Adding VC to a guitar pedal?
dkcg
Post by dkcg » Sat Oct 04, 2008 3:11 pm
I think there must be some way to add a CV offset to a guitar pedal and convert it to a module. So that it adds whatever CV voltage converted to something it can make sense of and adds that to the volume or other pots. Is there some fairly simple way? I thought about going steampunk with a steam powered robotic arm, but that doesn't seem practical to me.
Any pointers in the right direction? I don't even mind having a 9volt mounted inside with it's own power switch/pilot light.
Cat-A-Tonic
Lobsters love Muff
Post by Cat-A-Tonic » Sat Oct 04, 2008 6:05 pm
Expression pedal inputs can be used for VC.
To get the best level compatability you have to go through the attenuation + amplification game.
You could just adjust the offset of the CV before you send it to the pedal.
...like with a polarizing mixer for example.
wetterberg
Post by wetterberg » Sat Oct 04, 2008 6:39 pm
it's quite easy using vactrols. I'd google "adding vactrols to pedals" or similar
plord
Wacky for Wiard Wiggler
Post by plord » Sat Oct 04, 2008 9:49 pm
Bridechamber VC Resistor? This is a tiny vactrol PCB, which lets you turn any two-wire Pot (where the pot is acting as a resistor) into a jack and pot CV combination.
