New modes for the E352 Cloud Terrarium
Pighood
Post by Pighood » Thu Dec 13, 2018 11:50 am
Just curious...has anyone used the 2nd output to feed back into sync, 1v/oct or such to make the thing oink like I can do with my E-350?
*phnert*
zerodivide
Post by zerodivide » Thu Dec 13, 2018 2:13 pm
Pighood wrote:Just curious...has anyone used the 2nd output to feed back into sync, 1v/oct or such to make the thing oink like I can do with my E-350?
never thought to do this, will try it now thanks!
organon
Post by organon » Thu Dec 27, 2018 10:01 am
Is there any recommendation for alternative (i.e. smaller) knobs? I love the module but the X Parameter sitting right next to the coarse tune is kind of ruining the playability. I don't think these are the standard Alpha pots with 6mm shafts.
paults
mice nuts
Post by paults » Thu Dec 27, 2018 10:33 am
a) the pots are BI P260 series. About as far removed from $0.45 Alphas as possible.
b) they are 1/4" (6.3mm) diameter. I'm sure there are many alternatives. You will need a 1/6in Allen/hex key to remove.
starthief
Post by starthief » Thu Dec 27, 2018 12:22 pm
The Davies 1900h clones from Thonk worked well enough for me on the E352. Narrow enough to give an extra little bit of room for comfort, and they don't look bad.
(photo is from October 2017)
Keltie
Post by Keltie » Thu Dec 27, 2018 2:39 pm
Yes. It does indeed oink, like a lil pig in cute red boots.
I typically use the sine harmonics wavetable into FM, which is pretty straightforward, other times get audio rate scanning of out 1s wave, cloud params etc etc.
Gets kinda noisy quite quick, good for perc sounds. Not so much straight synth voices for me, but if you like harsh noise, maybe...
brandonlogic
Post by brandonlogic » Sat Dec 29, 2018 5:30 pm
ambient drone voice throughout this track is e352 in detune mode through magneto.
http://soundcloud.com/brandon-logic/mod ... k-12-19-18
Pighood
Post by Pighood » Sat Dec 29, 2018 8:41 pm
Mine arrived today....loading it up with 3rd party tables :fap:
Question for paults: once you've loaded a bank into one of the User spots, do you have to keep the uSD card in the module, or can it be removed?
*phnert*
mgscheue
Post by mgscheue » Sat Dec 29, 2018 8:57 pm
You can remove it.
Pighood
Post by Pighood » Sun Dec 30, 2018 12:25 am
mgscheue wrote:You can remove it.
So the 352 has sufficient on-board memory to hold 8 banks at a time?
There are 127 banks in that patch sharing repository....it would be nice to see the name of the actual file rather than A-H.
*phnert*
mdoudoroff
Post by mdoudoroff » Sun Dec 30, 2018 9:28 am
Yes!
Pighood
Post by Pighood » Sun Dec 30, 2018 9:47 am
Perhaps in the next firmware upgrade, this can be increased.....
*makes paults sammich of his choosing*
*phnert*
organon
Post by organon » Sun Dec 30, 2018 10:29 am
@paults @startthief
Thanks for the suggestions about the knobs! The Davies really don't look too bad on it.
Also the potentiometers that are used here are an impressing investment in quality and longevity that a lot of manufacturers wouldn't be willing to make. That's pretty cool.
facts are the new opium for the people
dhoinjo
Post by dhoinjo » Fri Jan 25, 2019 5:30 am
Not sure if this is the right thread to ask but would it be somehow possible to have the E352 produce a square wave that goes up to 32kHz?
I am looking at buying a Z3000 to clock the processor of my ZDSP because I need an oscillator with a square wave that goes up to 32kHz to take the clock back to the original speed.
If I can do that with the E352, I don't need to buy the Z3000.
starthief
Post by starthief » Fri Jan 25, 2019 8:06 am
dhoinjo wrote:Not sure if this is the right thread to ask but would it be somehow possible to have the E352 produce a square wave that goes up to 32kHz?
Sure. Create a custom wavetable that has 4 cycles in a single table entry, and play it at 8kHz. Sines would probably do okay for a clock, so you could create that by raising a single slider in WaveEdit.
(Disclaimer: I don't recall the max sample rate and haven't actually tried this...)
dhoinjo
Post by dhoinjo » Fri Jan 25, 2019 8:39 am
starthief wrote: (Disclaimer: I don't recall the max sample rate and haven't actually tried this...)
Not too familiar with technical stuff like this and I lack the tools to measure this properly. My spectrum analyser goes only to 15kHz. Basically I don't really know what I'm doing.
starthief
Post by starthief » Fri Jan 25, 2019 8:58 am
Yeah, most tools like that will only cover the audible spectrum.
I'd say, go ahead and try the trick, and if it works it works :)
dhoinjo
Post by dhoinjo » Fri Jan 25, 2019 9:06 am
my idea exactly :tu:
shanebroderick
Post by shanebroderick » Fri Feb 01, 2019 5:39 pm
I just want to give a shout out to Paul / Synthesis Technology for having the best customer support that I have ever experienced.
jfprimeau
Post by jfprimeau » Sat Feb 09, 2019 12:21 pm
Anyone has sound examples of the new fixed detuning tables feature from the latest firmware? I'm curious as to how the 3rds/4ths/5ths/octaves/etc sound like, and what kind of sequenced "chord progressions" are possible.
brandonlogic
Post by brandonlogic » Sat Feb 09, 2019 1:55 pm
jfprimeau wrote:Anyone has sound examples of the new fixed detuning tables feature from the latest firmware? I'm curious as to how the 3rds/4ths/5ths/octaves/etc sound like, and what kind of sequenced "chord progressions" are possible.
Did u see the demo I posted a few pages back?
Here:
brandonlogic wrote:Two different sequences. One going into the v/oct, the other in the detune. Resulting in a transposition. really nice, very musically useful feature. going through the different internal detune quantization modes here.
jfprimeau
Post by jfprimeau » Sat Feb 09, 2019 7:11 pm
Here:
I hadnt. Sounds great, very convincing example! Thanks!
Szczepan
Post by Szczepan » Tue Apr 09, 2019 11:29 am
Hi there!
Could you please tell whats the lowest frequency which you can get from E352 Cloud Terrarium?
It's about sub bass frequencies
I can't find it anywhere.
I'm wondering whats the differnece between analogue VCO's sub base parts and this wavestables except warmth?!
Thx!
starthief
Post by starthief » Tue Apr 09, 2019 12:12 pm
Szczepan wrote:Hi there!
I can't find it anywhere.!
It goes down to very slow LFO rates, and unless I'm remembering wrong it can even stop completely. I do have a screenshot where it's at 79.2 seconds per cycle (0.0126 Hz) :lol:
Szczepan wrote:I'm wondering whats the differnece between analogue VCO's sub base parts and this wavestables except warmth?!
Thx!
Oh boy. :deadbanana:
dooj88
Post by dooj88 » Tue Apr 09, 2019 1:20 pm
Thx!
cmon man, that's what all these cats are for
