ModyPoly Polyvhords not working
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
tubbutec
Post by tubbutec » Fri Dec 02, 2016 2:56 am
Hi i just install the modypoly in my monopoly
And everything works exept the polychords mode
Only the first osc is working
But the normal chord mode works fine
Any idea?
Hi,
have not heard of this problem before. I would like to make sure that
you are using the Polychord mode correctly:
- Play a chord
- while it is playing press POLY+CHORD
- Poly will start blinking
- Now press the key you want the chord assigned to
- Switch into Polychord mode by pressing Poly+Chord when no key is pressed
If that is what you are doing and still have this issue, please get back
to me
No i was not using it correctly
Return to “Tubbutec”
