Plague Bearer unity settings?
Gear, Suggestions and Discussion.
Moderators: Kent, infradead, computer controlled, flight
soundsubs
Post by soundsubs » Tue Jun 22, 2010 11:49 am
im wondering where the 0 or "normal" settings for a PB are?
is it ~12 o'clock on everything?
not that id ever want it "normalled"... just curious.
flight
The Plague Bearer
Re: Plague Bearer unity settings?
Post by flight » Wed Jun 23, 2010 12:49 pm
soundsubs wrote:im wondering where the 0 or "normal" settings for a PB are?
You know, that's a really good question; I don't know if it can do "normal" at all. I guess that depends on what you mean: if you mean a setting where output = input (A.K.A. "unity") then no, there is no setting. You have to remove it from the signal path if you don't want any effect. But you could consider all-knobs-at-12:00 to be a good starting position to work from, as long as the input signal isn't too strong. I usually have the input around 7:00 (just barely above the point that the signal overpowers the noise), as the PB really works best and has the widest range of effect with low-level signals. The other controls are set to whatever sounds good!
~flight
flight(at)flightofharmony(dot)com
http://www.flightofharmony.com
soundsubs
Post by soundsubs » Wed Jun 23, 2010 2:44 pm
Thanks Flight--- this is as I was expecting. Just curious really.
This is why i love the PB, you never know whats going to come out of it.
it would be rad to have a "blank template" sheet where we can us MS Paint or whatever to draw our settings.
im finding it fun to have either low input/high gain or vice versa, sounds come out really thick.
flight
The Plague Bearer
Post by flight » Wed Jun 23, 2010 3:13 pm
soundsubs wrote:Thanks Flight--- this is as I was expecting. Just curious really.
Heh, yeah, I still get lost in tweaking when testing new batches.
As for a template, they are already online in pdf format: all PB-1E templates, and the full PBBP manual, which has them on separate pages. Or you can just grab the attached bitmap. ;)
~flight
Return to “Flight of Harmony”
