SSSR Labs Kotelnikov - Wavetable oscillator/voice
rpocc
Post by rpocc » Sat Jul 23, 2016 11:14 am
Kotelnikov is my latest product: a digital voltage controlled wavetable oscillator module with morphing feature and built-in transient generator available as DIY kit.
This oscillator can generate number of sounds with diverse spectral content and combine them in various proportions. Kotelnikov can be used as a usual oscillator in a traditional subtractive synthesizer system, but it is also possible to use it as a complete voice module as it features shaped timbres, envelope generator and amplitude modulation.
Technical highlights
  • The sound engine sampling rate is locked to pitch and varies from 4.2 to 133 kHz, which gives very clear highs and uniform spectral content over the full range.
  • The Pitch resolution is 6 cents and CV input sampling rate is 6 kHz, which gives smooth analogish FM-ready CV response.
  • Analogue Amplitude Modulation input is bipolar, linear, rail-to-rail.
  • User-updatable wavetables and user-friendly audio bootloader (MCU version 1.1)
Kotelnikov contains 80 waveforms organized in 4 banks:
  • DRUID: Collection of Electric Druid VCDO wavetables (used with permission)
  • ATTACK: Interleaved dark/bright wavetables pairs
  • HARMONIC: Frequency-relative sinewaves
  • HD: Selected 12-bit wavetables
The firmware is written in Assembly language to ensure glitch-free operation and maximum working range.
The Transient Generator has 3 modes: AD/AR envelope generator or resettable LFO. Total time range of 0.4µs–10s is divided into 3 subranges. This generator is internally connected with FM and WM inputs, which helps you to achieve fluent, alive sound with no wires at all.
Specifications:
Pitch: 7 octaves range (C0-C7), 6 cents resolution
DAC: 12-bit, variable sampling rate: 4.2–133kHz
Wavetables: 3x16 8-bit tables, 32 12-bit tables. 256 samples each.
Control ADC: 0–5v, 10-bit, 6kHz
Width: 14hp
Depth: 40mm
Dimensions: 71x129x60mm
Weight: 230g
Current draw @+12v: 50–80mA
Current draw @-12v: 20–50mA
Product page
DIY Full Kit (in stock)
Modulargrid page
Dealer in the US
SSSR Labs — synthesizers and DIY kits from Russia
modularsynth.ru/en/ — modular synth blog
My modular system
GryphonP3
Post by GryphonP3 » Sat Jul 23, 2016 9:38 pm
Thing looks killer :sb: any hope for a PCB/panel version in the future? I have a policy to only ever use my own parts nowadays.
My cat can eat a whole watermelon ...
latigid on
Post by latigid on » Sun Jul 24, 2016 4:24 am
The parts list looks pretty esoteric -- Russian switch IC?
I'm curious about what parts are done in software vs. hardware. Any chance of a schem/block diagram?
rpocc
Post by rpocc » Mon Jul 25, 2016 6:07 pm
GryphonP3 wrote:Thing looks killer :sb: any hope for a PCB/panel version in the future? I have a policy to only ever use my own parts nowadays.
I'm not planning at his moment to add such kind of item in the store, but if you're really looking for the minimal kit, I can do a special offer for you personally:
* PCBs
* Front panel
* Programmed ATMEGA
Four most rare components (Optionally):
* Russian chip КР590КН5
* AD7545
* REF5050
* 4x 0.1% 100.0k resistors
PM me.
latigid on wrote:The parts list looks pretty esoteric -- Russian switch IC?
I can't publish the schematic, but I made this diagram for you:
PDF
The switch IC is needed for the Transient Generator. Unlike CD4066 it is close equivalent to a MAX analog switch, which is simply cleaner, faster and has separate V+ for logic and signal.
My modular system
rpocc
Post by rpocc » Wed Oct 05, 2016 8:05 am
A new demo with manual scanning through Kotelnikov's wave forms in all 4 banks. No processing, no editing, no effects. Recorded through a transformer direct-box, so certain ultra-low frequencies might disappear.
My modular system
sammy123
Post by sammy123 » Wed Oct 05, 2016 8:28 am
I've been using this oscillator a lot more lately and I gotta say....it's really nice in both sound and functionality. Harmonic mode rocks. :tu:
glitched01
Post by glitched01 » Sat Mar 04, 2017 3:15 pm
Nevermind. Got the answer.
JohnnyThorj
Post by JohnnyThorj » Mon Mar 06, 2017 6:20 pm
Druid mode have very impressive, mystical sound. Like it
glitched01
Post by glitched01 » Tue Mar 14, 2017 4:12 pm
This was one of the best and hassle-free builds I've done. Well-documented, no surprises.
Check out my build-log, here:
http://synth.glitched.org/
andban
Post by andban » Tue Aug 29, 2017 3:15 pm
I've build the minimal kit and thanks to the good build instructions i've had build the thing in no time. I really enjoy the module.
The only issue i've encountered is, that the LFO only retriggers when the decay time is set to very fast (switch set to fast mode and pot is dialed less than ~2o'clock). On different settings, it retriggers sometimes 3-4 times but normally just behaves like an AD.
Its likely that i've used some wrong/faulty component somewhere, but before i randomly replace parts, i thought maybe you can give me a hint which components might cause that behavior? Thank you!
AMHOWL
Post by AMHOWL » Tue Aug 29, 2017 6:56 pm
Just finished my build yesterday.
Sounds absolutely great, and ridiculously fun!
Very well documented build.
Hadn't anticipated how much fun drums with this thing could be too! :sb:
IamM.A.D.
Kotelnikov
Post by IamM.A.D. » Fri Nov 24, 2017 1:45 am
Hello. I just finished building your Kotelnikov kit and it keeps burning out IC13 as soon as I power up with the knobs and switches set according to the build document for the power up test. I've looked it over and everything looks good. Can you help me with my issue. Thank You.
-Marcus
rpocc
Re: Kotelnikov
Post by rpocc » Fri Nov 24, 2017 2:06 am
IamM.A.D. wrote:Hello. I just finished building your Kotelnikov kit and it keeps burning out IC13 as soon as I power up with the knobs and switches set according to the build document for the power up test. I've looked it over and everything looks good. Can you help me with my issue. Thank You.
-Marcus
Hi! Please send me a pictures of your build to sssrlabs@sssrlabs.com.
Usually it can happen due to mixed up power pins.
My modular system
talfred
Post by talfred » Thu Dec 14, 2017 4:24 pm
I bought a kit from Synthcube and there was a few strange things there.. Instead of two 130K and two 150K resistors there were two 13M and two 15M resistors. I would guess the correct values to use is 150K and 130K?
And I'm not sure if two of the capacitors are correct either. Anybody else had kits with wrong componenets?
Else this is a great build! Would be nice if SSSR Labs could provide pictures of the latest PCB versions (with black silkscreen). I forgot to take a picure before I started
rpocc
Post by rpocc » Thu Dec 14, 2017 4:52 pm
talfred wrote:I bought a kit from Synthcube and there was a few strange things there.. Instead of two 130K and two 150K resistors there were two 13M and two 15M resistors. I would guess the correct values to use is 150K and 130K?
Hi! There's nothing wrong with components. It's just a 3-symbol notation for e12 resistors:
13M and M13 are not the same!
In that package you can also find 100K 0.1% soviet resistors labeled as "M1 0.1%"
13R = 13 OHms
130R = 130 Ohms
K13 = 130 Ohms
1K3 = 1300 Ohms
13K = 13000 Ohms
130K = 130 KOhms
M13 = 130 KOhms
1M3 = 1300 KOhms
13M = 13 MOhms.
My modular system
talfred
Post by talfred » Thu Dec 14, 2017 5:13 pm
Thanks for answering, so M13 is actually 130K and M15 is 150k, that's good to know! (and I'm sorry, I see it's also written in the build manual)
I'm also not totally sure about two of the capacitor values, there's a big one that looks like a ceramic one, but that's the mylar 3n3 isn't it? I'll have to get back later with this question as I don't have it here right now..
talfred
Post by talfred » Sat Dec 16, 2017 4:38 pm
The last of the blue ceramic capacitors supplied in the kit is labeled 331, that's a value of 330 pF. Is it OK to put it into C35 even though it's supposed to be 300pF?
rpocc
Post by rpocc » Sat Dec 16, 2017 8:28 pm
talfred wrote:The last of the blue ceramic capacitors supplied in the kit is labeled 331, that's a value of 330 pF. Is it OK to put it into C35 even though it's supposed to be 300pF?
Absolutely. It's 10% or even more tolerance anyway.
And the big one is a tantalum 10u
My modular system
CRD
pitch pot
Post by CRD » Tue Jan 16, 2018 5:23 am
i completed the module and it looks like it works as it should except for one thing:
the pitch pot is working only when i turn it to mid-high positions(one step after the center).. looks like something curious.. isn't it? :help:
rpocc
Re: pitch pot
Post by rpocc » Tue Jan 16, 2018 6:07 am
CRD wrote:i completed the module and it looks like it works as it should except for one thing:
Probably that was you asking the same question by email. I've just replied about 10 minutes ago and will also reply here.
This is the block diagram of the module:
It has only 1 ADC input for the pitch, so all pitch and FM-related controls go to an analog summing stage and being acquired at the same time with the maximum range of 0–5.000V equivalent to exactly 5 octaves. (This ensures the perfect tracking) So, when all inputs are at 0V, the Pitch knob is intended to have the minimum value with the low-C at the center position. As more voltage is applied to the V/Oct input, knob starts to work in full range.
My modular system
CRD
Post by CRD » Sat Jan 27, 2018 6:43 pm
hello dimitry,
firstly thanks for double answers and secondly for this little terrific(and well documented) device!
now i got a doepfer midi cv interface (version 3) and started to send gate/pitch from an elektron monomachine..
i read into your manual that cv/gate passes directly from the power socket(the two wire jumpers are inserted).. the only strange thing which is still unsolved is:
within this setup i always get sound from the module even when i stop playing notes, the module keep on playing the last note/pitch triggered. so I don't get what shown on your modulation video above!
i know monomachine is not what can be called as the "usual" midi keyboard, this was actually the first time i was using its midi output..
rpocc
Post by rpocc » Sun Jan 28, 2018 3:15 am
CRD wrote:hello dimitry,
You just need to connect TG output to the AM input to achieve what you want.
My modular system
CRD
Post by CRD » Sun Jan 28, 2018 4:36 am
ok, good to know, now i get it!
Ayab
Post by Ayab » Sun Jan 28, 2018 7:31 am
Lovely sounding device from the demos. I like the way it can be so smooth and musical. I really like the design too - stylish but also a practical layout.
lapdog
C30 & C31 values
Post by lapdog » Sun Mar 11, 2018 7:24 am
Hi there,
building this right now, and I noticed two things:
1. instead of C24 1n ceramic I got a mylar/film-looking (blue) one with the same value, 1nF. I guess it's no big deal, just noted.
2. C30 & C31 are supposed to be 22p, the ones I got are marked 220. Can I still use them?
