Author |
Musi-Analog-Modular-Synth Frac????? |
br>Tubeampguy |
br>e-grad |
br>Probably a DIYer who puts his own monicker on his panels. My own panels read 'e-grad' at the bottom and for example 'Ken Stone CGS85 / Tube VCA/Dist.' at the top. br> br> |
br>BugBrand |
br>Looks kind of cool.
Though whoever built it doesn't know how to use Tyco MTA connectors correctly. br> br> |
br>fluxmonkey |
br>i likes it. alot. the MTA arrangement is odd, but i appreciate how it minimizes the depth. one of my only complaints about the format is the deep frames, especially for gigging. br> br> |
br>Kent |
br> fluxmonkey wrote: | ...one of my only complaints about the format is the deep frames, especially for gigging. |
This was my primary reason for abandoning the format. br> br> |
br>BugBrand |
br> fluxmonkey wrote: | i likes it. alot. the MTA arrangement is odd, but i appreciate how it minimizes the depth. one of my only complaints about the format is the deep frames, especially for gigging. |
Oh yeah, I meant the cable plugs rather than the board sockets.. soldered rather than IDC insertion (and random usage of plug colours - different colours are meant to be for different wire gauges)
Yes, regular Frac depth is poopy - hence why I DIY'd down to 4" first and then onwards to 2.3". Those modules would fit into one of my frames! br> br> |
br>e-grad |
br> BugBrand wrote: | Yes, regular Frac depth is poopy [...] |
Keep in mind Blacet even suggests to mount the Frac racks into an even deeper SKB rack.
Quote: | All modules these days are designed to be placed in a sub mounting system that is 19" rack compatible. That means that you can place a mixture of module systems in a box such as those made by SKB. |
http://blacet.com/FAQ.html br> br> |
br>fracmonkey |
br>Yes, these skb racks are way too deep for even Blacet. Must be better alternatives these days. I'd consider just basic homemade wood boxes. br> br> |
br>Tubeampguy |
br> fracmonkey wrote: | Yes, these skb racks are way too deep for even Blacet. Must be better alternatives these days. I'd consider just basic homemade wood boxes.  |
I rack all my RAK-2's in these
There very shallow (12 3/8" rack depth) but still stackable and portable (if you don't fly to gigs) That's why I keep them 6U instead of one large rack case. br> br> |
br>fluxmonkey |
