[Project] Turing Machine Mk2
Tombola
Post by Tombola » Wed Apr 06, 2016 3:41 am
The new Turing Machine is finally finished. It is a random looping sequencer, with many improvements on the previous version:
  • * Rotary loop length switch
    * Pulse out
    * Two boards, includes Backpack circuit to drive expanders (compatible with old Music Thing expanders)
    * Easier to build: a larger PCB in the same width, clock and noise circuits are more robust
    * Noise level trimmer & reduced voltage in noise circuit to make circuit more robust with different noise transistors
    * Compatible with existing Music Thing expanders
Kits will soon be available from Thonk
Design files are in Github (BOM etc on the way when I get to it)
And here's DivKid explaining the whole thing BRILLIANTLY:
DomMorley
Post by DomMorley » Wed Apr 06, 2016 4:12 am
:banana:
How I fill my days: www.dommorley.com
"Your head will collapse, but there's nothing in it..."
qfactor
Post by qfactor » Wed Apr 06, 2016 5:57 am
:w00t: :w00t: :w00t: :w00t:
mbroers
Post by mbroers » Wed Apr 06, 2016 8:30 am
looks awesome, new panel design is cool as hell! :nana:
Bamboombaps
Post by Bamboombaps » Wed Apr 06, 2016 11:16 am
Awesome been looking out for this.. Mabye ill get this one to lock :hmm:
roger
Post by roger » Wed Apr 06, 2016 12:56 pm
so i have all the parts for the ver1 lying around except for the pcbs. missed the last opportunity to buy them from thonk and now with the ver2 around, i'm wondering how much difference is there in terms of parts? i don't expect them to be identical :hmm:
Tombola
Post by Tombola » Wed Apr 06, 2016 3:22 pm
roger wrote:so i have all the parts for the ver1 lying around except for the pcbs. missed the last opportunity to buy them from thonk and now with the ver2 around, i'm wondering how much difference is there in terms of parts? i don't expect them to be identical :hmm:
Not identical, but limited changes - I'd guess maybe 10% different.
Tombola
Bamboombaps wrote:Awesome been looking out for this.. Mabye ill get this one to lock :hmm:
The little trimmer (behind the hole between write & scale) is designed to make that easier.
masterofstuff124
Post by masterofstuff124 » Wed Apr 06, 2016 4:17 pm
huzzah i love front mounted recessed trimmers that are still accesible through the panel!
The_Crooked_Man
mad man with a box
Post by The_Crooked_Man » Thu Apr 07, 2016 10:18 am
Any chance there will be black panels to match the old expanders?
Thonk Support
aka Monobass
Post by Thonk Support » Thu Apr 07, 2016 10:53 am
The_Crooked_Man wrote:Any chance there will be black panels to match the old expanders?
edit:
I'll do a final run of the acrylic panels but I won't be making new acrylic designs for the new modules. But I will be releasing all the manufacturing files for them and details on getting them made. So it would be quite simple for someone to make new designs to match.
Last edited by Thonk Support on Thu Apr 07, 2016 11:22 am, edited 2 times in total.
Thonk - CLICK HERE - Modular Synth DIY + Eurorack Accessories Store
AS of October 2020 this account which used to go by the name of Monobass is now manned by various staff at Thonk.
Waz
Wiggling with Scurvy
Post by Waz » Thu Apr 07, 2016 11:00 am
Any plans in the works to house this and all the expanders under one panel?
Thonk Support
aka Monobass
Post by Thonk Support » Thu Apr 07, 2016 11:14 am
Waz wrote:Any plans in the works to house this and all the expanders under one panel?
Considering it, but with 5 expanders and rising (including chaining multiple volts modules) it doesn't make quite as much sense anymore I don't think.
qfactor
Post by qfactor » Thu Apr 07, 2016 11:15 am
I won't be manufacturing the acrylic panels any more but I will be releasing all the manufacturing files for them and details on getting them made. So it would be quite simple for someone to make new designs to match.
So you won't be clearing your acrylic stocks anymore?
Thonk Support
aka Monobass
Post by Thonk Support » Thu Apr 07, 2016 11:17 am
Sorry I should be more specific, I am going to do another run first. But i'm not producing a design for the new module in the old styles.
davidh
Post by davidh » Fri Apr 08, 2016 3:21 am
this is just perfection, will get one with the pulse expander :banana:
pre55ure
Post by pre55ure » Fri Apr 08, 2016 4:15 am
Cool! :party:
Does this preclude the 9v regulator fix from the older version?
midirobot
turing
Post by midirobot » Fri Apr 08, 2016 7:22 am
so cool !!!
can t wait to try:)
Bamboombaps
Post by Bamboombaps » Sat Apr 09, 2016 4:59 pm
Brilliant stuff. Btw if I replaced a resistor with a trimmer in my original one could I trim the locking problem away? If so any idea which one? Or is it all different now?
ambrohski
Post by ambrohski » Sun Apr 10, 2016 12:09 am
So, I understand locking to the left with the length selector 16 makes the loop length 32. Does it then mean the other length values on the selector will be doubled when locked to the left? :hmm:
lcf
Post by lcf » Sun Apr 10, 2016 2:05 am
Magpie Modular makes it for the first version. I think that they will make it for this one too.
Tombola
Post by Tombola » Sun Apr 10, 2016 6:39 am
pre55ure wrote:Cool! :party:
It has a completely new voltage reference for the DAC, should have more stable voltage outputs. The expanders all use the old 9v system.
Tombola
Post by Tombola » Sun Apr 10, 2016 6:40 am
ambrohski wrote:So, I understand locking to the left with the length selector 16 makes the loop length 32. Does it then mean the other length values on the selector will be doubled when locked to the left? :hmm:
Yes, so you can do 4, 6, 8, 10 etc
Tombola
Post by Tombola » Sun Apr 10, 2016 6:41 am
You could try replacing R31 with a 1m trimmer
sromanel
Post by sromanel » Sun Apr 10, 2016 7:50 am
Little OT: I'm going to build a mk.I, what's this locking issue everyone's talking about here? :hmm:
