disting mk4 SD card problem
Author disting mk4 SD card problem
wingcommander
I’m trying to update the firmware on my Disting Mk4. The micro card is MS Dos Fat 32. The file image.hex is in the root directory.
I stick the card in and power up with the S key pressed. Disting boots up and then, after displaying the horizontal and vertical yellow lines, goes straight to displaying “Success”. Of course after a restart I’m still on V4.
Any clues?
First post, so can't start new thread.
Does this card work for WAV playback, or the help files?
wingcommander
Not for help. "No Card" is displayed. Dodgy card? I bought it especially for this.
What card is it?
Did you format it yourself?
wingcommander
os wrote:
What card is it?
It's a SanDisk 16GB. I've reformatted it a couple times sine the problem. Using 2 different Macs
So that's "MS-DOS (FAT)" not "ExFAT"?
wingcommander
Correct
And the card is fully inserted, to the extent that it clicks into place?
wingcommander
Yes it clicks into place.
Now. And works fine.
Apologies for the bother and thanks for the help
markyzno
Hi Os,
I'm also having this issue, FAT32, hold down S knob and just get success.
Hex file in root.
Any thoughts?
What kind of card is it? Try a different one, if you have one. Also try reformatting.
markyzno
Hi OS, its a sandisk ultra 64gb card, so I cant see a problem there? Alsohave reformatted many times at FAT32, PC see's it fine.
I boot the device and it just says success....No loader or prompt.
I have also tried putting samples on and my disting wont read the samples :(
I'm not 100% certain 64GB cards will work. Is it possible to partition it into two 32GB partitions?
markyzno
I'll try that Os and then report back.
markyzno
Os youre a legend, all works and i'm now happy on 4.3. Thank you SO much
we're not worthy Guinness ftw! SlayerBadger! nanners
felipetellezost
I have a 32gb sandisk sd card on a MK running 4.13....
The "K" algorithms are weird....K7 and K8 and K6 display "Preda" and then glitch.
HALP...I've seen this error abound everywhere but cannot fix it!
PS my card is new.
I'm running Fat32
very frustrating
EDIT
They seem to work?....but what does that PREDA stand for?
EDIT EDIT
PREPARE!!!
I think this is resolved, please ignore
