Dual Looping Delay for heavy electronics/death industrial
Discussing gear, production, and ideas for making noise music. Enough JMJ, let's rock like Merzbow!
pstanig
Post by pstanig » Tue Jul 05, 2016 2:23 am
A little exercise to start understanding the 4ms Dual Looping Delay and its use in a power electronics / death industrial setting. Sound sources are the Make Noise DPO and a metal object with contact mics. The DPO line has reverse and hold triggered via sampled-and-held Doepfer random. The metal parts are just looped with different loop lengths. Clearly work in progress, rough material.
https://soundcloud.com/naxalprotocol/dldexercise
nanshe
Post by nanshe » Tue Jul 05, 2016 4:21 am
It's really good! May I ask how you integrate the contact mic in your modular? Do you use a module like the A-119?
¤ fs / ft (eu only) : fonitronik mh01, doepfer a-119 ¤
¤ wtb (eu only) ¤
¤ current setup ¤ soundcloud ¤
pstanig
Post by pstanig » Tue Jul 05, 2016 4:32 am
Yeah, I have an A-119 and an A-138d (which is meant as an insert for pedals, but also works well enough, clearly, as an input for external signals).
I usually place two (and at times three) contact mics on the metal pieces (and the third contact mic is sent over to soundcard and Cubase, so I have a "clean" track with the metal sounds to process later if needed).
Multiple mics give metals a deeper, rustier flavor (the object I use is in the attachment).
sparood
Post by sparood » Wed Jul 06, 2016 2:42 pm
The cold percussion cutting through the synths sound great indeed.
pstanig
Re: Dual Looping Delay for heavy electronics/death industria
Post by pstanig » Sun Nov 27, 2016 1:46 pm
Another piece using the DLD to polyrhythmically loop some junk metals. [s]https://soundcloud.com/naxalprotocol/pathologyasclarity[/s]
pstanig
Post by pstanig » Thu Feb 23, 2017 3:33 am
Another exercise with DLD in a heavy electronics setting. One layer is a feedback loop (pedal noise) looped and then processed through the Korgasmatron. The metals are from a field recording in a basement of an old house in the Alps, then passed through the DLD and chopped further in Cubase. http://soundcloud.com/naxalprotocol/spinal-bill
Return to “Synth Noise”
