Mattson VCA questions
MUFF WIGGLER Forum Index -> Mattson Mini Modular
Author Mattson VCA questions
pugix
First to note, the VCA link the MMM Store is broken. It goes to Emergency Kits.
http://mmm.sevcom.com/wiki/index.php?title=Voltage_Controlled_Amplifie r
I found the original from the history:
http://mmm.sevcom.com/wiki/index.php?title=Voltage_Controlled_Amplifie r&oldid=674
Now to my questions. George, why did you choose to have an overall output level pot instead of an attenuator on the master CV input? Is it because the amplifier will go above unity gain when CV in is at +5V and the Manual Level pot is turned up?
I was wondering if when I make my panel I swap the pots and put a master CV input attenuator and not have the output level pot. See any problems with this?
BTW, I'm cooking up a 5U x 1U panel that will house one each of the Mattson Envelope Generator and VCA.
mmm
It's not broken. We get people Spamming the site and uploading their own crap. We delete and ban those users and I send an invoice to the linked companies for the advertising time. That really pisses them off but, who gives a sh--. Guinness ftw!
Thanks for catching that, Richard. All fixed.
No, that's the way my brain works. woah
I think that goes back to my old EML days where the VCA's "leaked" and I always wanted to turn them down when I wasn't actually playing something.
Old habits and all....
The master CV input and the Manual level are summed together going into the VC input buffer. The manual level just applies 0-5VDC to the VC buffer to open it up in case people want to just let it drone. I found some patches where having a snappy EG in the master CV input and a hair bit of droning bleedthrough turned out really cool. But, that's me.
They actually don't go above unity. I actually think it's down a bit. An anomoly I've rectified by turning the mix channel up on my main mixer. seriously, i just don't get it
Not at all. If that's the way you want to do it, go ahead. I just provide a means, You guys provide all of the creativity Rockin' Banana!
My I/O for the DIY boards are merely suggestive...for the most part.
Cool, a Two-fer. Post pix!!!
pugix
Thanks, George!
So the sum of the Manual Level pot and the Master CV input is somehow clamped at +5V, so that the gain can't exceed 1.0 (or a little less). And if the Manual Level pot is turned all the way up, then the Master CV input basically would have no effect? Would a negative input on the Master CV input in that situation reduce the gain?
mmm
pugix wrote:
Thanks, George!
No, they're not clamped at +5v. You could put 6 or 7V on it and get more gain. If the master CV input transitions above the max manual voltage applied internally, it will bump the output level.
I don't know about the negative input scene. Technically, If the manual offset is up all the way and you apply an inverted envelope to the master CV input, It should work backward. I've never tried it.
Besides the 100K impedance resistors acting as a summation network, they feed into pin 3 of U1 which is negatively biased slightly less than ground with a 100K to ground and a 4.7M resistor from there to -V.
After the input buffer, the signal is diode clamped/ half wave rectified to prevent negative values on the base of the transistor driving the current mirror and entire modulation network. (Q1)
The raw VCA output goes to the top of the Output level pot. The wiper feeds that signal to an output buffer which splits the output in two identical output feeds. Thus, the dual mono outs.
So, short out CN2B pin 1 and 2 to loop the output back to the output buffer directly and bypass the output level pot.
pugix
Thanks for the plentiful information, George. I've ordered two each of the EG and VCA boards. And I finished my FPD panel design. I always wait for the boards before I order the FPD, just to make sure. The FPD panels are about $65 USD each. cry But I'll fit all four modules in two 1U panels (1 EG and 1 VCA per panel - all the panel bits fit in 16 spaces on a grid). The EG out will be normal-lug connected to the VCA master CV input jack. For functionality, this beats the Oakley ADSR/VCA hands down with 8 pots, 2 switches, 6 jacks vs. 4 big knobs, 1 switch (range) and 4 jacks on the Oakley, and a completely separate VCA. I plan to add an LED to indicate the EG output level too. A tiny LED can fit in between stuff.
mmm
Wow, Thanks we're not worthy and COOL! thumbs up
Make sure you post pics.
I may be low on 12p headers so, I may need to make an order. Inventory is this evening. Right after I feed my birds smile
Thanks Richard, I'll respond officially whan I get to that side of the computer.
G
pugix
My birds are really scarfing down the black oil sunflower seed this spring! Lots of cardinals here, but lately a gang of grackles is lording it over the feeder. Hey, they all gotta eat!
Or did you mean your parakeets? confused
mmm
I have a pair of cockatiels that I've known since they were eggs.
They'll be 23 YO this July. Apparently, feeding them works. thumbs up
mmm
Oh, yeah,
I was low on connectors, so:
Richards: yes, all of the Richards that ordered and AB,
Connectors will be here Thursday.
I think I'll limit the next sale to just the Michaels out there hihi
Adam-V
I'm Michael and so is my wife....
Adam-V
mmm
Adam-V
There's two!!! SlayerBadger!
On a more serious side. The VC Dual LFO sale ends tomorrow at midnight PDT.
I might even have enough connectors by the next morning. w00t
klstay
Looks like the same asswipes changed the page again?
klstay
Also, what is the response curve on these?
mmm
Thanks, I fixed the page. IDK why people do that. Frying Pan Bash!
The response curve is linear.
G
