Introducing Cocteau, mod PCB for your YOCTO 808 clone
effegee
Post by effegee » Mon Apr 03, 2017 10:44 pm
24 July 2017 All kits shipped; build thread here.
2 May 2017-- 1st run closed; watch for news of Remora & Vactrol-8
30 April 2017--UPDATE:-- Information regarding other mods, Remora & Vactrol-8 added here: viewtopic.php?p=2541299#2541299
21 April 2017-- UPDATE:-- e-licktronic has opened one final run of YOCTO V1 kits. Sign up closes May 1st: http://www.e-licktronic.com/forum/viewt ... =16&t=1321
11 April 2017--UPDATE: added link to Cocteau enclosure, https://goo.gl/forms/4o8l3HfiWggQw0283
Announcing Cocteau (by Autonomik Circuits), an overlay mod PCB for the YOCTO (v1.0) analog drum machine.
Cocteau is placed over the YOCTO's front panel PCB to add 34 pots and 24 slide switches for modification of the YOCTO drum voices. Cocteau also adds duplicate RS-CL and MA circuits (RS-CL 2 & MA-2) hardwired to YOCTO's Trig-1 and Trig-2 switched jacks, allowing simultaneous sequencing of RS & CL and CP & MA (so you don't have to choose one sound at the expense of the other).
Cocteau ships as a DIY kit with PCB and hard-to-find/special-order parts (slide switches, 2M(B) pots, etc.), with a Tayda BOM for the Alpha pots and a Mouser BOM for all other parts. Build instructions will be provided.
Installation requires desoldering of some components (mostly resistors) and cutting of a few traces.
Cocteau is designed to allow the user to modify the existing circuits while allowing easy, realtime return to the original 808 sound. For example, the BD Tune pot functions only when the adjacent switch is activated; when deactivated, BD Tune returns to the original value.
Cocteau is also designed to fit within the existing panel clearance using low-profile pots, switches and connectors. A metal enclosure for the YOCTO + Cocteau will be available from Kacper Pawluk, who has already designed the front panel. A laser-cut resin panel, fabricated from his design, has been tested and fits perfectly.
Sign up for Cocteau Enclosure (1st batch) here: https://goo.gl/forms/4o8l3HfiWggQw0283
For users interested in CV control of voice parameters, there is currently in the late stages of testing a set of DIY Vactrol CV PCBs, which connect to 16 CV IN jacks (3.5 mm) on the I/O panel of the YOCTO. In addition to these 16 jacks, the Kacper Pawluk enclosure will have holes for other jacks (e.g., RS-CL 2 Audio Out, MA-2, Audio Out, White Noise IN, Accent Out, Trig-3 Out, or whatever the user decides).
Preview of some of the CV control (Soudcloud):
[soundcloud url="https://api.soundcloud.com/tracks/314966661" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/314966659" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/314966655" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/314966650" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
[soundcloud url="https://api.soundcloud.com/tracks/314966646" params="auto_play=false&hide_related=false&show_comments=true&show_user=true&show_reposts=false&visual=true" width="100%" height="450" iframe="true" /]
Finally, there will be an expansion port on the back panel of the enclosure, connected to Trig-3 of the YOCTO sequencer, for installation of swappable drum modules available for future purchase.
Cocteau list of mods:
Pots (x34):
BD Tune*
BD Envelope*
BD Xtra Decay
SD Tune 1*
SD Tune 2*
SD Filter* (Snappy)
SD Decay* (Snappy)
LT Reverb
LT/LC Decay
MT Reverb
MT/MC Decay
HT Reverb
HT/HC Decay
RS Tune 1*
RS Tune 2/CL Tune*
RS Filter
CP Reverb
CP Filter
CP Density
CB Tune 1* (OSC 1 Tune)
CB Tune 2* (OSC 2 Tune)
CB Filter
CB Decay (normal)
CB Decay (long)
OSC 1 & OSC 2 trimmers (moved from underside of YOCTO PCB)
OH Filter
CH Filter
CH Decay
Metal Tune* (OSC 1 & 2 of CB/CY/OH/CH)
4 extra pots (+ extra pads) for user custom mods
RS-CL 2 Level
MA-2 Level
(Pots with * have an adjacent slide switch to change between original value resistor/cap and mod pot, allowing user to quickly switch back to authentic 808 sound.)
Additional slide switches:
LT Reverb Off
MT Reverb Off
HT Reverb Off
CP Normal Filter <--> Low Filter (x2)
CP Density <--> CP Delay
CB Decay (Normal) <--> CB Decay (Long)
MT Decay (an extra switch needed to accompany original MT-MC slide switch)
RS 2 <--> CL 2 (x2)
+ additional switches for user custom mods
Availability: Cocteau will be ready to ship about 8 weeks after the initial run list is finalized, which is the time needed to receive the special-order parts. Sign-up list is here (Google Forms): http://bit.ly/2ocVlOq
Pricing:
The projected price is $145 USD/kit, plus shipping & handling from the U.S.
What's included:
- Cocteau front panel PCB
- (17x) high-quality 500-series SPDT switches
- (7x) make-before-break (MBB) DP3T switches
- (4x) Alpha 2M(B) pots
- 1 meter shielded stereo cable
- (1x) SK30A transistor (for RS-CL-2 circuit)
- Plastic sheet (to shield between YOCTO main PCB and Cocteau)
The Tayda BOM for the pots is around $18 USD and Mouser BOM, about $40.
Other supplies needed:
- an MTA hand tool ( http://www.mouser.com/ProductDetail/TE- ... y/59803-1/ ) and some 24 AWG wire (or you can use pre-assembled PH 2.0 connectors, though I prefer the MTA connectors for reasons that will be clear in the build instructions)
- Brand new, sharp (yes, sharp) clippers. I recommend these: Plato 170, http://amzn.to/2ovrylt
- Desoldering braid or a desoldering gun, such as a Hakko FR300-05/P (I use the discontinued Hakko 808) or ZD-915 desoldering station (shown here on a NAVA:
- a blade, such as an Xacto knife
limpmeat
Post by limpmeat » Mon Apr 03, 2017 10:49 pm
Whoa
GrantB
Post by GrantB » Mon Apr 03, 2017 10:57 pm
:yay: nice to see this project surface. I think we spoke about this at the synth meet. Congrats!
effegee
Post by effegee » Tue Apr 04, 2017 12:30 am
GrantB wrote: I think we spoke about this at the synth meet.
Ah, yes. At EMP...
NS4W
Post by NS4W » Tue Apr 04, 2017 2:13 am
Wow! Great work :sb:
(Wonder if the Yocto kits will be back in stock in order to build the whole thing together...)
Rowan
Post by Rowan » Tue Apr 04, 2017 4:24 am
Sounds absolutely fantastic.... sign me up.
ninGiaBoom
Post by ninGiaBoom » Tue Apr 04, 2017 10:44 am
PLease, consider me in as well...i love mod boards like this one :love:
ninGiaBoom
Post by ninGiaBoom » Tue Apr 04, 2017 10:45 am
PLease, consider me in as well...i love mod cards like this one :love:
SPIKE the Percussionist
Post by SPIKE the Percussionist » Tue Apr 04, 2017 3:51 pm
and now i have an interest in this noiz weapon...
more noiz!
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Constructs of Ritual Evolution
DOGGEBI
Fiddle Witch and the Demons of Doom
morgue city
Unified Space
JanneI
Post by JanneI » Wed Apr 05, 2017 2:05 am
Definately interested! Count me in! 1 pcb and 1 case, thanks!
lexxxus
Post by lexxxus » Wed Apr 05, 2017 6:01 am
1 kit and 1 case, please!
Modulus
Post by Modulus » Wed Apr 05, 2017 6:36 am
This is epic, pimp my yocto please! Please put me on the list for the kit, case/panel, and the cv expansion when it's available. Great work!
yan6
Post by yan6 » Wed Apr 05, 2017 7:24 am
Gawd, I want so bad.....does anyone have an unbuilt yocto to sell me so I can build this :sadbanana:
1 kit of everything
mOBiTh
Post by mOBiTh » Wed Apr 05, 2017 7:36 am
ah shit, this means i have to build another yocto :deadbanana:
Troubleshooter
Post by Troubleshooter » Wed Apr 05, 2017 8:04 am
Sign me in!
p.s. A new yocto with nava kind of sequencer is on its way, I hope for you this PCB will fith both yocto 1 and 2!
GryphonP3
Post by GryphonP3 » Wed Apr 05, 2017 9:05 am
Wow!!!!! INCREDIBLY useful mods!! :hail: :hail: :hail:
Troubleshooter wrote:Sign me in!
This. Will you plan on also releasing for V2? If not, the V1 might actually be a preferable piece of kit..
My cat can eat a whole watermelon ...
ThecureForSin
Post by ThecureForSin » Wed Apr 05, 2017 9:22 am
Very cool!!!! Still debating on a yocto and nava, but this is definitely helping the yocto decision :goo: :goo: :goo: :goo:
momo
Post by momo » Wed Apr 05, 2017 12:56 pm
Very interested, but I guess this is aimed more at owners with an existing v1 board, or those with a built v1 Yocto without a case (or willing to buy the new case and thus have a spare that probably nobody wants). Because as far as I know, Vincent is soon moving to v2 boards, and not doing any more v1 board runs. Does anybody know any different? Thanks and great work!!
ElSmurf
Post by ElSmurf » Wed Apr 05, 2017 3:54 pm
Glad to see this finally became a reality!
spneca
Post by spneca » Wed Apr 05, 2017 5:33 pm
Wow. This is great! I'm in for a board and metal enclosure.
DJBRUTAL
Post by DJBRUTAL » Wed Apr 05, 2017 6:18 pm
Rad! Please put me down for a pcb and enclosure.
punkdISCO
Overlay mod PCB for the YOCTO
Post by punkdISCO » Thu Apr 06, 2017 1:09 am
effegee
Hi
Wow!! Please may I order/reassure the PCB kit. I will also like the metal enclosure but I think this is not through you.
Please let me know how you require payment etc.
Fantastic mod!!!
thanks,
Paul
keninverse
Post by keninverse » Thu Apr 06, 2017 7:34 am
How are the connections made to the main PCB? Fly-wires? If so, how many fly wires do you need to wire?
Altitude909
Post by Altitude909 » Thu Apr 06, 2017 10:14 am
someone needs to talk to Kacper and see if he'll run some cases.
Level5
Post by Level5 » Thu Apr 06, 2017 10:55 am
I'm in for 1 kit, please
