Intellijel Quad VCA
Carmelo_P82
Post by Carmelo_P82 » Mon Apr 02, 2018 3:04 am
Hi folks,
I have the Quad VCA and I love it even I'm still learning. I wanted to know if this is a normal situation :
Using it as 4 Independent VCAs
IN1
1. I connect the output signal from my Mangrove to IN 1
2. Connect the OUT 1 to my Audio Interface
3. I connect a modulating signal to CV 1 . The modulating signal comes from the envelope of the Quadra trigged by Yarns
No worries I can hear the sound from OUT 1
IN2
1. I connect the output signal from my Iteritas to IN 2
2. Connect the OUT 2 to another canal of my Audio Interface
3. I connect a modulating signal to CV 2 . The modulating signal comes from another envelope of the Quadra trigged by Yarns
I can't hear the OUT1 and OUT2 separately but I can hear the OUT 2 (3 or 4) if nothing is connected to OUT1. Is it a normal situation ?
I can do that only in Cascaded Mixing ?
Thank you for the help / answer :tu:
Altair
Post by Altair » Mon Apr 02, 2018 6:29 pm
Looks like some good feedback on this module here. I guess that cements as being one of the first I'm going to buy.
Altair
Also, Hello MuffWiggler! :miley:
Carmelo_P82
Post by Carmelo_P82 » Tue Apr 03, 2018 2:54 am
Carmelo_P82 wrote:Hi folks,
IN1
IN2
Resolved :)
Carmelo_P82
Post by Carmelo_P82 » Tue Apr 03, 2018 2:55 am
Altair wrote:Looks like some good feedback on this module here. I guess that cements as being one of the first I'm going to buy.
Yes it is :sb:
Funkydroid
Post by Funkydroid » Tue Apr 03, 2018 7:27 am
Yeah this is a badbwoy module. Feeding channels into each other and adding voltage to cv= fat sounds with beautiful and complex softclipping that doesn't just "squarewave" your sounds on sample level, although hardclipping does have it's uses it still sounds like an arse when 20+ samples are continuously clipped.
Dicky
Post by Dicky » Thu Apr 05, 2018 5:28 am
Is it DC-coupled? Can’t see it noted anywhere
uniquepersonno2
Post by uniquepersonno2 » Thu Apr 05, 2018 11:42 am
Dicky wrote:Is it DC-coupled? Can’t see it noted anywhere
Just tested it on mine, yes it is.
Dicky
Post by Dicky » Thu Apr 05, 2018 12:26 pm
Nice, thanks! I’m sold
Arcana
Post by Arcana » Thu Apr 05, 2018 7:04 pm
Anyone compare the Linix and the Quad VCA?
Post by exper » Thu Apr 05, 2018 7:52 pm
Arcana wrote:Anyone compare the Linix and the Quad VCA?
i migrated from the Linix to the Quad VCA mainly because I missed the sweepable response of the uVCA. Plus the added boost sounds great. Haven’t regretted the swap at all.
Current system:
http://www.modulargrid.net/e/racks/view/5549
________________________________________
FS/T: Various Euro:
https://www.muffwiggler.com/forum/viewt ... p?t=221800
eyeiaye
Post by eyeiaye » Thu Apr 05, 2018 9:04 pm
I have to say the best quad VCA out there is the Tangle Quartet!
HOLY CRAP
Ive owned them all and this is the BEST!!!!!
cptnal
Post by cptnal » Fri Apr 06, 2018 2:28 am
eyeiaye wrote:I have to say the best quad VCA out there is the Tangle Quartet!
HOLY CRAP
Does what it says on the tin. :tu:
CaneMan
Post by CaneMan » Tue Apr 17, 2018 4:29 pm
After reading all these posts on the Intellijel Quad VCA, I went off to order one. It seems to be out of stock in all the US shops I've checked. Has anyone seen it in stock anywhere?
Post by exper » Tue Apr 17, 2018 5:13 pm
CaneMan wrote:After reading all these posts on the Intellijel Quad VCA, I went off to order one. It seems to be out of stock in all the US shops I've checked. Has anyone seen it in stock anywhere?
Looks like they should be re-stocked very soon. You could always order direct as well. Shipment is fast from Canada.
Current system:
FS/T: Various Euro:
CaneMan
Post by CaneMan » Tue Apr 17, 2018 5:26 pm
:doh: Didn't even check to see if they sold direct. Time to get those VCA's.
cephalicarnage
Post by cephalicarnage » Wed Apr 18, 2018 11:13 am
I've just bought my second Quad VCA and now I can BOOST EVERYTHING!!! :deadbanana:
Rafi
Post by Rafi » Mon Jul 23, 2018 11:22 am
Solid move cephalicarnage
:yay:
ecstaticquiet
Post by ecstaticquiet » Wed Jul 25, 2018 1:44 am
IN1
IN2
Resolved :)
What was the solution? I'm having the same issue! I feel like the solution is a simple one....
medium Rob
Post by medium Rob » Mon Oct 08, 2018 4:56 pm
apologies for my n00bness... i don't understand how the linear / exponential response works yet. my first test last night, using only audio (no CV) - i can't hear any signal unless the lin / exp knob is turned fully CW (linear) - the volume knob only seemed to work when the lin / exp knob was at full CW (linear) position.. is this normal?
medium Rob
Post by medium Rob » Tue Oct 09, 2018 2:34 am
Anyone care to share a thought?
hawkfuzz
Post by hawkfuzz » Tue Oct 09, 2018 6:35 am
Follow the demo and I'm sure you'll figure it out. Sounds like you need to plug a cv source into the cv jack to open the vca.
JakoGreyshire
Post by JakoGreyshire » Wed Oct 10, 2018 1:47 am
Good job HawkFuzz! I was just thinking that those two videos needed to be embeded here for posterity... You beat me to it..
:yay: :yay:
Maybe this one should be here too, because it shows the Intellijel uVCA II and explains a lot about VCAs with Bias knobs at around 3:40 minutes or so...... Noobs should watch the whole video, and the other two videos that are part of this one.. He talks about LIN and EXP in this video too..
I'm sure most people have seen these videos already... Once again I'm embeding this here for posterity.... I wish Frank Murder would do more videos...
:tu: :tu: :tu:
(P.S. We were all noobs at one point.. No apologies needed)
My YouTuBe Page...
The patch you've created in your brain is more challenging to modify than the patch you have on your modular.
Dogma
Post by Dogma » Wed Oct 10, 2018 12:59 pm
I wish there was a way to connect a couple of mixups to the Quad VCA - im about to grab 3 mixups and the quad VCA to replace a WMD PM (along with 2 x Frapp321 and a Frapp 333)
Really like the simplicity/quality.function of these intelliel modules
look up!
oinkbanana
Post by oinkbanana » Wed Oct 10, 2018 9:34 pm
came across this quote from the hexVCA thread back in 2011
intellijel wrote:A full featured VCA would have both attenuators and offset and a variable control to adjust between linear and expo response.
really glad you finally got around to making the best VCA
what would it take to make the continuous shape function Log-Lin-expo?
