ES-1 query
Moderators: Kent, os
bleeps
Post by bleeps » Wed May 26, 2010 2:46 pm
Much greater output voltage range - up to 9x more than directly connecting a DC-coupled interface via a 'floating ring' cable.
Would a DC coupled interface also get this increased range if connected via the ES-1? (it's implied but I want to know for sure)
Post by os » Wed May 26, 2010 2:56 pm
Yes, that 9x is specifically referring to DC-coupled operation.
The gain of the ES-1's amplifier is 4.5x. The extra factor of 2x comes from the balanced input stage, and only applies if your audio interface has differential balanced outputs.
bleeps
Post by bleeps » Wed May 26, 2010 4:02 pm
Ah, I see. Thanks! And good idea to take it out of that pre-order thread, I wasn't thinking when I posted in there. :oops:
criticalmonkey
Post by criticalmonkey » Thu May 27, 2010 12:02 am
follow up on this
would it only get the positive voltage and need an offset or would it gain for both positive and negative voltages
or am i missing something
Post by os » Thu May 27, 2010 3:33 am
When used as a DC-coupled amplifier, the ES-1 works for both positive and negative voltages.
seychmar
Post by seychmar » Mon Nov 08, 2010 12:14 pm
os wrote:Yes, that 9x is specifically referring to DC-coupled operation.
Do all MOTU interfaces have differential balanced outputs? The Expert Sleepers website only makes specific reference to the Ultralite series. Is this also the case for the 828?
Post by os » Mon Nov 08, 2010 12:30 pm
I'm pretty sure it does, yes.
Someone else on this forum must actually own an 828 though and will be able to confirm.
franzschuier
fart box afficinado
Post by franzschuier » Mon Nov 08, 2010 5:47 pm
I had a 828 Mk2 and it was DC Coupled. Worked like a charm with silent way.
shacksman
Post by shacksman » Tue Nov 09, 2010 9:49 am
get one there awsome 8_)
Return to “Expert Sleepers”
