Repairing Plumbutter 2 faulty jacks
home of post-70s electronics
Moderators: Kent, infradead, bartlebooth
Cobramatic
Post by Cobramatic » Mon Oct 17, 2016 12:19 am
Hi All, I’m relatively new to the Plumbutter world but I wanted to share my initial experience with others because the simple repair work I did this weekend has just brought a whole new life to my PB2.
Basically, like everybody else, it takes some time to figure out what is happening when you are patching. I mean the instrument is well known for its unpredictability compared to so called ’traditional’ synths – this is clearly part of its charm and appeal. I totally get that. That’s why you get one!
Tricky thing is – when an instrument is known for its quirkiness then how do you know something is actually working as it is intended to?? I mean, other than reading all the posts and watching some of those amazing videos by many of the Wigglers here, I had no clue to start with. Then as I started to understand I wondered why some things didn’t do what I might have hoped they would...
For example – you would expect those purple FM inputs to give you some type of FM modulation when a jack is plugged in – but because the knob already changes the sound on its own, and differently depending on the direction of turn, I couldn’t be sure I was getting a result. Basically I wasn’t getting a result!
Rollz – I knew I should be able to mix things up with the browns to effect the rhythms if I connected them together – but for me several of them did nothing when connected.
Blue Verso and Inverso jacks – ditto there, some of them seemed to do nothing no matter how hard I tried with them.
For a while I thought it was me, then I noticed that some jacks responded if I wiggled them juuuust right, or pushed the nana in part way only. So finally I decided to take things apart and have a look.
It is very easy on the PB2 to unscrew all the front screws and then just pop out the front section and PCB from the base to reveal the board in all its glory. If you look at the picture here you can see that the soldering looks fine on the Jack I'm pointing to - Nope, actually there is no electrical connection. The reality is I had at least 8 (yes EIGHT !!) jacks that were not connecting properly thru to the PCB ring around each hole. Presumably a cold or cracked joint?
I pulled out the multimeter and soldering iron and tested every one and resoldered the faulty jacks – it was easy as pie to do. Put it all back together and it works like a dream come true – suddenly things work like I wanted them too.
Motto of the story – if you are having any of the problems I described, or if any of your in's or out's don't seem to respond - then don’t be afraid to pop it open and fix it yourself. I can’t believe how much more fun I’m having now.
:party: :party: :party:
ClausF
Post by ClausF » Mon Oct 17, 2016 2:17 am
Thanks for the report and the pictures, it helps a lot to see the things before opening it. So if I get these problems, I know where to look... :tu: :tu: :tu:
mudlogger
Post by mudlogger » Mon Oct 17, 2016 5:55 am
I had the exact problem happening to me on my Plumbutter V1. I fixed 10 jacks by resoldering them. Mr Blasser doesn't put enough solder on the lugs. I'm told the reason being is so its easier to fault find and unsolder if theirs an issue. I thought it was just on the older models and am surprised its still happening on v2 models. I think it also matters which type of bananas you use. I used Pomonas and they are tighter fitting than others and don't help the issue. All ends well though.
ModusOp
Post by ModusOp » Sun Nov 20, 2016 12:54 pm
Hey Cobramatic, can you please tell me if you had to desolder the connection first?
I'm new to soldering but I have a Gongue whos banana jack is working only about 10% of the time. Hoping to not have to buy a lot of supplies for this, but want it to turn out right. 8-)
Then again, I do have some Easel cards to try to solder, so perhaps I should just get a whole kit. :hmm:
pugix
Post by pugix » Wed Nov 23, 2016 3:53 pm
ModusOp wrote:Hey Cobramatic, can you please tell me if you had to desolder the connection first?
I had to do this on my P.B. 1. All you need is some fresh no-clean solder. Just heat and re-flow with new solder. Read up on soldering electronics first, if you don't have experience. Plenty of discussion here in DIY.
Richard
http://www.pugix.com
ModusOp
Post by ModusOp » Wed Nov 23, 2016 9:26 pm
Thank you for the advice. :) So I don't need the fancy desoldering pump or braid? Cool!! I'll give it a go!
ignacio
Post by ignacio » Thu Nov 24, 2016 10:32 am
Just got a PB2. Hopefully I won't have issues, but if I do, I can refer back to this thread. Thank you for sharing your experience.
ModusOp
Post by ModusOp » Fri Dec 02, 2016 11:13 pm
Worked like a charm. 8-)
At first, I tried to get the solder that was already there flowing, but that must not have sealed the deal. So I added a tiny bit of new solder and that did the trick. :nana: Program cards, here I come!
ClausF
Post by ClausF » Sat Dec 03, 2016 1:56 am
That's also the trick when you desolder things, add a bit of new solder, that makes the old fluid. Good to hear that you did it....have fun! :guinness:
The Goob
Post by The Goob » Mon Dec 05, 2016 8:36 am
Nice! The circuit board layout is even crazy
aux-in
Post by aux-in » Tue Feb 07, 2017 4:39 pm
thanks! I had same issue on an FM input on an avdog. after a little bit of panic, I found this thread. I just fixed it, working perfectly again.
ghrobbing_tristle
Post by ghrobbing_tristle » Sun Apr 02, 2017 8:22 am
This might be better suited to the DIY subforum, but I figured I'd ask here since I'm about to try fixing a faulty jack on my Plumbutter 2 this afternoon. I've watched a few videos on through-hole soldering, but I'm left wondering -- are there are any tips and tricks to reflowing/fixing a joint on a banana jack specifically? The hole is rather massive, and I'm wondering how I can make sure the connection between the bottom of the jack and the board is as good as possible.
Thanks for entertaining these incredibly newbie questions!
pugix
Post by pugix » Mon Apr 03, 2017 6:47 pm
ghrobbing_tristle wrote:This might be better suited to the DIY subforum, but I figured I'd ask here since I'm about to try fixing a faulty jack on my Plumbutter 2 this afternoon. I've watched a few videos on through-hole soldering, but I'm left wondering -- are there are any tips and tricks to reflowing/fixing a joint on a banana jack specifically? The hole is rather massive, and I'm wondering how I can make sure the connection between the bottom of the jack and the board is as good as possible.
There is a surprising lot of details in doing any solder repair, that might catch up a newbie to soldering. I would suggest looking at some basic electronic soldering videos to learn about types of solder, temperatures, tinning the tip, etc.. Then practice on something you can throw away. Once you get the hang of making a good joint, and knowing that you did, then try your repair.
If you don't have time to do that, then here are a few tips.
Use a 700 degree tip, preferably from a temperature controlled soldering iron.
Use no-clean solder. I prefer to use lead based, rosin core solder, but it's harder to find these days.
Tin the tip. Then apply the tip, so that it is touching both the side of the banana jack terminal and the ring on the circuit board. Apply a bit of solder (the right amount is learned by practice) to that point where the tip, the jack, and the PC board all touch. Let it flow, which usually takes no more than 5 seconds. Then remove the iron.
The joint should be shiny. The solder should look smooth.
Be prepared with some solder wick to remove too much solder, if that happens, and then flow again.
Richard
ghrobbing_tristle
Post by ghrobbing_tristle » Fri Apr 07, 2017 11:45 am
pugix -- Thanks so much, and sorry for the slow reply! I tried to fix this jack, but alas, my skills weren't up to the task. I tried reflowing the existing solder a bit, and when that didn't work, I tried adding a bit more to no effect. My hunch is that I added too much, and I'm without the tools to remove it.
It's a bit of a bummer to start with a broken jack like this, but I'm sure I'll be able to get Peter's help.
Thanks again!
mrcharles
Post by mrcharles » Sun Apr 09, 2017 3:49 pm
I think I have a similar problem with one of my gongue jacks.
I assume I will need to remove the knobs before I can open the pb2 - right?
What procedure is recommended? Just pull?
jimmie
Post by jimmie » Mon Apr 10, 2017 6:59 am
no need to remove the knobs. just remove the screws and open the case.
mrcharles
Post by mrcharles » Mon Apr 10, 2017 12:46 pm
Thanks for the answer, jimmie.
I'll have a go at diy repairs...
Oldstench
Post by Oldstench » Tue May 09, 2017 12:42 pm
I had the same problem with mine. Still think some of it is wonky. Probably need to go through it again.
Humanity has doomed itself.
rmro
Post by rmro » Wed Aug 08, 2018 5:48 am
Could someone please explain the process of testing the jacks with a multimeter?
I have one jack I'm planning on re-soldering once I get my skills up to par, but would be interested in knowing the others are all functioning correctly.
Thanks[/quote]
Return to “Ciat-Lonbarde”
