Juno-66 not working after install
Support and discussion of Tubbutec products.
Moderators: Kent, tubbutec
Modern Lover
Juno 66
Post by Modern Lover » Mon May 01, 2017 9:41 pm
I'm piggybacking on this topic because I failed to lacate the start a new topic button.
I've installed the Juno 66 and having trouble:
1) Key Transpose seems to be unresponsive
2) Half the keyboard is unresponsive
3) Waveforms don't seem to be operating
2017-05-01 19.17.09.jpg (2.22 MiB) Viewed 144 times
tubbutec
Post by tubbutec » Tue May 02, 2017 8:03 am
Hi,
this sounds like a bad install, possibly a broken trace or a short between traces.
1) Try putting back the original CPU if you can. Does it work?
2) Use a continuity tester to check all traces. Check for continuity and shorts.
3) A quick way to check if the Juno-66 is working at all is to check if it outputs midi "All notes off" after turning it on.
Return to “Tubbutec”
