Ring mod options
construct09
Sine me up
Ring mod options
Post by construct09 » Tue Sep 27, 2016 4:14 am
Hello
I don't have a ringmod in my bugbrand banana frac system, the bug ringmod is near impossible to find so I guess I,ll have to source a DIY solution
Klangwerk is out of the question (pcb is too deep) and I would prefer it to be 1fw anyway
What options do I have? (I,m considering the Oakley at this stage)
It must have banana jacks!!!
thanks
werock
Post by werock » Tue Sep 27, 2016 9:35 am
There is the MFOS one, but I would guess that is probably going to be too deep for you as well.
There is also the 1fw width Paia one, although you'd need to change the jacks. A cheap & cheerful option maybe!
J3RK
Post by J3RK » Tue Sep 27, 2016 11:09 am
I have a 1"x3" PCB for an AD633 based 4Q Multiplier/Ring Mod. I haven't done a large production run yet, but it's tested, and works beautifully. I'd be happy to build a Frac module for you based on this PCB.
I may also have a 1"x3" PCB for a Schottky Diode based XOR circuit that has both logic output, and a differential amplifier for bipolar audio output. I'll need to check though to see if I still have any of these ones laying around.
Both sound great when used for ring modulation. The AD633 one is squeaky clean, the diode one has a little more character.
PM me if you'd like me to build either, and we can discuss the details.
I can do the panel in red or blue with bananas to more or less match the Bug system. It won't be an exact match to the PCB material, but close.
e-grad
Post by e-grad » Tue Sep 27, 2016 11:17 am
In my opinion Tony's RM is absolutely fantastic:
http://www.oakleysound.com/ringmod-e.htm
Ive built a couple if Oakley modules for my frac. To my experience any of Tony's 5U modules feat. 3 pots only can be built for frac while mantaining the pcb-mounted pots.
The module linked above is one of Tony's few designs for Euro and runs on +/-12V. I've no ideas whether it needs any mods to run it on +/-15V.
Synthbuilder
Post by Synthbuilder » Thu Sep 29, 2016 3:12 am
e-grad wrote:The module linked above is one of Tony's few designs for Euro and runs on +/-12V. I've no ideas whether it needs any mods to run it on +/-15V.
Don't get the Euro one for Frac. Go with the standard version:
http://www.oakleysound.com/ringmod.htm
That's 15V and has the correct power supply header for Frac. The only difference between the two builds is the power supply header and a few resistor changes. The PCBs are the same size.
Tony
construct09
Sine me up
Post by construct09 » Thu Sep 29, 2016 3:22 am
Tony
PCB is too deep unfortunately, close though :sadbanana:
Thanks for all your suggestions, the passive CGS is another option.Image
Got appx 70mm to play with
Return to “Fractional Rack Modules”
