DIY 4ms SMR
dalhasumai
DIY 4ms SMR
Post by dalhasumai » Fri Mar 18, 2016 5:49 am
A guy started a facebook group for PCB group buys and he's sellling 4ms SMR PCBs.
I started sourcing all the parts for a mouser/thonk basket.
GitHub : https://github.com/4ms/SMR
BOM :
I'm not sure about every replacement parts :
- SLIDES (POT-LED) : i see two alternatives but in 50K :
Thonk (red LED...) https://www.thonk.co.uk/shop/music-thin ... -voltages/
Mouser (not sure about colours) http://www.mouser.fr/ProductDetail/Alph ... boZoxqo%3d
Anyone know about a 100k source ?
- the 5 pots (POTR0904N) seems to be thonk's trimmers https://www.thonk.co.uk/shop/ttpots/
- VR4 (VREG-DCDC) seems to be this one http://www.mouser.fr/ProductDetail/RECO ... w5CejVE%3d if anyone a cheaper alternative, let it be !
- D13,D19 http://www.mouser.fr/ProductDetail/Vish ... bn2Q%3d%3d same thing here
- S0, S1 : BUTTON-TACT : http://www.mouser.fr/ProductDetail/ALPS ... oBay0Ts%3d
this one seems ok (i checked the dimensions)
- V-SEL : http://www.mouser.fr/ProductDetail/TE-C ... GdYnar0%3d
- SWD http://www.mouser.fr/ProductDetail/TE-C ... mg10Mhc%3d
- POWER (SMD !) unshrouded : http://www.mouser.fr/ProductDetail/FCI/ ... vH7rLdI%3d
shrouded http://www.mouser.fr/ProductDetail/Mole ... 252bzYw%3d
- V1 http://www.mouser.fr/ProductDetail/Fair ... NT5Q0mM%3d
- LED-INCLIP : Dual T1 LED, Common Cathode. I'm stuck on this one, seems to come from Malekko's Eagle library. I can't see what it does on the module... Help !
- 27 jacks : Thonkiconn (thonk soon out of stock !) https://www.thonk.co.uk/shop/3-5mm-jacks/
alternative ? http://modularaddict.com/pj301m12-jacks
or see group buy on pusherman group
- Rotary encoder / button, 12mm. I'm also stuck here. same as braids ?
- MINIUSB : http://www.mouser.fr/ProductDetail/Hiro ... EVPIFWo%3d looks ok
- LOCK switches : looks same as Clouds but not permanent (locked) I have 0 knowledges about DPDT, SPDT style so i won't know if it fits.
- submini SPDTT switches : same here...
Your turn now ! :)Image
insula
Post by insula » Fri Mar 18, 2016 5:52 am
really big thanks for sharing all this information!!
:yay: :yay: :yay:
i was also thinking to buld one 4ms, and now looks more easy with all this deatils
:banana:
dalhasumai
Post by dalhasumai » Fri Mar 18, 2016 5:55 am
Let's do this !
ki0
Post by ki0 » Fri Mar 18, 2016 6:25 am
Could you pass me the facebook group, please?¿ i would like to order some pcbs... :bananaguitar:
Thank you very much for the info.
dalhasumai
Post by dalhasumai » Fri Mar 18, 2016 6:36 am
I was told not to share the group link
Please take a moment to check my replacement parts propositions and help me figure out the other ones !
Altitude909
Post by Altitude909 » Fri Mar 18, 2016 11:00 am
dont forget lightpipes
also: http://www.ebay.com/itm/251176235368
and for the toggle switches, watch the diameter of the legs, the official parts used have tiny leads and finding switches that fit proved a chore. I went with C&K T series but those were really expensive.
d.simon
Post by d.simon » Fri Mar 18, 2016 3:43 pm
this work?
http://www.elecrow.com/3mm-led-dual-col ... p-377.html
probably not...through hole.
The dual LED is a clipping led for the input. (if the input signal clips)
RE: lock switches. There was a MW thread on this just recently (LP4 switches). Also my "prototype SMR" thread someone asked about it.
Lock switches are momentary : .brd shows "WHITE-MOM"
MOM = momentary (not mother)
d.simon
Post by d.simon » Fri Mar 18, 2016 3:48 pm
the LP4 "e-switch" comes up a few times on MW. There are maybe 3 sources of those types of switches (well buying, eswitch, and ?)
d.simon
Post by d.simon » Fri Mar 18, 2016 4:00 pm
yes song huei "tall trimmers"
the real crux IIRC is the 100k illuminated sliders. 20mm travel ... right?
On my prototype version I use 100k rotary pots instead (and a separate LED)
sempervirent
Post by sempervirent » Fri Mar 18, 2016 5:35 pm
I'll have SMR panels in a few weeks, preorders are open until April 1:
http://grayscale.info/panels/4ms-smr/
Also, one small contribution to the parts list... Thonk has the Davies 1900h-style knobs without a pointer line, like the Rotate knob on the factory builds:
https://www.thonk.co.uk/shop/knobs-davi ... one-metal/
Altitude909
Post by Altitude909 » Fri Mar 18, 2016 5:41 pm
d.simon wrote:yes song huei "tall trimmers"
Dont have to be 100K, I used 50K and those worked fine
dalhasumai
Post by dalhasumai » Fri Mar 18, 2016 6:09 pm
Altitude909 wrote: Dont have to be 100K, I used 50K and those worked fine
Really ? cause mouser is selling the 50k version
Altitude909
Post by Altitude909 » Fri Mar 18, 2016 6:17 pm
Yes. They are not being used as analog anything, just as digital controls. Anything 100k-10k should be ok
d.simon
Post by d.simon » Sat Mar 19, 2016 12:56 am
sweet.
did u know you can use two SMR to do vocoding?
dalhasumai
Post by dalhasumai » Sat Mar 19, 2016 2:42 pm
Altitude909
Post by Altitude909 » Sat Mar 19, 2016 3:00 pm
I didnt even use that brand. I used the Eswitch ones:
http://www.digikey.com/product-search/e ... P4OA1PBCTG
sempervirent
Post by sempervirent » Sat Mar 19, 2016 9:17 pm
E-Switch LP4, Well Buying PS004, and Highly PB61303 are all the same switch as far as I can tell. Which one is the original and which two are the clones? Who knows...
dalhasumai
Post by dalhasumai » Wed Mar 23, 2016 2:48 pm
Lightpipes : http://www.mouser.fr/ProductDetail/Dial ... Waun5uo%3d
not sure about the dimensions
Altitude909
Post by Altitude909 » Wed Mar 23, 2016 3:10 pm
cane creek
Post by cane creek » Wed Mar 23, 2016 3:44 pm
This might give you an idea of whats involved.
Conjure
Post by Conjure » Wed Mar 23, 2016 4:00 pm
Good luck. I've hand-built every Mutable project and I still don't want to touch the SMR. Not scared of the ARM or anything. Just the sheer size of the project. The tiny ICs are a little daunting.
Also, I've heard the LEDs aren't long enough on the DIY versions.
cane creek
Post by cane creek » Wed Mar 23, 2016 4:22 pm
So how do you order ? do you send the guy a message ? as the Facebook page looks a bit chaotic.
dalhasumai
Post by dalhasumai » Wed Mar 23, 2016 4:27 pm
The guy posts google docs when he's annoucing a new group buy and you fill it with what you need. but try sending him a message, he often have some spare boards.
d.simon
Post by d.simon » Wed Mar 23, 2016 4:31 pm
so the lightpipes are friction fit? no glue i assume.
cane creek wrote:This might give you an idea of whats involved.
its a helpful image but doesn't show lightpipes, as stated
d.simon
Post by d.simon » Wed Mar 23, 2016 4:35 pm
Conjure wrote:Good luck. I've hand-built every Mutable project and I still don't want to touch the SMR. Not scared of the ARM or anything. Just the sheer size of the project. The tiny ICs are a little daunting.
yeah...its amazing how much logic the led ring takes. digital design though.
just due to the amount of I/O there's a few opamps here and there.
the codec and the arm.
several power regulation sections.
that's about it besides passives.
