Juno-66: turn off midi out channel
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
alalal
MIDI double trigger as controller
Post by alalal » Wed Jan 18, 2017 6:49 am
Hi
I wish to use Juno as a cntoller.
At present it is double triggering.
I press Key transpose until it flashes
Then I press the C# for MIDI as played
I then press Key transpose to turn off the light.
Its still double triggering!
Am I missing something?
tubbutec
Post by tubbutec » Sat Jan 21, 2017 3:09 am
Yes you are. After pressing C# you must select the midi channel from the lowest 17 notes. The lowest note turns off the channel.
Return to “Tubbutec”
