Sidrax problems/fault?
home of post-70s electronics
Moderators: Kent, bartlebooth
Jamesf1
Post by Jamesf1 » Mon Dec 05, 2016 4:58 pm
Hi,
Recently ordered a Sidrax. However there seems to be a strange problem with it.
When I press a bar I can hear the note played in the left speaker and when I release the bar I hear it in the right - all good so far.
However directly after releasing the bar there is a short pause and the note previouly played comes back up usually at a reduced volume on the left speaker and gradually fades away - but after releasing the bar I have not touched anything further -weird.
Has anyone else experienced anything like this - any solutions as it is getting very frustrating.
Also this behaviour seems to be kind of random and sometimes the Sid works as expected and other times not.
Cheers.
bartlebooth
Post by bartlebooth » Mon Dec 05, 2016 11:40 pm
try adjusting the screws associated with the offending bar..the piezos are very sensitive so will pick up any movement in the bar until it settles back to rest.if the bar is still jiggling around it can manifest as unwanted sound/noise
sungja
Post by sungja » Tue Dec 06, 2016 6:21 am
I had the same problem with my old sidrassi. Had to change the piezo and removing the broken one was not easy. I would send it back to Peter and have him do it.
Jamesf1
Post by Jamesf1 » Tue Dec 06, 2016 2:24 pm
Thanks for the suggestions and much appreciated.
I tightened the screws on the bars but the instrument still behaves in the same way.
It is not one single bar that is causing the problem but they all seem to do it intermittently. Press the bar and release it - volume envelope behaves as expected but after you think the sound has stopped the volume then comes back up and dies away by itself.
Really strange and I previously had a Sidrazzi and it seemed to work just fine. I guess I will have to go back to Peter.
Cheers.
shortsleeves
Post by shortsleeves » Tue Dec 06, 2016 3:41 pm
One of the bars in my Tetrax behaves similarly, but not at all times. The rest seem to act that way from time to time only. I'm pretty sure it has to do with the natural reaction of wood to being pressed. Perhaps the bars are too dry/moist? Haven't found the way to eliminate it entirely, but I pretty much know when it's possible it will happen – mostly with slow and heavy pressure.
Lukasz
Jamesf1
Post by Jamesf1 » Tue Dec 06, 2016 4:54 pm
Thanks Lukasz that is very helpful and interesting to hear that it is not just my Sid behaving in this way. Perhaps you are right and it is something to do with how dry the wood is. Given the time of year I have had the radiators on and maybe the artificial heat has dried the wood out so it is not flexing as it should.
I think I will give the bars a good coat of oil over the weekend the weekend and see if that improves matters before I contact Peter.
Cheers.
wednesdayayay
Post by wednesdayayay » Tue Dec 06, 2016 6:49 pm
I don't remember where but I believe someone else was having a similar issue and it had to do with excess moisture
don't take my word though
sh is the sound of data
bobo is the gesture
PB
Hainbach
Post by Hainbach » Fri Dec 09, 2016 1:10 am
I have the same sometimes, mostly after pressing hard on the bar, so you get that popping sound.
Jamesf1
Post by Jamesf1 » Fri Dec 09, 2016 6:28 pm
Thanks for the replies and reassuring to know it's not just my unit.
I have found that turning the heater down in the room has helped - so I guess it's something to do with the climate/moisture in the air. Also after playing for about 5 or 10 minutes the response of the bars seems to greatly improve and operate as you would expect.
I suppose that it is one of the draw backs when your synth is mostly comprised of wood.
waxdoctor
Post by waxdoctor » Sat Sep 14, 2019 11:52 am
hi - I know this thread is an old one but I need to ask following:
bought a beautiful sidrax and love it - but is it normal that only my 6th bar(2nd from right) sounds left when touching it and right when releasing it?
all other bars are right/left (touch/release)...
thanks!
Ras Thavas
Post by Ras Thavas » Sat Sep 14, 2019 12:39 pm
waxdoctor wrote:hi - I know this thread is an old one but I need to ask following:
thanks!
I have one note that does that too, and remember reading that wasn't unusual. Interestingly, if memory serves, I think the user even tried swapping the leads to the pressure piezo and that didn't invert the stereo function.
Hopefully someone with a little more data can chime in, I can see where someone would not want one note standing out as different. Even better would be tiny toggles that allowed you to set the direction, so you could set notes to alternate in the stereo field.
waxdoctor
Post by waxdoctor » Mon Sep 16, 2019 11:07 am
thanks!
great - thank you for confirming :) somehow i like it that it behaves differently... :) but the tiny toggles - wow - that would be nice...
merlatte
Post by merlatte » Tue Sep 17, 2019 7:39 am
thanks!
I have a Quatrax that has two of the fourteen barres reversed like this. In an email, Peter said he wired the piezos in randomly and that the wires could be switched to make them uniform (or even more random, I'd suppose).
BergotMusic
Post by BergotMusic » Wed Sep 18, 2019 2:09 pm
thanks!
My tetrax also has one bar where the stereo signal is inverted from the others, (also the second from right)
I was always curious about other CL organs and how these were set up. I think it's great when patching while making bars collide with each other and getting something different from this one in particular. It's my favorite of all four!
Return to “Ciat-Lonbarde”
