SH 101 - behaving strangely with MIDI from a DAW only (????)
MUFF WIGGLER Forum Index -> Tubbutec
Author SH 101 - behaving strangely with MIDI from a DAW only (????)
wavetable808
Hi, just had the 101 mod installed and I'm encountering a strange and frustrating problem.
When I trigger the 101 via MIDI from an external keyboard it works perfectly but if I send it MIDI from my DAW (Logic) it doesn't work properly. It sounds like the notes are triggering multiple times as if there is an ARP or LFO triggering something.
It's not related to any setting on the 101 - I've been through them all while receiving MIDI from Logic.
Totally stuck on this one - any help greatly appreciated.
tubbutec
Hi,
when this happens do you only use one midi connection (from logic to the sh-1oh1) or also midi out from the sh-1oh1 to logic?
If you use both you might have created a midi loop..
Also see this topic:
https://www.muffwiggler.com/forum/viewtopic.php?t=172500
wavetable808
Hi, definitely only MIDI in to the 101 so no chance of a loop.
I've also been through the MIDI data and "cleaned" it in case it's something else. So confusing.
wavetable808
I made this quick video showing it receiving some MIDI from Logic to give an idea of the kind of sound it is making.
https://www.youtube.com/watch?v=nYmBOxFDvt8
tubbutec
Hi,
can you use the firmware updater utility:
https://tubbutec.de/tubbutec-firmware-updater/
to check your firmware version ?
there was an issue with MTC quarter frames before version 1.04
