5U intelligel metropolis type sequencer..?
josaka
Post by josaka » Thu Aug 04, 2016 5:11 pm
anything like the metropolis sequencer in 5U..?
if somehow you missed it..
Dr. Sketch-n-Etch
Post by Dr. Sketch-n-Etch » Thu Aug 04, 2016 6:16 pm
Why not mount a Metropolis onto a blank 5U panel, and mount that in a 5U case? Of course, you'd have to ask Danjel van Tijn whether the Metropolis would tolerate +/-15V power or not...?
They always said I would be nothin' but a fishhead -- look at me now!
sduck
experimental use of gravity
Post by sduck » Thu Aug 04, 2016 8:58 pm
There's the unobtanium Ryk M185 that it was based on...
ImageRyk m185 Sequencer front by Stephen Drake, on Flickr
peachfuzzmcgee
Post by peachfuzzmcgee » Thu Aug 04, 2016 9:00 pm
Not to hijack the thread but if anyone ever figures out if it's possible to power the intellijel stuff on 15v I would love to know as I'm interested in converting their Dixie II plus into 5u, or maybe if I can fit two Dixie II behind a 2u panel that would be really dope. Wanna put them on a MU blank
Last edited by peachfuzzmcgee on Fri Aug 05, 2016 6:11 am, edited 1 time in total.
sduck
Post by sduck » Thu Aug 04, 2016 9:08 pm
Making a +-15v to +-12v converter for euro>5U conversions is pretty simple. I've built a bunch of them on protoboard, enough that I started working on a dedicated small pcb for these, but haven't finished it. Such a thing may already exist.
Post by JohnLRice » Thu Aug 04, 2016 9:10 pm
peachfuzzmcgee wrote:Not to hijack the thread but if anyone ever figures out if it's possible to power the intelligence stuff on 15v I would love to know as I'm interested in converting their Dixie II plus into 5u, or maybe if I can fit two Dixie II behind a 2u panel that would be really dope. Wanna put them on a MU blank
Talk to the good Dr. Sketch-n-Etch a couple posts above, he may have a 5U version of the Dixie he can sell you? :hmm:
Voltage_Controller
Post by Voltage_Controller » Thu Aug 04, 2016 9:11 pm
It really is a compelling sequencer. I've considered purchasing a small euro skiff just to run a Metropolis with my MU format system.
I wonder how much Free State would charge for that epic of a repanel :twisted:
“The only truth is music.” ― Kerouac
josaka
Post by josaka » Thu Aug 04, 2016 10:56 pm
sduck wrote:There's the unobtanium Ryk M185 that it was based on...
this is epic.. I knew it was a roland but never seen this version or used in anger..
you build all the best modules !
MrNezumi
Post by MrNezumi » Thu Aug 04, 2016 11:23 pm
sduck wrote:Making a +-15v to +-12v converter for euro>5U conversions is pretty simple. I've built a bunch of them on protoboard, enough that I started working on a dedicated small pcb for these, but haven't finished it. Such a thing may already exist.
Would this have MOTM-style connectors or DotCom or both?
kindredlost
5U skiff friendly
Post by kindredlost » Fri Aug 05, 2016 7:14 am
Voltage_Controller wrote:It really is a compelling sequencer. I've considered purchasing a small euro skiff just to run a Metropolis with my MU format system.
I have one of the Intellijel sequencers. It has the linear pots and most of the functions like direction, pulse, gate and stage are all digitally implemented through menu diving unlike the Roland which has stages, division and direction on the front panel switches. I don't see it as a bad thing because they are all a real quick button push and encoder twist away. Very fast access. The real difference in my opinion is that Danjel has added quite a few more features and increased things like up to 64 pulses, many more stages and has all of these things under CV control. Very very cool.
The ability to desolder and replace the linear pots with rotary pots and convert the numerous digital functions to panel switches may be quite the challenge even for the highly skilled such as the FSFX crew. If it were only a challenge then it might be fun yet risky, but if it were just a matter of gaining access to one of these unique, classic sequencers then going for the 3U setup could be the most sane route. A Happy Ending Kit is all you really need.
sduck
Post by sduck » Fri Aug 05, 2016 8:15 am
Both if I ever get around to finishing it. FreestateFX may already have something like this.
MrNezumi
Post by MrNezumi » Fri Aug 05, 2016 9:00 am
I was just at the FSFX website and didn't see any power adapters there. I'm trying to sort out the whole mixed format (MOTM/Euro) thing. I thought it was just a power problem but there seems to be more to it.
Post by JohnLRice » Fri Aug 05, 2016 1:34 pm
Some foodz for thoughts on eurorack power options with associated downsides:
COTK has a DotCom +-15v to +-12v eight position adapter board plus the order of the voltages on the pins is relatively the same as eurorack.
Downsides: They use 14 pin connectors instead of 16 pin like eurorack distro boards and they are keyed the opposite way.
Possible solution: buy 14 pin connectors, cut off 16 pin connector from eurorack cable, attach 14 pin connector correctly orientated. Lot's of potential to accidentally do it wrong though.
Mos-Lab also has a DotCom +-15v to +-12v eight position adapter board (plus a little single position one).
Downsides: They use 10 pin connectors instead of 16 pin like eurorack distro boards and the wiring order isn't compatible at all so making adapter cables would be difficult.
With both the COTK and Mos-Lab distros it might be possible to make a "rider" PCB to convert them to eurorack power use, like having female COTK or Mos-Lab connectors on the bottom and eurorack headers on top but, if someone went to that much trouble it would make more sense just to add a few regulators, resistors and capacitors to create a stand alone +-15v to +-12v eurorack adapter board. :hmm:
Doepfer has a couple possibilities:
The a-100 mnt, this is the same power supply they put into their little 32 hp cases I believe. Only $60 + $15 for the wall-wart. http://www.analoguehaven.com/doepfer/a100mnt/
Downsides: It requires a 7v to 9v AC input so connecting to a DotCom supply would not be possible, or at least somewhat difficult (tapping off the transformer secondary "might' be possible if the needed voltage is present but doing so without a reasonable engineering level understanding of power supplies is asking for trouble) So, better just to use a wall wart with it.
A-100SSB Small Supply/Bus for DIY applications with up to 8 modules / max. 380mA. Release date: June 2016, price about Euro 70, the picture shows the prototype without silk screen.
Downsides: It needs to have a 100-240v AC connection. Mounting holes don't look like they are placed well or enough but this is a prototype picture so maybe the final version will be better?
zapp550
i'm prefect, are you?
Post by zapp550 » Fri Aug 05, 2016 2:49 pm
The metropolis was the sequencer that almost made me sell off my 5U system and head the euro route, really glad I didn't go all in though. The metropolis is a fantastic sequencer and while I enjoyed it while I had it the euro format just drove me crazy, I'd imagine converting it to 5U/MU would cost a ton if it was done well. I'd really like to see the Ryk M185 available again even though I've heard it was a tedious build; the feature set is just that good.
My new album-
[bandcamp width=100% height=120 album=2252334289 size=large bgcol=ffffff linkcol=0687f5 tracklist=false artwork=small]
My musical/visual meanderings
http://soundcloud.com/autumn-drones
http://www.youtube.com/user/analogueboy1
ach_gott
Post by ach_gott » Fri Aug 05, 2016 4:09 pm
zapp550 wrote:I'd really like to see the Ryk M185 available again even though I've heard it was a tedious build; the feature set is just that good.
You can see why:
Phil (Megaohm) built mine. Each of those box switches has to be handwired and routed.
Edit: It's a great little machine, though, and it's a kick to play with.
Post by JohnLRice » Fri Aug 05, 2016 4:29 pm
You can see why:
:eek: I suppose there was a reason that a PCB wasn't created for the box switches? :hmm:
ach_gott
Post by ach_gott » Fri Aug 05, 2016 4:31 pm
JohnLRice wrote: :eek: I suppose there was a reason that a PCB wasn't created for the box switches? :hmm:
You can sub in other pieces, though I'm not sure what other people used. These were a group buy when the PCB was first offered. But it's a good thing that they didn't design the PCB around them as they went out of production not too long after that.
zapp550
Post by zapp550 » Fri Aug 05, 2016 4:46 pm
You can see why:
:goo: I was at Phils when he was finishing those up and talking about the build, they looked fantastic though and I was so jealous..you ever want to sell let me know :hyper:
My new album-
kindredlost
5U skiff friendly
Post by kindredlost » Fri Aug 05, 2016 5:05 pm
zapp550 wrote:...The metropolis is a fantastic sequencer and while I enjoyed it while I had it the euro format just drove me crazy...
Of course everyone is formed from a different mold but I still think it is worthy of a small setup in 3U. I don't see there being any dialog issues between the formats but I definitely agree Eurorack has it's fiddly foibles. Not a real fan of the tight distances either but the original Roland design wasn't far removed from the size in 3U.
BTW, when was this conversion board set offered (what year)? I totally missed that somehow. I do agree if I could get the Intellijel version in 5U it would be quite awesome. I just am not so sure I'd give up the extra features to go with a more cloned version personally. Having control over the amount of pulses, quantization scales, larger sequence length, shuffle timing as well as little detail extras in gate and trigger functions etc., are really nice.
Does the 5U version shown have both skip and slew function available on the stage push buttons? I am not familiar with it at all.
sduck
Post by sduck » Fri Aug 05, 2016 7:56 pm
It wasn't a conversion board set - it was it's own little DIY pcb and chip that was offered up in very limited numbers on electro-music.com back in 2008 or 2009 or so. Completely unrelated to the Metropolis actually, which didn't exist at the time. Those unobtanium switches were part of the deal. Panels were hard to get - slots that worked for those switches are tricky - a guy named Julien in the UK made a bunch of MOTM format ones, which I have one of. It was kind of the most extreme DIY I'd done at the time - all you had was the PCB and chip, a parts list, and a schematic/wiring diagram that wasn't much help. I was totally convinced that it wasn't going to work when I first powered it up, and I even video recorded the first power up just in case, but it actually worked to my amazement!
While it looks like the roland sequencer, it's actually quite different (I think, never used the real thing). It does have the switchable slew per step, and quite likely the skip feature, but these require multiple button presses to get to, and I can never remember what they are. Mine's actually been stuck with steps 1, 3 and 7 with slew on for years.
drob842
Re: 5U intelligel metropolis type sequencer..?
Post by drob842 » Sat Aug 06, 2016 7:23 am
josaka wrote:anything like the metropolis sequencer in 5U..?
Good god, I did not need to see that video. I intentionally ignore most eurorack news because I fear constant GAS. This sequencer may have finally pushed me to start a small eurorack setup to complement my 5U.
Thanks a lot. :moneyburn: :moneyburn:
Jamnuska
Post by Jamnuska » Sat Aug 06, 2016 10:49 am
Ha, pull up Mylar Melodies other video on Stepper Acid.
<iframe width="640" height="360" src="https://www.youtube.com/embed/Mj0Hw6z9p ... r_embedded" frameborder="0" allowfullscreen></iframe>
Hope that embed works. Never tried that.
If not:
Also if you want some crazy buttons and super powers:
http://www.audiodamage.com/hardware/pro ... ?pid=ADM06
Paradigm X
Post by Paradigm X » Sun Aug 07, 2016 3:05 pm
ive got a pcb and the chip, but no switches
can potential ne built with rotary switches...
bit beyond my skills at the mo i think sadly. long term dream.
dslocum
darwin's nemesis
Post by dslocum » Sun Aug 07, 2016 4:01 pm
If someone knows Ryk (the inventor of this seriously wonderful module) could you please see if you might persuade him to allow others (like me - SSL) to produce them for folks that aren't DIY savvy?
I would LOVE to make this sequencer available, and would love to have at least three in my rack.
I would replace the unobtainium switches with slide pots though. Having looked into many sources for these switches, and without an order for over several hundred thousand units, you're just out of luck.
Fingers crossed.
Ryk - How about it sir?
Doug Slocum
Synthetic Sound Labs
www.steamsynth.com
"I guess all the Forest Mims Radio Shack books I read finally paid off!"
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"...this whole thing was started by a dream and a mouse." - Walt Disney
"Flatulence sounds aren't just for brass and reed instruments anymore, thanks in large part to Dr Moog." - Ockeghem
sduck
Post by sduck » Sun Aug 07, 2016 9:24 pm
Try PM'ing him over on electro-music.com. The thread about this isn't far from the front page - not a lot of activity over there. Wait, let me see if i can find it....
Here...
http://electro-music.com/forum/viewtopic.php?t=27157
BTW it's ryktnk, not ryk. This might confuse some people, as there's also a fairly prominent DIY guy from Canada who goes by Ryk.
Return to “5U Format Modules”
