3 trins RGB+1C discrete RGB output signals
Author 3 trins RGB+1C discrete RGB output signals
andrethitcho
Hi,
does anyone know if the video synth 3trins RGB+1C can output discrete RGB signals?
Thanks.
Dirty_Bill
andrethitcho wrote:
Hi,
Thanks.
Depends on how you'd want to use them -
The outputs of the R/G/B channels are available on the patch header, but are not suitable for connection to external video devices.
FetidEye
check out the lzx expander!
(for using the 3trins with lzx modules)
in combination with some cadet series modules you can output video
andrethitcho
Thanks for the answers.
I've noticed that there are RGB connections on the left side of the PCB board.
So, I wonder if I could solder some RCA jacks into them.
I've emailed Gijs and he told me I could try it.
I'm aware of the LZX expansion but could not find any info about what i'm trying to achieve. And that is: I want to output RGB signals to the RGB inputs of my Sony PVM monitor.
Dirty_Bill
You'll need quite a bit of level shifting and sync to run the outputs from the 3Trins into an RGB Monitor input, even with the LZX Buffer. you COULD run 3trins LZX buffer -> LZX Visual Cortex and run those outs to the monitor...
andrethitcho
Dirty Bill, thanks a lot for the information. I'll check LZX modules, then.
Dirty_Bill
The Cadet Syn Gen/Encoder combination would probably work as well.
andrethitcho
Cool. Thanks.
