Stillson Hammer mk2 firmware v1.777
Digital Audio Electronics - discussion & support.
Moderators: Kent, infradead, governor blacksnake, solidox
mt3
Post by mt3 » Sat Apr 15, 2017 5:03 am
Announced on the facebooks (Apr 13). Will be out soon.
Bug Fixes
* Remote reset step 2 works correctly
* preset reload works correctly for all playing styles (moved sliders on active page no longer overwrite stored data on reload)
* CV input B behavior fixed
New Feature
* sequence step rotation
jasev
Re: Stillson Hammer mk2 firmware v1.777
Post by jasev » Sat Apr 15, 2017 10:19 am
mt3 wrote:Announced on the facebooks (Apr 13). Will be out soon.
Bug Fixes
New Feature
Cool, not updated a Hammer yet. Hope it doesn't give me any hassle, been reading up on firmware updates and it makes my brain cell go dizzy
guestt
Post by guestt » Sat Apr 15, 2017 1:58 pm
Yay :party:
Step sequence rotation is huge - I use this a lot in Patterning on the iPad, instant variation in a logical form!
Thanks for sharing :)
mt3
Post by mt3 » Sat Apr 15, 2017 9:48 pm
Baddcr wrote:Yay :party:
So Patterning is worth it? Does things others don't? I'm still squatting the fence.
sendepause
Post by sendepause » Sun Apr 16, 2017 3:31 am
:party:
guestt
Post by guestt » Sun Apr 16, 2017 4:05 am
Patterning is one of the few apps I still use on the iPad mt3
It's stunning... I have it hooked up through an Endorphin.es Shuttle Control and synced (via Link) to the Octatrack and the Modular, works a treat!!
Rotating polyrhythms and probability :banana:
mt3
Post by mt3 » Sun Apr 16, 2017 9:43 pm
Robscorch
Post by Robscorch » Mon Apr 17, 2017 11:28 am
sendepause wrote:* CV input B behavior fixed
:party:
:nana: :nana: :nana:
:party:
rustyjaw
Post by rustyjaw » Tue Apr 18, 2017 12:55 am
Oh man! Yay!
Synth Enthusiast | Abandonment Photographer
Kujo
Post by Kujo » Tue Apr 18, 2017 7:29 am
all i gotta do now is find someone who can update it for me.
I am offended.
https://soundcloud.com/kujo-project
FS(EU): Metasonix RK4 / Metasonix F-1
auxren
Post by auxren » Tue Apr 18, 2017 4:07 pm
By CV input B behavior, do they mean when you change the slider and the value on the screen snaps back to one value and doesn't actually update to the new value? If so, yeaaaaaahhhh buddddy; that's been bugging me.
:omg:
Dark Barn
Post by Dark Barn » Tue Apr 18, 2017 5:24 pm
I posted this on IME Facebook also but you might want to check for this yourselves regarding the new rotate feature:
It seems like the sliders don't rotate along with the information. So if you offset things by plus one for example, the slider adjacent to the right of the step you are trying to control now controls that step.
I’ve been searchin’ for the dolphins in the sea
The Weak in Review: Poetic_stere0
mt3
Post by mt3 » Tue Apr 18, 2017 7:06 pm
Dark Barn wrote:I posted this on IME Facebook also but you might want to check for this yourselves regarding the new rotate feature:
Hmmm, unsure if that's intentional or a bug.
:hmm:
Dark Barn
Post by Dark Barn » Tue Apr 18, 2017 8:19 pm
I hope it's a bug, because things get weird if you try to work on a rotated sequence. If the intent is as stated, to rotate random sequences to give them a proper downbeat feel. Although I can see where it also might be useful. Something I haven't tried: rotating inactive steps into the active "window," that could be cool :)
rustyjaw
Post by rustyjaw » Tue Apr 18, 2017 9:58 pm
Dark Barn wrote:I hope it's a bug, because things get weird if you try to work on a rotated sequence. If the intent is as stated, to rotate random sequences to give them a proper downbeat feel. Although I can see where it also might be useful. Something I haven't tried: rotating inactive steps into the active "window," that could be cool :)
I'm not certain this is what you are talking about, but the firmware ReadMe says the following:
"Please note that the sliders will continue to program the actual steps printed on the faceplate when moved. This parameter (and sequence length) will become CV controllable in the next update."
weirdo
Post by weirdo » Wed Apr 19, 2017 2:21 pm
Since the update to fw 1.777 my display shows wrong cv-values (all stuck on C..) when playmode is stopped and i select individual steps. The shmk2 plays it right but i want to enter exact values..the gate-values are still shown correct.
rustyjaw
Post by rustyjaw » Fri Apr 21, 2017 9:53 am
I tested the Assignable B and it works exactly as I thought it would when I first got the SH. Namely, if you assign it to pitch, turning the knob (with CV or physically) into the negative range will drop the pitch of the assigned steps.
Now I am re-evaluating my desire for a dedicated 64-step sequencer since this will let me instantly alter a sequence (technically you could do that before, but only by adding voltages, not by subtracting).
I haven't tested it with gates yet, but presumably one could shorten or remove steps from a sequence of gates with the same method.
rustyjaw
Post by rustyjaw » Fri Apr 21, 2017 11:37 am
Ok so I took a few minutes before work to test gate behavior with Assignable B and the results are somewhat puzzling. At full ccw, it will turn off gates with sliders below halfway (it seemed to work with values below 60), but it had no discernable effect on gate length. I would expect the gates above 60 to at least get shorter, but that's not what I observed. Note that the gates were going into a Double Andore MkII with the envelope set to ASR so the gate lengths would affect the envelope sustain.
Flamusic
Post by Flamusic » Tue Apr 25, 2017 11:01 am
weirdo wrote:Since the update to fw 1.777 my display shows wrong cv-values (all stuck on C..) when playmode is stopped and i select individual steps. The shmk2 plays it right but i want to enter exact values..the gate-values are still shown correct.
Same problem here.
Update works fine on MAC OSX with Pickit 3
Preset save works fine.
If the hammer is not playing and i skipr thru the steps it displays the last note where i stopped the hammer on all steps.
Also triggering the note with the Encoder triggers the same CV value no matter what the slider does.
That was much better before the update.
Any one still has Version 1.666 for a downgrade ?
mt3
Post by mt3 » Tue Apr 25, 2017 12:10 pm
Same problem here.
rustyjaw
Post by rustyjaw » Tue Apr 25, 2017 12:41 pm
OK, I'm an idiot, can someone explain what sequence rotation is supposed to do? I've enabled it a few times, but I honestly can't hear a difference.
Flamusic
Post by Flamusic » Tue Apr 25, 2017 3:26 pm
mt3 wrote:
Same problem here.
Cool, thank you...
I dont know if i should downgrade because the save feature is also cool :)
Would be nice to have booth.
Can downgrade the SH be a problem ?
Flamusic
Post by Flamusic » Tue Apr 25, 2017 3:33 pm
rustyjaw wrote:OK, I'm an idiot, can someone explain what sequence rotation is supposed to do? I've enabled it a few times, but I honestly can't hear a difference.
If you have some synced background music ( a drum beat, metronome, synth line or a song) to wich the SH is synced....
You can hear what the sequence rotation is doing.
If you hear the SH playing alone its not so easy to hear the diffrence.
But with a beat or melody wich is not changed by thetrack rotation you can hear it easy. Its cool
rustyjaw
Post by rustyjaw » Tue Apr 25, 2017 5:49 pm
If you hear the SH playing alone its not so easy to hear the difference.
It's a per-track feature, right? Not global to all tracks in a given preset...
Flamusic
Post by Flamusic » Wed Apr 26, 2017 12:50 pm
Yes, its per track
Return to “The Harvestman”
