SH-1oh1, TR-606, TT-303 sync question
MUFF WIGGLER Forum Index -> Tubbutec
Author SH-1oh1, TR-606, TT-303 sync question
panteltheo
Hello everybody.
Do you know if there is a way to sync tr 606 to sh 101 via cv clock and then sync the 101 to a tt303 via midi?
tubbutec
Hi,
the SH-1oh1 can sync to clock and midi. It can not however convert a
cv-clock to a midi clock as the midi clock is much faster then the
analog one.
If you want to use your TR-606 as Master, there is specialized gear to
convert its DIN-SYNC clock to a Midi Clock, such as
http://audiowerkstatt.de/de/din2midi2din
or - if you want to use a trigger instead of DIN-SYNC:
http://audiowerkstatt.de/de/trigger2midi2trigger
if the TT303 has a DIN Sync input, then you could also just connect
TR-606 --> TT303 via DIN SYNC, and use the TR606 Trigger outs to clock
the SH-1oh1
Skanker
So it's not possible for example to trigger the 1oh1 sequencer simply using the Lo Tom trigger output of a 606 directly into the 1oh1 clock in?
tubbutec wrote:
Hi,
analog one.
the SH-1oh1
tubbutec
Yes of course this is possible! Just the way you can do it with the original 101.
The above question was to generate a midi clock from that trigger signal and sync a tt303 with it - this is not possible.
