Kenton Pro 2000 mkII
chamomileshark
Post by chamomileshark » Tue Jan 10, 2017 2:25 pm
hi, I'm thinking of using the aux CV outs from a Kenton Pro 2000 MkII to control things like VCAs (to add velocity or aftertouch response) and VCFs of the Blacet/ Bananalogue and MOTM frac modules.
The kenton manual says the voltages are +/- 12.6 volts - is that ok to connect? I'm only using the 5V pull up for the gate so I'm concerned those voltages are too high.
Key Gear: Wiard 300 Series, EMS VCS3, Frac Modular (Blacet, Wiard, Bananalogue & Synthesis Technology).
Website: http://inspiringsounds.com
a bunch of stuff
http://markgriffiths.bandcamp.com/
http://www.soundclick.com/markgriffiths
Kyhotay
Post by Kyhotay » Sun Jan 22, 2017 2:00 pm
I don't know the answer but you could run the CV out of the Kenton into an attenuator or mixer and start with a lower voltage into the VCF and VCA.
I recall in the manual for the PAiA 09700 MIDI>CV Converter that recommend an attenuation network to scale the output CV for the pitch wheel output. In that case the purpose is to scale it more to the range of voltages one would expect from a pitch wheel, not a theremin!
Brian Folkes
Heavy into Fracing...
https://soundcloud.com/brian-folkes
Spivkurl
Post by Spivkurl » Tue May 08, 2018 5:58 am
I have been using my Kenton (same one as you) to interface the frac setup with my MPC 4000. Everything seems to be working as expected.
So far, I have just used the "aux" for key tracking. Since the min/max range can be adjusted, it seems like external attenuation should not be necessary.
Klangzaun
Post by Klangzaun » Tue May 08, 2018 6:19 am
I am using a MPC live with the Kenton Pro 2000 mkII to control my modular gear.
You can set up a range from -64 up to + 64. I remember the manual says to set min to -25 and max to 0 to get +5V.
However I never cared about this and it works perfectly anyhow...
Cables For Clouds
Post by Cables For Clouds » Wed Jun 20, 2018 12:09 pm
cools
cslammy
Re: Kenton Pro 2000 mkII
Post by cslammy » Wed Dec 19, 2018 10:43 am
chamomileshark wrote:hi, I'm thinking of using the aux CV outs from a Kenton Pro 2000 MkII to control things like VCAs (to add velocity or aftertouch response) and VCFs of the Blacet/ Bananalogue and MOTM frac modules.
Hi Chamo: I have one of these Kentons as well and have never had an issue with CV. The output CV is adjustable but I thought (?) default was 0 to 5V which works for me.
cslammy
Return to “Fractional Rack Modules”
