SSL 1230 - Fader VC ADSR - Low output
Discussion and support for Synthetic Sound Labs modules and devices.
Moderators: Kent, dslocum
sonicwarrior
Post by sonicwarrior » Mon Jan 09, 2017 5:02 pm
I have two Rev 1.2 VC ADSRs and both only output +4 V on normal mode and +2.5 - 2.7 on the two LFO modes.
The website says it should output +5 V.
They have four trimmers on board:
Can I adjust the output with any of those?
Soundcloud
For sale: Jürgen Haible Tau Phaser (MOTM format)
sonicwarrior
Re: SSL 1230 - Fader VC ADSR - Low output
Post by sonicwarrior » Fri Jan 27, 2017 3:58 am
Got an answer from Doug:
Again sorry for the delay. I wanted to be sure of the problem and I was correct. The LED is drawing down the output, and since the LED is also (indirectly) tied to the output of the module, the output will also be low.
The LED has a 220 ohm resistor that makes it pretty bright. I tried a 2.2K (2K2) resistor and the LED brightness was reduced but still (IMHO) acceptable. The module output can now go to about 4.7v. Only by removing the LED from the circuit can the output go to a full 5v in the present design. There’s no simple fix for this, unfortunately. Both me and Tom (the original designer) failed to catch this, and you are the first to notice.
I’ll update the specs on the web page to reflect this, but I’m afraid that there’s nothing that I can do with the circuit the way it is. I’d be happy to replace or remove the LED resistor for you but it’s the best solution I can offer at the moment.
4,7 V sounds acceptable to me so I'll try to replace the resistors myself.
Soundcloud
dslocum
darwin's nemesis
Post by dslocum » Sat Jan 28, 2017 4:07 pm
FYI - You can get about 4.7v if you reduce the brightness of the LED - still reasonably bright, IMHO. Just replace the existing 220 ohm resistor with a 2K2 (2200 ohm) 0805 size resistor.
The resistor on the 1230 VC ADSR is "R20". It's right next to the metal crystal near the CPU.
This will also affect the 1235 Envelope / VCA. The resistor number is "R220" which is near "U4".
I'll be sure this doesn't happen on future products. Sorry folks!
Doug Slocum
www.steamsynth.com
"I guess all the Forest Mims Radio Shack books I read finally paid off!"
"I ordered twice as many _______ as I thought I'd need, only to find out that I'm still less than half way to having enough."
"...this whole thing was started by a dream and a mouse." - Walt Disney
"Flatulence sounds aren't just for brass and reed instruments anymore, thanks in large part to Dr Moog." - Ockeghem
Return to “Synthetic Sound Labs”
