3x VCA by Happy Nerding
MUFF WIGGLER Forum Index -> Eurorack Modules Goto page 1, 2, 3, 4  Next [all]
Author 3x VCA by Happy Nerding
igorrr
The 3x VCA offers three high class amplifier circuits with linear characteristic. Thanks to AC / DC compatibility, a very low noise floor and basically no distortion, the module is not only a great partner for control voltages, but audio material as well.
The dual potentiometers regulate initial levels and bipolar CV attenuation values of all amplifiers. Using these rather unusual, yet very practical components, it was possible to equip the 3x VCA with a front panel that is only 6 HP wide. Switches allow the user to feed the results of one amplifier into the output of the next, so we can get 1+2, 2+3, and 1+2+3 outputs mix. Two-colored LEDs visualize CV and output signals.
• 60 mA +12V
• 60 mA -12V
150 USD, 133 Euro (159 Euro with VAT).
http://www.analoguehaven.com/happynerding/3xvca/
http://www.schneidersladen.de/en/happy-nerding-3xvca.html
https://www.schneidersladen.de/en/happy-nerding-3xvca-black.html
https://escapefromnoise.com/modular/happy-nerding-3xvca/
http://www.midiamsterdam.nl/happy-nerding-3xvca.html
https://www.signalsounds.com/happy-nerding-3xvca-eurorack-vca-module
https://www.signalsounds.com/happy-nerding-3xvca-eurorack-vca-module-b lack
https://www.modulargrid.net/e/happy-nerding-3x-vca
This module is great partner to our 3xMIA.
https://www.muffwiggler.com/forum/viewtopic.php?t=162109&postdays=0&po storder=asc&start=0
Plumbstone
Loving your super compact designs. Will Schneiders be restocking the 3xMIA at the same time? I would love to pick up one of each.
Electrostatic
Damn.
Triple bi-polar vca in 6hp, without being stupidly cramped...
I'm in.
uncleyam
this is amazing, might get 2 of these instead of veils / blinds
Looks sweet, Igorrr, and clever/efficient reuse of an existing design! thumbs up
autopoiesis
go go go! the dual concentric pots on the 3xmia are great. can this do attenuversion + offset addition per channel (eg leave the IN jack unpatched, patch some CV into the CV input, offset with the base knob and attenuvert with the top knob)?
Coetillion
are you just trying to offset + attenuvert your cv? you would just plug your cv into the in jack for that
autopoiesis
it depends on how the inputs are normalled to internal voltage, no? on Blinds and TBVCA you need to patch as I described to attenuvert + add offset to a signal.
joskery
Does this actually amplify things – that is, can this be used as an input module for line level signals?
jwm
nice. any ETA in the US?
mopoco
really clever user interface!
same goes for the price... applause
igorrr
3xVCA and 3xMIA should arrive to Schneiders Laden end of this week or so. Regarding availability in US – I can not name the date yet, as 3xMIAs should come first.
Line level signals can not be usefully amplified, sorry. It is made on purpose to avoid clipping. Because at CW position of the smaller knob standard modular signal will become x1 (-5V…+5V) and CV can amplify it further, so it will be x1+xCV. And three blocks can be summed, so if there was much amplification – it would clip all the way.
The module does not invert the signal by it own means. Otherwise it would not be named VCA. Imagine we have some audio source we want to “duck” or “pump”. We connect it to “in” jack, turn smaller knob to the desired initial level, and then use “CV in” and CCW rotation of the bigger knob to make this audio signal quieter in response to our CV. In case of four-quadrant multiplier our audio would not become quieter, but get inverted. The user can use 3xMIA to invert (and offset) the CV, then this inverted CV when plugged to “CV in” of 3xVCA will invert the signal connected to “in” jack.
nikvudu
oof, very nice design. i may well replace my current vca with this.
ben_hex
Great RE purposing / redesign of the MIA. The MIA is great to work with so I'm expecting this will be too.
igorrr
3xVCAs arrived to Schneiders Laden
joskery
Got both the MIA and VCA from Schneider's. Waiting anxiously!
MvK
in the description:
"Switches allow the user to feed the results of one amplifier into the next."
so its not summing the outputs of the 3 VCAs like some multi VCAs do?
joskery
Not by default - that's what the switches do.
autopoiesis
got it, so the VCA isn't bipolar, but there's an attenuverter on the CV input. looking forward to getting one!
igorrr
MvK wrote:
in the description:
The outputs are summed together, so we can get 1+2, 2+3, and 1+2+3 outputs mix.
Will correct description from my side
Positive Modular Attitude
I - LOVE - THIS - MODULE.
End of transmission.
hawkfuzz
Refreshing Analogue Haven frequently. Debated buying some from across the pond, but I'll wait.
igorrr
In case it is important for some users: 3xVCA has onboard power regulators, so is quite immune to bad power supplies.
thumbs up SlayerBadger!
ben_hex
as everything should have! smile Just been playing around with mine tonight and it's working great. Love the format from the 3xMIA I've had for a short while too.
Page 1 of 4
