New modes for the E352 Cloud Terrarium
JC14
Post by JC14 » Wed Nov 07, 2018 4:59 am
Does the E352 come with a memory card? Just wondering since mine didn't...
loorenz
Post by loorenz » Wed Nov 07, 2018 5:31 am
JC14 wrote:Does the E352 come with a memory card? Just wondering since mine didn't...
No micro SD card included with my E352 too.
mdoudoroff
Post by mdoudoroff » Wed Nov 07, 2018 6:11 am
Nope. Nor does it need one to operate.
tau_seti
Post by tau_seti » Fri Nov 16, 2018 7:21 pm
I've got the new firmware loaded and am trying to figure out how detune mode works.
I have read the manual, but still have questions.
When I go to the visual displays, I see CTS in the legend under the graphics. What are CTS?
What is the difference between x and y Parma in this mode?
mgscheue
Post by mgscheue » Sat Nov 17, 2018 9:03 am
CTS is the amount of detune, in cents. Notice how it changes continuously when you vary the x parameter in smooth mode but jumps in steps of 100 in 12-tone mode. An equal-tempered semitone is 100 cents.
X controls the amount of detune, Y the wavetable that is fixed in pitch, and Z the wavetable that's detuned relative to Y.
mdoudoroff
Post by mdoudoroff » Sat Nov 17, 2018 10:12 am
paults wrote:
paults, I think it would be nice to have those detune tables available in the pitch section of the E370 some day. Handy.
Maybe not exactly, but.....[cough]
From Facebook, yesterday:
paul: “We are 'helping' make it easier by placing standard detuning intervals into the default Chord Table.”
eric: “And allowing the X/Y inputs to drive FM so you can dial in a detune from the panel pots.”
paul: “Chord Mode + new FM Offset mapping. Will have code week after Thanksgiving”
:nana:
tau_seti
Post by tau_seti » Sun Nov 18, 2018 6:38 pm
mgscheue wrote:CTS is the amount of detune, in cents. Notice how it changes continuously when you vary the x parameter in smooth mode but jumps in steps of 100 in 12-tone mode. An equal-tempered semitone is 100 cents.
Thanks, that really helps.
dp
Loving the new detune mode!
Post by dp » Mon Nov 19, 2018 6:35 am
The main melodic line is e352 being fed two different sequences from Voltage Block
zerodivide
Re: Loving the new detune mode!
Post by zerodivide » Mon Nov 19, 2018 1:19 pm
dp wrote:The main melodic line is e352 being fed two different sequences from Voltage Block
your rack looks so similar to mine! albeit double the size heh. nice stuff. But wait how are you feeding 2 melodies to e352? Im not following
Eurtrude
Post by Eurtrude » Mon Nov 19, 2018 1:41 pm
I guess he is sending one melody to normal pitch CV and an other one to the X input in detune mode, so you can sequence the offset of osc 2 :)
dp
Post by dp » Mon Nov 19, 2018 2:59 pm
Yeah exactly one into v/octave other into x think the detune was in harmonic setting.
brandonlogic
Post by brandonlogic » Mon Nov 19, 2018 3:27 pm
I sent this to paul but thought i'd post here too.
How about adding a looping on/off option to the other current modes? Or at least morph? The sample player can be fun, but to use as a one shot envelop, it can be very hard to dial what you need. I’d like to simply be able to use waveforms from a wavetables bank as one shots. For example, these waveforms would make great envelopes, to dial them in just right in sample mode is a real pain, plus the cv position not very useful when using it this way. if you could simply turn looping mode off in morph mode, it would be a much better way, plus add the ability to smoothy morph the envelope!
would be grate for wavetables especially designed for envelope use!
denuir
Post by denuir » Mon Nov 19, 2018 3:39 pm
Figured it out after additional searching. Thanks
zerodivide
Post by zerodivide » Mon Nov 19, 2018 4:03 pm
Haven't gotten a chance to load the new firmware (need to buy an SD card heh) so I haven't really looked into the detune thing yet. I just assumed detuning was changing the cents of Osc 1 vs Osc 2. you can actually change semitones?
mgscheue
Post by mgscheue » Mon Nov 19, 2018 7:15 pm
Yep! The options are smooth (continuously variable), fourths fifths and octaves, 12-tone (semitones), and harmonic series. There’s also uni-phase, which unison—no detuning, but phase shifting, instead.
Jumbuktu
Post by Jumbuktu » Mon Nov 19, 2018 9:44 pm
Love the polyrhythms on this. Rather TDreamesque!
lionelfischer
Post by lionelfischer » Tue Nov 27, 2018 6:50 pm
brandonlogic wrote:I sent this to paul but thought i'd post here too.
this sounds like a good idea b
zerodivide
Post by zerodivide » Wed Dec 12, 2018 12:47 pm
curious what envelopes and VCAs you guys are feeding your e352s into. I've been using the 0-coast's Countour to shape the e352 into plucky sounds in dual OP FM mode but I feel I need a dedicated envelope generator now for it
catchin
Post by catchin » Wed Dec 12, 2018 1:12 pm
zerodivide wrote:curious what envelopes and VCAs you guys are feeding your e352s into. I've been using the 0-coast's Countour to shape the e352 into plucky sounds in dual OP FM mode but I feel I need a dedicated envelope generator now for it
The Rossum Electro Control Forge was installed alongside my E-352. It's an amazing way to manipulate all the sound dimensions in the Cloud Terrarium. I owned a E-340 before this, and honestly the E-352 is exactly what SynthTech was missing. They've nailed it as far as an osc is concerned.
Pighood
Post by Pighood » Wed Dec 12, 2018 10:15 pm
Just pulled the trigger on a 352 from Detroit Modular (h/t to Trent).
Do the ones being assembled/shipped at this point come with 1.3?
*phnert*
Dragonaut
Post by Dragonaut » Thu Dec 13, 2018 12:16 am
You could call him back and ask him. They might even update it for you if it isn’t already.
https://soundcloud.com/acaciabridge (IDM, Ambient, Bass, Downtempo)
www.instagram.com/dr_science_phd (synths, hikes, and views.)
Pighood
Post by Pighood » Thu Dec 13, 2018 1:09 am
I mean I pre-ordered a unit that has yet to be shipped to DM.
*phnert*
Mndscrpt
Post by Mndscrpt » Thu Dec 13, 2018 3:41 am
I recieved my optomix yesterday, both outs run into it. Sounds super organic and strong! The vca of my Borg 2 wasn't that pleasing. Classic ADDAC 802 also sound solid, not so plucky but great for longer basslines and such. :guinness:
As env i used maths so far and malekko quad Envelope. It will be replaced with zadar, really excited for this combination!
paults
mice nuts
Post by paults » Thu Dec 13, 2018 9:00 am
Yes, it will have V1.3 installed.
I will be shipping to Detroit Modular their E352s around Tuesday of next week. So, depending on THE AMAZON CLOG EFFECT, it may arrive to you a few days after Christmas.
Pighood
Post by Pighood » Thu Dec 13, 2018 11:40 am
Wheeeeee wavedoggieeeeeez :fap:
*phnert*
