How do you use fixed filters?
I mean filters without CV. I notice some classics like the Moog modular filterbank, Serge resonate EQ, buchla fixed filters. I don't see a lot of these in modern systems. Do you have one? Are there any particular tips or tricks you like to use them for?
- MindMachine
- weekend warrior
Great for isolating certain bands of sound from processed drums, radios, acoustic instruments, etc.
Accentuate certain frequencies when emulating acoustic instruments. Like a clarinet can get raspy when played louder so you wiggle on certain notes of passages. Nice for timpani, etc.
Clean up synth voices. I'll use one instead of a hi pass vcf if I just want to take a little something off of a sound.
That's how I use them. Now that I think about it though, both of mine are resonant. I imagine I would use a classic FFB the same way.
FS: Pedals and Euro modules, Delta Labs, dotcom Q128 for 37.00
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
- Cat-A-Tonic
- Lobsters love Muff
^This (sometimes I wish we had a LIKEMindMachine wrote:Great for isolating certain bands of sound from processed drums, radios, acoustic instruments, etc.
+ tuning feedback loops
Also if you have one with two or more outputs, like the Synthesizers.com one with expander, the big COTK one or the Modcan B one:
* you can create some interesting stereo effects by panning some frequencies left and some right. And I'm guessing it might sound amazing in a quad or 5.1 surround system to take 4 or 5 bands and have them continually rotating to the right while 4 or 5 different bands are continually rotating to the left?!
* create interesting timbre switching/morphing by running different bands of outputs into a sequential switch or multi input panner like the Modcan Scanner or SSL Segwencer
* process some source material that has radically shifting frequency content and patch certain FFB outputs to several envelope followers to trigger events when certain frequencies are predominant
* process different bands through different effects like delays and reverbs for unusual effects.
Actually even with single output FFBs the above is a handy tool to effects processing, just mult your original signal, run the dry signal to a mixer and then with the FFB dial in the frequency content you want to be sent to the effect and run the effect output to the mixer separately. EDIT: like MindMachine already mentioned!
- InnnerSight
- Wiggling with Experience
With the FxDf I like to run the outputs to a sequential switch, then from there to a LPG and a reverb or delay line.
It can sound like pretty little arpegs, or crazy polyrhthymic madness.
When I make perc sounds I really like jamming some white noise into a narrow band, then LPG-ing it.
Of course there is the fun thing of multing a signal, running one side through a filter, inverting it and mixing it with the original to create a nice cut at that freq. Some filters already invert though, so it isn't always necessary to invert it again.
love the way this guy uses the polymoog resonators in this video. saw it years ago and wanted one of these things so bad. finally got one a while ago, the diy one for euro. anyway, i love how he gets sounds like tubas etc from the synth by using the resonators like a formant filter. makes me wonder if there is some info somewhere about what freqs to set fixed res filters to, to kind of emulate some specific things like this (i'm guessing emulating brass is prob where it works best).
cant figure out how to embed video! anyway, i'm sure prob a lot of ppl at MW have seen this..
- Common Wiggler
Another vote for the Serge Resonant EQ. I can lose myself for hours tweaking that, particularly with external signals.AlanP wrote:The Serge Resonant EQ is fun to just patch white noise into one input, feed the output back into the second input, and play with the sliders and input attenuators.
We're all sort of conditioned to want Voltage Controlled Everything, but experimenting with a good-quality static filter bank is an almost Zen experience
- FetidEye
- demonic space drone
- Contact:
mostly I resonate sounds with them (Serge EQ and Resonator)
input = some small tick or low repeating pattern. I boost certain bands and use feedback and suddenly it becomes an organic (or very industrial mechanical) sound.
Then I modulate the original source and it gets even more fun!
Or distort drum / persussive sounds (feedback on the Serge is very nice)
