sinusoidal wavefolder
MUFF WIGGLER Forum Index -> Music Tech DIY Goto page 1, 2, 3, 4, 5  Next [all]
Author sinusoidal wavefolder
guest
i put together that barrie gilbert sine-shaper circuit i had discovered while researching for the OTA sine wave shaper paper:
it works as expected, but still needs some tweaking. its pretty fun, but has some glitches at deeper modulation (faster opamps might fix this). it goes about +/-550 degrees before the sine distortion gets bad, and +/-650 before it totally distorts and loses sine shape altogether. in the middle range, it can keep all harmonics below -60dB.
there are two ways to modulate with it. if you modulate the amplitude of the signal going in, it acts like a normal wavefolder, except the output is sinusoid, rather than a ramp wave. if you add an offset to the input, you are phase modulating. i will see about getting some videos up.
guest
and here is the transfer function:
it looks more like +/-720 degrees before distortion from this shot.
Dogma
Really cool smile
Audio?
SoundPool
looking forward to some audio/video. always on the lookout for interesting wavefolders. the distortion may actually give it some unique charm, no?
guest
it took some time to deal with youtube, but here are some quick tests. all of the modulation depths are set with some knob tweaking, so nothing fancy.
this is a basic run through of transfer function, with a triangle wave being amplitude modulated, as you might use a normal wavefolder.
this is a triangle wave being offset modulated (phase modulation at the output).
this is a saw wave being offset modulated with a slow sine wave. you can see tha the output remains a steady sinewave, with only the phase being changed with the modulation.
this is a saw wave being offset modulated with a fast sine wave, which is more akin to how PM would work.
nd595
Absolutely fantastic! Any chance to see the schematics and to buy a PCB?
mike.synthesizer
Great job.
guest
once i get things finalized i will post a schematic. the circuit needs to be temperature compensated (well, should be, doesnt necessarily need to be). not sure if i will be making a product out of this or not.
cygmu
I try to avoid empty congratulations posts but that is absolutely great! So please accept my empty congratulations!
cygmu
Actually, I have a question: is this the article where you found the circuit in question?
B. Gilbert, "A monolithic microsystem for analog synthesis of trigonometric functions and their inverses," in IEEE Journal of Solid-State Circuits, vol. 17, no. 6, pp. 1179-1191, Dec. 1982.
doi: 10.1109/JSSC.1982.1051878
I might try to read it, along with your recent article.
guest
yes, thats the best paper for the topic. he also wrote one 5 years earlier which was an introduction to it called "CIRCUITS FOR THE PRECISE SYNTHESIS OF THE SINE FUNCTION". there are some tradeoffs in the design, mostly with the "bias factor" (how much overlap the differential pairs exhibit). right now im using a bias factor of around 3, which gives theoretical error of 0.2% (my circuit shows -60dB harmonics, which is similar). going to lower bias factors gives lower error, but higher temperature dependency, lower output signal, and a higher ratio between the normal signal (sine in the middle) and the overdrive signal (the saturation at the ends).
pirx
Fantastic wavefolder! Thank you for sharing this and looking forward to the schematic.
maltemark
Very nice PM-like action there. Like!
guest
so here is the current schematic:
im using +10V/-12V rails, and LM358 opamps. the transistsors are PMP4201 matched pairs. ideally all NPNs would be matched, and all PNPs would be matched, but thats not really possible like this.
guest
just did a quick temperature test. the distortion stays about the same over a pretty wide range of temperature. i hit it with the heat gun, and it stayed pretty consistent. the amplitude changed +14% with what was probably +50C temperature change, which is pretty drastic. i think it might be ok without temperature compensation, as amplitude isnt that critical.
Dcramer
Gads! I wish I could buy this! love
guest
im trying to figure out where the slight glitches at higher modulation come from, and i think its transistor mismatch. if thats the case, then there isnt a too much advantage to using matched pairs over hand matching, except for the very middle section when using it strictly as a sine wave shaper.
this then brings up the question: what would you prefer? a THMT PCB with transistor matching required, or an SMT PCB that is already populated?
i think im going to do a kit for this one, as it seems pretty useful. the circuit can be used to: 1. do low distortion sinewave shaping, 2. act as a quadruple wavefolder, 3. do PM or pseudo FM (there would need to be some leakage on the integrator to avoid slight offset voltages from saturating the modulator).
windspirit
Those transistor pairs are a bit daunting for some, I have soldered them before but they are quite picky. That being said wasn't there recently a thread talking about how difficult it is to match NPN with PNPs by hand? Is it more important to have all of the NPNs matched to the other NPNs and PNPs matched to other PNPs or is it important to have each NPN matched to the corresponding PNP?
Does changing the biasing on U2A (the op amp in a loop with the current source at the very bottom) do anything interesting? I though that it could possibly be another interesting modulation point.
SoundPool
I don't mind SMD but those transistors look a little tough for me (I do have shaky hands but normally manage to work around it). Also I have ZERO interest in matching transistors, normally I'm not bothered by temp comp so much but when I need them I'm lazy and buy matched pairs. If I don't like to do it through hole I certainly won't want to hand match those tiny things.
I think leaving it small and SMD is nice though, regardless of if that means buying pre-soldered PCB. If it had power footprints for both Euro and MOTM/Serge and a couple caps for clean/regulating power (I'm guessing thats not included on here, right?) its nice that it can be multi-format compatible, or even small enough to be squeezed into something like a stand-alone mini synth. People would still have to run a few wires and make a panel of choice, so its not like it would eliminate it being DIY.
J3RK
Wow! That sounds excellent! Probably the smoothest non-digital implementation that I've heard.
Isaiah
guest
This is fantastic!
So, the amount of folding is determined by the input amplitude, and adding a DC offset changes the symmetry, right?
A small SMT PCB (2"x2" or 2"x3"?) with 3M mounting holes and Euro/MOTM PSU footprints would be excellent.
Bonus points if you can squeeze an input VCA and mixer (for DC offsets) on there. hihi
Again, fantastic. Well done!
guest
only the NPN need to be matched to the NPN, and the PNP to the PNP. so no cross-matching required.
the bias on U2A sets the output gain, so that could be an AM point for the whole thing. im not sure how much feedthrough it has, though, or how well it goes to full-off, or effects on distortion at different levels, etc.
guest
the amount of folding is set by amplitude, but offset changes phase, and not symmetry. basically, the input voltage determines the output phase, so Vout = sin(Vin), where Vin can go from +/-720 degrees. so if you have a saw wave of fixed amplitude that spans 360 degrees, it will make a sine wave. as you add offset, it still makes a sinewave, but instead of going from -180 to +180, it could be 0 to +360, or any other 360 degree span. so at slow modulation rates, you dont notice any change as you add offset. but, as the offset modulation rate increases, you travel over the sine function faster and begin to warp the output, giving that symmetry changing look.
i was thinking about putting 2 inputs, each with a VCA, going to a mixer, and maybe having one be switchable for the pseudo-FM.
Isaiah
guest
Ah, thanks for the explanation!
Yes, two VCAs and a mixer on the input of the folder would be excellent.
Perfect as a standalone module or as VCO add-on!
Isaiah
Also, what's the ideal input voltage range?
Page 1 of 5
