(obviously not looking for anything as complex as the Rutt Etra)
Moderators: Kent, luketeaford, Joe., daverj
darenager wrote:I wonder how many people with Maths don't know it can file a tax return, or that Plague Bearer can indeed give bears the plague
suitandtieguy wrote:STG IS ALL ABOUT THE PLUR.
These modules have much higher parts count and cost per chip than the average audio modules, but I am trying to keep the cost as low as absolutely possible because I want to get these modules out there.I'll let him chime in if he wants to say how much
With upcoming Vector-to-Raster conversion modules, this type of synthesis is achievable, as well as scanimate type stuff, etc.complex as the Rutt Etra
I think you mean the MFB VD-01.laserpalace wrote:Analogue Solutions VD-01
As far as analog circuits go, we've definitely talked about some video specific VCFs for video texturizing purposes. There is a module in the works for audiovisualization specifically, which includes envelope followers with adjustable decay to control the smoothness of the modulation. You could try using your EuroRack VCFs but those may blur the image more than you'd like, even at higher settings. Still could be some fun, there -- using the Triple Video Fader & Key Generator module to fade back and forth between blurred and non-blurred images.Will there be any kind of slew, or smoothing agent in the LZX modules?
There will be a Vector-to-Raster conversion module, that's all you need -- X, Y & Z inputs. This will run at full composite video resolution.How about a high res. oscilloscope module in the LZX line?
I wanted to comment on this, since it calls into question the history of the LZX project and I don't want anyone to be confused. I got into Synth DIY a few years ago primarily because I was frustrated by the lack of tools for working with analog video processing/synthesis. I have a B.A. in Film and am interested in using experimental technologies for filmmaking, and there seemed to be a lot of unexplored territory from the days of 70's video art.When Lars contacted me a year and a half ago asking me how to build a video synth
This isn't entirely true -- there are some fundamental differences between the two different standards which complement different patching workflows and philosophies. I don't believe either method is "better", they are just different and will lend themselves to different approaches, and the world will be better for having both!!Because of that when he decided to make commercial modules he ended up using voltages that aren't the same as mine.
no, not at all. this make for fascinating reading as far as i'm concerned. i come from the music side and have very little knowledge of video systems. like most people here, i guess. please continue to educate me/us ....daverj wrote: (sorry about another long post to read)
like your avatar too. i can almost hear him scream: 'KRUPA, KRUPA'Animal wrote: As well, I will mention that Laserpalace's avatar is magnificently imperious and godlike; threatening yet strangely narcotic.![]()
I like it.
Back when I was changing pots on a regular schedule because pot noise was getting into the video, we only had black and white cameras at the TV Center. Of course the pots were being turned all day every day, so did get a lot of use. Time will tell. Also the quality and composition of the pots will affect their life.creatorlars wrote:On VCAs -- It's worth noting that the Triple Colorspace signals without the chroma subcarrier are much less susceptible to pot noise than Composite Color.
Very true. Having VCAs for every attenuator does increase the cost and size of the circuits. A definite drawback. But since most users aren't DIY folks, it can reduce how often they have to send modules in for pot replacement. A number of my video devices have been in daily use for 25 years (some for 35 years), so I've seen a lot of pots get replaced.creatorlars wrote:It also came down to cost -- with triple modules, that's a lot of VCAs!
I'm also using wideband low noise video amps and quality components, along with high frequency design and layout techniques. I also had my mini-jacks customized during manufacturing to double their life, as well as using pots with 5 times the normal life of the pots used on most Euro modules.creatorlars wrote:Our inputs are buffered with wideband video op-amps right as they enter the module, before the attenuverter, and quality components are used throughout.
The problem with specialized subforums is that a lot of people with a casual interest tend to not go into them. On the other hand there are maybe some people interested in video who haven't seen this thread because they don't use Euro. Like everything, there's reasons for it and against it.creatorlars wrote:Maybe it's close to time to start a Video Synthesis subforum...?
I forgot to comment on this in the previous post.creatorlars wrote:There are some drawbacks to the Jones stereo jack solution, although it's quite genius! For example, you can't mult a video signal, you still need a conversion module to run video out through non-video modules (or LZX modules), and you can't use stacking cables. The ease of use, however, of patching straight in, instead of through a conversion module is huge. But it's all gonna mean different things to different people, depending on their systems.
