Mister Grassi
Moderators: Kent, bartlebooth
Mister Grassi
Looks like Peter has a new IFM touch module, Mister Grassi. Looking forward to this one...
"Grassi, a touch-module, contains twelve square waves, used as the clock and data for shift registers, each followed by primitive resistor DAC. The DACs modulate clock and counter-clock wise, yielding closed loops of perpetual modulation, triggered by touch. Each of the six outputs are a single, four-bit DAC. Listening to them raw, they generate modem sounds to pure noise on touch. On release of touch, each DAC holds the contingent position of its DATA. Thus the DATA can be used as CV for up to six other operators, scrambled on touch. Touch->Scramble->Listen; Untouch->Hold->Feed
Grassi features a triangular hexagon, used for square-wave outputs (outer rim) and DAC triggers (inner core). Thus, a triggering touch should connect an outer station to an inner station, to begin the rungling process."
Manual http://synthmall.com/ifm/ifmGRASSI.pdf
- wednesdayayay
- Super Deluxe Wiggler
- fluxmonkey
- Contact:
- yghartsyrt
- permanent entropy
- pugix
- Contact:
Also interested in this.
Richard
https://www.pugix.com
- Paranormal Patroler
From what I gather this module acts like a T&H on random voltages being output while you keep your finger on the panel. There seems to be a trigger side of things (outer rim) and a voltage side of things (inner triangle) for all six outputs. Any insight ?!
I'm curious what the voltage range is and what the waveforms are. There are examples on the manual but I'm not sure whether it's a constantly fluctuating signal or something that starts only when you press it.
I also wonder how well this will work with other Eurorack modules.
agreed, grassi looking v cool.
Hilarious though somehow to see paper circuit now in euro.
If it rungles like the benjolin then it will hold the cv of each output indefinitely until touched agian. I suspect those cv states could get pretty complex depending on the complexity of the touch modulation that happens. So maybe anything from lfo like sweeps to erratic s&h patterns?
touchable chaotic pattern generator
I'm sure that it won't work well with euro but will be a great way to scramble a well working rack lol
- windspirit
- wednesdayayay
- pugix
- Contact:
I see that the IGM Keyboard with Mister Grassi is now available at synthmall and also control.
http://www.ctrl-mod.com/products/igm-ke ... ter-grassi
But I want just a stand-alone Mr. Grassi module.
I have a Mocante in the wood case, but I want to move it into a Eurorack case, so I can add Mr. Grassi and some support modules.
Richard
Paranormal Patroler wrote:I didn't know you were into CL stuff.Summa wrote:Yep, it's totally weird you can't order Grassi separatelyI'd love to see you get your hands on one and give us some feedback
Andreas, can you please explain why rangling makes people so excited ? I'm totallySumma wrote:short update from Peter B "Hi andreas, thanks for the interest. yes indeed soon i will have it but not quite yet!>>>> hang on! -peter"
Well KonstantineParanormal Patroler wrote:Andreas, can you please explain why rangling makes people so excited ? I'm totallySumma wrote:short update from Peter B "Hi andreas, thanks for the interest. yes indeed soon i will have it but not quite yet!>>>> hang on! -peter"
by this one but I still think Mr. Grassi looks very nice so I'm very much interested to see if it's worth adding on my controller rack space.
I googled up Rungling and came to the Benjolin but the examples are scarce, or meh. If you do get the Grassi please make a video. A "special" kind of random that gets people excited, even more so if it's a playable one, is nothing something I'm usually interested in but here we are.Summa wrote:Well KonstantineParanormal Patroler wrote:Andreas, can you please explain why rangling makes people so excited ? I'm totallySumma wrote:short update from Peter B "Hi andreas, thanks for the interest. yes indeed soon i will have it but not quite yet!>>>> hang on! -peter"
Have you ever tried a Benjolin? I'm not sure how the shift registering actually works inside that one, but it's one oscillator that "clocks" the other and feeds it back again. It's another controllable "random", there's really nothing else that resembles it, I tend to use the Rungle out of my Benjolin for other duties but if Mr Grassi adds hand-on control and manipulation to that it can only be good.
- thresholdpeople
- Veteran Wiggler
I don't know if they ever got posted to Muff's, but Pjay, who is a wiggler on this forum, had some really, really lovely Benjolin based tracks that he shared on facebook. I guess it was last fall/summer at this point... wow time goes quickly. I believe they were facebook video uploads, so it's sort of an unsearchable hole and for all intents gone now, unless he has them somewhere...Paranormal Patroler wrote: I googled up Rungling and came to the Benjolin but the examples are scarce, or meh. If you do get the Grassi please make a video. A "special" kind of random that gets people excited, even more so if it's a playable one, is nothing something I'm usually interested in but here we are.
- Dirty_Bill
- Ultra Wiggler
- Dirty_Bill
- Ultra Wiggler
