Malekko Varigate 8+
behndy
Post by behndy » Wed Nov 28, 2018 2:31 am
coooool! i gots some Tendies en ROUTE.
i mean, i adoreeee that it looks like they realized jacks up top might be best then ROLLED WITH IT.
still want to grab a VG8. 4 is SO damn fun.
music, noise, in progress silliness - http://www.youtube.com/c/behndy
zynapse
Post by zynapse » Thu Dec 06, 2018 3:55 pm
Which firmware version responds appropriately to an external clock? I have tried the two most recent official releases (11 and 12) and out of desperation I have treid the current beta, all without success. I am clocking with PNW and I have also tried Eloquencer. A variety of things happen - usually its a slow start, sometimes a skipped step, sometimes a double hit where a single step is programmed. I would be willing to have varigate as the clock source but it also starts slowly.
I have also thought about delaying PNW output to varigate but unfortunately varigate is not consistent with how it misbehaves.
I can say for sure its the best random module I have...
pinkflag16
Post by pinkflag16 » Thu Dec 06, 2018 5:09 pm
zynapse wrote:Which firmware version responds appropriately to an external clock? I have tried the two most recent official releases (11 and 12) and out of desperation I have treid the current beta, all without success. I am clocking with PNW and I have also tried Eloquencer. A variety of things happen - usually its a slow start, sometimes a skipped step, sometimes a double hit where a single step is programmed. I would be willing to have varigate as the clock source but it also starts slowly.
I’m on the latest beta and have not had issues so far. I’ve clocked it with Morphagene eosg out, 2hp RND normal clock out (not randomized), and ran a few short tests with a CR-78 and click track from Logic. All good so far.
pinkflag16
Post by pinkflag16 » Thu Dec 06, 2018 11:13 pm
Is it possible to create a mode that assigns one of the inputs to v/8 so a regular keyboard can be used to program cv in real time? The new live cv is nice, but hard to be accurate.
nedrush
Post by nedrush » Mon Dec 10, 2018 6:07 am
Is the new firmware still in beta? Should I upgrade or perhaps wait?
behndy
Post by behndy » Mon Dec 10, 2018 5:28 pm
a few people have written about success with using Pamela's New Workout to work resetting/sending clock to the Varigate 8, playing with the level and width settings. anybody mind sharing their settings that work?
i can get the clock to work well, the reset is always one beat off. i've tried gate and triggers, run through as many different width and level settings as i can think to..... reset is still wonky. and the reset mult'd to Voltage Block, Varigate 4+, Quad LFO and Envelope.... works fine.
i've tried each of the firmwares on the Malekko site, even the Beta. lol. when i got to 1.0.11 the reset lags one beat instead of two behind so.... progress?
any advice?
pinkflag16
Post by pinkflag16 » Tue Dec 11, 2018 3:25 pm
Update: My VG started jumping a bit in song mode occasionally. Not cool! It happened both with internal and external clocks, but only a few times over the coourse of maybe 20 minutes or so. Still...
zynapse
Post by zynapse » Tue Dec 11, 2018 4:06 pm
behndy wrote:a few people have written about success with using Pamela's New Workout to work resetting/sending clock to the Varigate 8, playing with the level and width settings. anybody mind sharing their settings that work?
any advice?
For reset, this works for me, as per PNW manual:
"There are also 4 special ‘utility’ types of modifier mainly for working with external devices; constant ‘on’ and ‘off’ gates, a single initial start pulse and a single final pulse fired when the stops (both indicated by pulse symbol)."
behndy
Post by behndy » Tue Dec 11, 2018 5:27 pm
gotcha. i'll look at that. which do you use?
the single initial start pulse seems like it would be the same issue, right now VG is always one clock pulse behind. like it resets a pulse after getting the reset, but a friend had suggested using the Stop Pulse to reset it before starting.
jwise
Post by jwise » Tue Dec 11, 2018 9:20 pm
Chris Meyer at Learning Modular recently made a video regarding PNW and sync issues surround clocks and resets with Grids and Euclidean Circles, but I was thinking this might address some of the issues with clocks and resets on the VG8+/VB.
Thoughts?
MarkF
Post by MarkF » Wed Dec 12, 2018 7:23 am
Sorry if this is a RTFM question, but is there a way to make it so pattern changes come at the end of a bar rather than immediately when pressing a button?
I bought a VG 8+ used and currently the behavior is that patterns change immediately when you press a new pattern which has caused me to make a few timing hiccups.
Eurtrude
Post by Eurtrude » Thu Dec 13, 2018 2:44 am
Hello there !
Is it possible to divide the clock of a track, then multiply it ? (or in the other way,multiply, then divide), so that weird clocks can be achieved ?
For exemple, multiply the clock by 3 and then divide by 2 to have 1.5X the clock.
I've read the manual and think it's possible but I just wanted to be sure :)
Thanks !
SB-SIX
Post by SB-SIX » Thu Dec 13, 2018 4:28 am
Eurtrude wrote:Hello there !
Thanks !
As far as I know you can either divide or multiply a track. But you could of course with external modules...
There is a chance you might like this: https://soundcloud.com/steeboo
aroom
Post by aroom » Thu Dec 13, 2018 5:25 am
Eurtrude wrote:Is it possible to divide the clock of a track, then multiply it ? (or in the other way,multiply, then divide), so that weird clocks can be achieved ?
yes you can. if you move the slider while pushing the track button, it will multiply. so you can do both.
p 10 from the manual
DIVIDE/MULTIPLY:
To DIVIDE a particular pattern/sequence, make sure the GATE output you want to divide is lit. Now select the TRACK button and move the DIVIDE/MULTI- PLY slider to the right. The position of the slider affects the amount of division down to 1/16.
To MULTIPLY a particular pattern/sequence, hold the TRACK button down while you move the slider to the right. You can multiply up to 16.
Aaronautical001
Post by Aaronautical001 » Thu Dec 13, 2018 7:09 am
But i dont think you can do this in series on a single channel within VG8.
smurf
Post by smurf » Thu Dec 13, 2018 11:15 am
giftculture wrote:it would be awesome if there was a button combo similar to holding bank/all, that would just delay every other step!
This would be great as mentioned before. But what happens if the channel has a a division or multiplication of the clock set (in the track section)? How would that work - I can't "visualize"...
Eurtrude
Post by Eurtrude » Thu Dec 13, 2018 1:21 pm
Thanks all for the answers :)
@aroom : yeah I read that part but was unsure both could be done at the same time. Thanks for confirming it
aroom
Post by aroom » Mon Dec 17, 2018 3:34 pm
new beta firmware - release candidate - available : https://malekkoheavyindustry.com/variga ... e-updates/
I wonder how the new solo function is different from the one already implemented.
jwise
Post by jwise » Mon Dec 17, 2018 5:28 pm
With the previous beta and the current, GATE 1's button remains illuminated regardless of my chosen channel.
If I revert to the last official release the Varigate 8+ button lights work exactly as expected and will turn off when I choose another Gate or CV.
Anyone else experiencing this?
Cyber-N Powers
Post by Cyber-N Powers » Tue Dec 18, 2018 4:10 pm
jwise wrote:With the previous beta and the current, GATE 1's button remains illuminated regardless of my chosen channel.
If it flashes when playing, then I think it is just indicating the chosen pattern.
I’m quite liking this beta. Internal clock is much tighter, and the Voltage Block always starts on the first beat when slaved!
The CV keyboard mode is fun when it works, but I seem to keep slipping into a play mode that doesn’t record anything...until I leave the mode, then it plays back what I played last. Weird!
Overall though, a vast improvement on the previous beta firmware (for me) and I’m sticking with this for now.
srcodling
Post by srcodling » Tue Dec 18, 2018 9:31 pm
Yes, I am...
srcodling
Post by srcodling » Wed Dec 19, 2018 1:27 am
Sorry - I'm an idiot - that light is the preset number I'm on within the bank...
jwise
Post by jwise » Wed Dec 19, 2018 7:49 am
srcodling wrote:Sorry - I'm an idiot - that light is the preset number I'm on within the bank...
Fair enough, but this preset number is not on in the last official firmware. How can I clear it so it is off under the beta firmware?
behndy
Post by behndy » Wed Dec 19, 2018 11:04 am
i think Scrodlingers Cat means when you're in a bank, whichever pattern you are currently looking at, that pattern number blinks? is that what you're talking about?
mebbe try loading another pattern, so you're in 2 or 3, see if that resolves it?
or does 1 stay solid lit? i haven't experienced that, and i'm on the most current Beta.
jwise
Post by jwise » Wed Dec 19, 2018 12:26 pm
The button that is lit is definitely from the selected pattern. If I hit "recall" and a button I can change the light that stays on but I can't "deselect all," but I with the last official firmware the selected pattern light did NOT stay illuminated.
I should take into consideration that when I got my VG8 button #1 was minorly dysfunctional and was repaired around the time I started playing with the new beta firmware.
Maybe this is normal behavior but I never knew it?
I went back and watched Daniel Dehaan's tutorials to see if this was standard behavior but it wasn't a feature when he made the video a year and a half ago.
