Disting Mk4 has midi->cv, cv->midi built in!
Author Disting Mk4 has midi->cv, cv->midi built in!
albedo0point39
Ha! When I unpacked mine, I was wondering what the white 6 pin opto-isolator chip was there for Mr. Green !
Opens up a load of possibilities for midi control! Thanks Os!
https://youtu.be/b_GzyDzULms?t=48s
urmg17
Any info yet on how to hook up those MIDI Din ports?
http://www.expert-sleepers.co.uk/distingmidi.html
urmg17
Last Question... Can you post a link to a socket that connects to the 4-pin header.
There are so many you could choose, but something like this would work:
https://www.rapidonline.com/bkl-10120864-idc-cable-mounting-socket-wit h-2-x-4-pins-pitch-2-54-mm-50-8232
ob-6
ok this is awesome! so where do i go to buy a panel with DIN ports that can connect to the back of my disting MK4?
This isn't yet available. Stand by for news.
hippasus
Is there any possible modification on the mk3 or mk2 to add thos functionality?
No.
achida
..so excited ..
I have the last 6hp free over the Dmk4 are enough ???
The expander I've made is 4HP. You could just DIY a cable though and use no HP at all.
achida
Great!
I have just to wait the expander..
My Disting will arrive in a cuple of day..
I'm very interested in the disting midi feature and I have a couple of questions about it,
How many midi files can I upload to my card?
And if the expander can record the midi sequence on the storage card
or is "just" a midi cv interface
Thank you
There's no limit to the number of files.
A MIDI recorder function has not been added yet, but it's a possibility.
achida
Great Great Great applause
bougie
man this thing is so versatile. I may have to get one of those Miley Cyrus
Neal Beard
How did I miss this-?? two more 'must haves' from ES!
Thanks for flagging it up!
achida
Hello OS the disting is just arrivde at my job place.
so i neede a microSDcard but i cant understand what do you mean about this DIY cable.. any advice?
many tnx
ach.
The connection details are on http://www.expert-sleepers.co.uk/distingmidi.html
You could make a cable that goes directly from the disting breakout header to a part of MIDI sockets.
achida
thank you very much
Paranormal Patroler
So is the MIDI in/out only used in certain modes or anything that outputs pitch also outputs a MIDI notes? For example, does the Pitch-to-CV mode also outputs MIDI? Could I use the mk4 as a pitch-to-MIDI module? Would make for an interesting mode, with an addition of Pitch Bend CC message tied to work. Just an idea.
Also, a MIDI note is also output on Dual Quantizer mode, is there any chance that in the future we'll have a way to change the MIDI channel of Input/Output? That would be really handy.
The pitch tracking algorithm doesn't currently output MIDI, but it certainly could. Good suggestion.
Paranormal Patroler
In terms of UI adding MIDI channel on the available Modes is a pain, I understand that, but if you have room, how about a global mode that handles in/out channel for all modes?
