As a bit of background, I'm a big ciat-lonbarde/Blasser fan, and have used tons of his gear over the years with my main interesting in modular stuff coming from his introduction of IFM (I normally post in the IFM forum).
I'm primarily a drummer/percussionist (when I perform), and do a lot of programming (in Max). I've also done a bunch of projects where I combine these things (whisks, onset analysis, descriptor analysis), and want to develop those ideas further.
Short example vids:
Basically I really like a dirty/gritty/noisy drums+synths type sound, not too dissimilar to MoHa! (although I believe he uses SuperCollider for his noise).
So with all of that being said, what I want to do is build a somewhat compact system that is focused on using Expert Sleepers stuff (ES3, ES6, and possible ES5) to trigger/control some noisy sources (primarily IFM?). I plan on doing all the control/triggering stuff from the computer, so I would need no clock stuff, and I dislike filters, so that rules most of that out.
Other than a few (illuminating) conversations with @tremblap, I've not really gotten too deep into how to go about this. Based on my chats with @tremblap I've put together a really rough modulargrid sketch:
https://www.modulargrid.net/e/racks/view/185731
I don't know if I'll need the utilities, or go with a 4ms power thing, nor if this is the size I'll go with (I want to keep it compact enough to travel lightly, hence only considering the ES5).
SO
What modules/makers would people suggest here?
(with the caveat that a computer is involved, so it can handle a lot of processes/functions)
For the IFM stuff I'm mainly looking at the Fourses, and I suppose Swoop/Denum, though I have to say I find the descriptions to be a bit overlapping/confusing. The Sprott is (kind of?) a filter, but a Blasser crazy one, so I'm happy to give it a test run.
But beyond some IFM stuff, and ES stuff to control it, I'm not really sure what else to look for.
What are some other good (noisy!) sound sources?
Would I need much(/any?) utility stuff? (An ES3/ES6 would give me 8out/6in)
Envelopes/VCAs?
Weird process/fx? (again, that wouldn't be better served in the computer)
And some functional questions:
In terms of getting audio back into the computer should I just use the ES6 or run back into an input on the soundcard? Or is it better to use a transformer to leave euroland and come back to audioland?
As far as a case, I want to go real lean/light with it, so probably a corrugated plastic DIY thing, or maybe a pelican. I guess it depends on how big the setup ends up (famous last words for all first time euro-ers I'm sure!).
I've seen some cases where there are smaller panels at the top/bottom. Are there provisions to have some (8hp) modules in there sideways? Like, could I have my ES stuff along the top sideways, and just have the main area for sound production stuff?
Any other thoughts/suggestions?
