Moderators: Kent, lisa, luketeaford, Joe.
hmm 28 H x12.5 W x 11mm LHaving a hard time finding the correct switches.
Would theses work fine?
appears to be T092 100mA version so should be correct from the BOM note I don't actually have a build of this myself to check against.can anyone please confirm that using this 79L09 is correct?
https://www.reichelt.de/ICs-A-A-/-A-79L ... N=3&LA=3&A RTICLE=23508&GROUPID=2908
hmm post a good picture of both sides of your board and try to describe problem in detail maybe post an audio file of what is happeningHaaaaalp
I wouldn't do that because you may not have all the ground connections in place, but maybe somebody more experienced here can correct me if I'm wrong.hippasus wrote:I just populated the pcb, minus cv sockets and pots, I only solder six pots and in the outs only the main out while waiting to find a panel.
Is it possible to test it like that? I am going to blow something if I connect the power?
I did this and nothing blown up. I did it to measure voltages outputs of transistors and they were fine. Can't be sure on your build though.hippasus wrote:I just populated the pcb, minus cv sockets and pots, I only solder six pots and in the outs only the main out while waiting to find a panel.
Don't know german but here are the specs of the one I got if they can somehow help:Puzzler wrote:can anyone please confirm that using this 79L09 is correct?
https://www.reichelt.de/ICs-A-A-/-A-79L ... OUPID=2908
Somehow the benjolin is behaving strangely, even though i made the schottky diode mod for the V2164.
Sound goes on and off etc. Touching the case frame "sometimes" changes sound? maybe a ground problem?!
i even removed the CV pots for testing though.
hmm that possibly may have been IC socket related - did you resocket any IC's during this or just power cycle ? either way it may have cleared up with cycling the powerI tested my second module and it sounded similar distorted, but suddenly after several PSU switch on/off it started sounding clean.
OK that is a little weird unbalanced output to balanced input should be all rightNow i pulled out the 6.3 jack a little little bit and suddenly the pulse is loud as expected. Pushing it back in fully makes it quiet again.
And NO its not a problem of the PSU, the jack nor the audio interface. The issue is not reproducable with any of my other modules
what if i have this issue nevertheless. where would i install these 2 other schottky diodes?When you run the board with a power supply it is a very good idea to solder two diodes instead of the two battery connections. Do it in a way that the cathode of the diode is connected to the + of the battery connector and the anode connects to the - connection. This way the diodes do NOT conduct. The reason why this is a good idea is to insure proper startup of the voltage regulators when powering up. Without these diodes there is a chance that one power regulator starts up before the other and this will prevent the other from starting up, resulting in silence. The diodes fix this properly. If you use a non-symmetrical power transformer, like a wallwart thingy, two rectifier diodes and two elcos, either the + or the - voltage comes up before the other one, and that voltage will pass a regulator and make the other regulator sense an "inverted" voltage on its output and force the other regulator into permanent short circuit protection mode. The diode will short this "inverted" voltage to ground and assist the other regulator when it comes up just a fraction of a second later. These diodes can be simple 1N914 types.
???solder two diodes instead of the two battery connections
ah ok his description is purely for the original board not this euro versionwhat if i have this issue nevertheless. where would i install these 2 other schottky diodes?
R49 is the only 510k there is marked on the board - as you can see there is no 510k on the BOM, so replace the only one of those you can find on the board with 510R. If you look at the relevant part of https://github.com/kweiwen/benjolin/wik ... the-module you can see "VR8" on one of the pots on the silkscreen in the image (why the part names are left off production PCBs, I don't know), the resistor is on the left side of that one.jestern77 wrote:which one is r49? And r36?
