Author |
22 M ohm resistor for hihats |
br>ronski |
br>Hi all,
I'm having a hard time finding a 22m resistor here in the UK.
Any one UK based has some? Would a 5% resistor do maybe?
Any other options, doubling 2 lower value resistors?
Ronnie br> br> |
br>ronski |
br>donpachi |
br>That one is quite pricey. You could also use two 10M resistors in series. I remember that I had troubles sourcing 22M resistors and finally got some which are quite large. In retrospective, I should have gone with 10M+10M or 10M+10M+2M. br> br> |
br>ronski |
br>Cheers, good idea
I did in the end go for the 22M one, cause the 10 ohm resistors were all really expensive as well.
donpachi wrote: | That one is quite pricey. You could also use two 10M resistors in series. I remember that I had troubles sourcing 22M resistors and finally got some which are quite large. In retrospective, I should have gone with 10M+10M or 10M+10M+2M. | br> br> |
br>daryll |
br>gasboss775 |
