them together, the sound will fluctuate and become unpredictable. the large divisions make ritmic sounds.
the Y inputs have 3 pads, because you can connect more than one divider output to them.
You can indeed make a expander where you can patch all outputs (or several) to these Y input points.
The divider outputs cannot be directly patched to other modules in your system, you have to add some parts (resistor + capacitor) to make it safe. Internal patching is ok.
A friend of mine used a lot of toggle switches, so that works too :)
I've made a performance version with momentary switches, that is fun !
oberkorn
Post by oberkorn » Fri Mar 25, 2016 3:02 pm
received my PCB today :)
j_p_higgins
Post by j_p_higgins » Fri Apr 08, 2016 5:59 pm
got mine today, brilliant module. :yay:
masterofstuff124
Post by masterofstuff124 » Fri Apr 08, 2016 6:13 pm
i really like mine. great for generating some really strange CV source or noise. adds some other worldly modulation to my setup. still not really sure how to use the cv ins. maybe i should try clocking them and see if i can get more rhythmic things going.
djamsia
Post by djamsia » Sat Apr 09, 2016 4:22 am
Hello...
shortly, I will start the construction of "Reverse Landfill Noise!
but I have a question:
it's a good idea put a selector between internal patch holes?
and make these are selectable?
thanks!!!
masterofstuff124
Post by masterofstuff124 » Sat Apr 09, 2016 8:54 am
I put every division on the center pole of a two way(onoffon) switch. That way I can mix and match which ones go to which outputs. I can also have all the switches In center position and the module makes nothing. Which IMO makes it a very fun and interactive module. It's not essential though. I really just wanted a module with that many switches! So far I've only used it as a mod source but my large switching array makes it very fun to use. This module is very versatile and I don't think I've even scratched the surface. I do know I want more CMOS lunetta stuff though. It's great!
FetidEye
demonic space drone
Post by FetidEye » Sun Apr 10, 2016 6:38 am
djamsia wrote:Hello...
thanks!!!
yes, that sounds like a good plan ;)
av500
Post by av500 » Mon Apr 11, 2016 2:33 pm
ordered PCB and panel today, let's make noise great again!
ehafh
Post by ehafh » Mon Apr 11, 2016 3:58 pm
sent a PM, looks like a fun build
Goosecheese
Post by Goosecheese » Tue Apr 12, 2016 9:40 am
Rockin! How much for Australia?
falafelbiels
still learning to wiggle
Post by falafelbiels » Tue Apr 12, 2016 10:58 am
I scorched a panel for it today.
This is a V1 but I used the experimental area to set up CV inputs à la V2.
The divisions are on 3 position switches.
I like it a lot!
FetidEye
demonic space drone
Post by FetidEye » Tue Apr 12, 2016 5:25 pm
HEY! cool design :)
tof man
FetidEye
demonic space drone
Post by FetidEye » Tue Apr 12, 2016 5:27 pm
Goosecheese wrote:Rockin! How much for Australia?
that depends on what you want, kit or pcb etc.
pm me for details
