LP-1 hold and record mode?
Support and discussion for soundmachines products.
Moderators: Kent, soundmachines
R.U.Nuts
Post by R.U.Nuts » Fri Jan 27, 2017 8:20 pm
A quick question about the LP-1 which I couldn't answer myself by reading the manual: Is recording possible while hold mode is engaged? I hope so. I'm planning to buy a LP-1 but if the answer to my question is "no" this would be a dealbreaker for me...
soundmachines
Post by soundmachines » Sat Feb 11, 2017 4:22 am
Hi there!
Not sure what you mean.
In HOLD mode the LP1 'keeps' the X and Y outputs locked to the last vaild 'touch point'.
Please let me know what is your need in terms of behaviour I may check it out better!
Davide
soundmachines
we play synthesizers !
www.sound-machines.it
R.U.Nuts
Post by R.U.Nuts » Sat Feb 11, 2017 6:14 am
Hi there! I mean is it possible to record while hold mode is engaged?
solaris
Location: ̋͋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̋̏̏ ̏ ˳̊̊̊̊̊ ˳̥̥̥̥̥̊̊̊̊̊̊̊˳̥˯Ξ̿̿̿̿̿̿̿̿̿̿▂ ̋̋̋̋̋̋̋̋̋̋
Post by solaris » Sat Feb 11, 2017 6:37 am
R.U.Nuts wrote:Hi there! I mean is it possible to record while hold mode is engaged?
no.
but you could "fake" hold mode by engaging rec mode for a fraction of a second without moving your finger - this way the value will be recorded and hold indefinitely. then, you could re-engage rec mode from there, moving your finger and recording the movement.
but then, coming out from rec mode will "reset" the value and it will come back to zero, not to the previously recorded ("hold") state.
▂̵̶̵̥̤̳̤̇̈̄̅̈□ □ □ □ □ □ □ □ □ t r a n s f e k t i o n ▔▔▔▔╲▂▂▁▂▂̵̶̵̥̤̳̤̇̈̄̅̈▂▁▁
▂̵̶̵̥̤̳̤̇̈̄̅̈□ □ ▂̵̶̵̥̤̳̤̇̈̄̅̈▂̵̶̵̥̤̳̤̇̈̄̅̈▂̵̶̵̥̤̳̤̇̈̄̅̈□ ▂̵̶̵̥̤̳̤̇̈̄̅̈▔╲▂̥̥̊̊̊̊▂ ‬::.:::.h++p://z.x-xx---x.info □ □ □ □ □ □ □ □ □‬
soundmachines
Post by soundmachines » Sun Feb 12, 2017 4:55 am
Solaris is right (thanks!) but still can't understand what would be the scenario that RUNuts is asking for.
Maybe you would like to record something while the output is not "moving" until you finish the recording phase? A kind of 'muted recording' or 'cued recording' ???
Dav
soundmachines
R.U.Nuts
Post by R.U.Nuts » Sun Feb 12, 2017 8:55 am
soundmachines wrote:Solaris is right (thanks!) but still can't understand what would be the scenario that RUNuts is asking for.
Dav
As I understand if not in hold mode the voltage of the outputs will drop back to zero once I don't touch the LP1. So if I have the LP1 gate output trigger an Envelope of say a VCA that is set to a long release time and the LP1 CV out to an oscillator's pitch input and this VCO runs through said VCA you would hear the VCO's pitch drop while I don't touch the LP1 and the gate is low and the envelope in it's release phase.
But I could fix that with a track and hold module I guess.
Return to “soundmachines”
