a/b switch which handle line level?
Author a/b switch which handle line level?
pushthatbutton
hello again,
as the topic allready says: i need a a/b pedal or small box which can handle line level and doesnt change the sound at all or at least not to much.
it should be usable in both directions: 1 in 2 outs and 2 ins 1 out...
second function is more important. (2 ins 1 out.)
i want to use several fx with different sources in a live situation.
prefering a small box but does someone has experience with the big boss switcher (boss es-8) and line level?
seems to be very good featured but to much for now.
thanks in advance!
hairychris
I use a small Fender ABY for switching instruments.
https://www.andertons.co.uk/p/0234514000/aby-and-switchers/fender-micr o-aby-pedal-in-black
It should be OK with line as it's totally passive as long as you're using 1/4 inch jacks.
I also use a Boss Line Selector in my bass rig so that I can have a wet/dry signal path going into a single amp.
pushthatbutton
thank you!
will check the fender aby out.
i got a boss ls-2 but something seems to be broken in it.
bought it used.
it distorts way to much.
http://artproaudio.com/aby_switches/product/coolswitch/
I have good luck with the inexpensive ART products.
pushthatbutton
thanks!
will keep my eyes open for it.
PrimateSynthesis
Any passive box is going to use mechanical switching. It can't tell ins from outs, or instrument from line level.
rupect
Lehle
controlFreak
a passive switcher would suit your needs
durwin
to use as ins and outs interchangeably, absolutely - just be wary of impedance differences as they can change your tone quite easily. Active circuitry will be more reliable for that side of things.
