ES-8 ADAT input problem
Author ES-8 ADAT input problem
___tomk
Could use another brain on this one: ES-8 paired w ES-6, both Logic and Max recognize input from inputs 1-4 (the ES-8 inputs), but not 5-10 (ES-6 inputs). This has not been an issue until now, randomly. Any ideas?
ES-6 still on (lighting up)? Connected by both ribbon cable and TOSlink cable? Both cables not fallen out?
___tomk
Yes, all of the connections are in place, and all input jacks illuminate as expected
When you say the apps don't recognise the inputs, do you mean the ES-8 only appears to have 4 inputs, or that it has 12 inputs but there's no signal on 5-12?
___tomk
Audio MIDI Setup shows ES-8 as inputs 1-12, signal appears in DAWs on 1-4 only. I/O mapping in Max is correct.
I guess it's a possibility that either the ES-6 or the ADAT input on the ES-8 has died. Do you have any other ADAT gear to test with?
___tomk
Ok - signal passes as expected through all ES-6 inputs when plugged into the optical in on my digi003 rack (thanks for your suggestion, I forgot to eliminate the ES-8 from the equation before posting here) - there was some clicking which was remedied by changing the clock source to ADAT in Audio MIDI Setup.
Once I verified the ES-6 was operational, I switched back to running it w the ES-8, no audio.
OK - did you try the digi003 ADAT out into the ES-8 ADAT in?
In that setup, you should be able to use Audio MIDI Setup to put the ES-8 in ADAT clock mode.
___tomk
With Digi003 optical out > ES-8 ADAT in, no audio on inputs 5 and above. Tried switching ES-8 clock source in Audio MIDI Setup from ES-8 Internal to ADAT, and the selection auto-returns to Internal. Interestingly, trying to switch the clock source changed the pitch/overall state of my modular (overall pitch dropped by about a m3, other parameters were affected).
Overall connection between Digi003 and ES-8 also became unstable (switching programs on my Mac and other seemingly random actions would randomly cause audio connection to drop/have an affect on voltages in the modular).
Avid drivers up to date, connected via thunderbolt/firewire adapter, straight into the Mac, ES-8 also connected straight into the mac. Running on 2013 MBP OS X 10.11.6.
This made me think the Avid software might have something to do with it, so I uninstalled and restarted to check the function of the ES-6/ES-8 combo, still no audio on inputs 5 and above.
Sounds very much like the ES-8 ADAT input isn't working.
Last test - plug an ADAT cable from ES-8 ADAT output to ES-8 ADAT input. See if anything goes out and back.
___tomk
Signal passes successfully (lights up) between all inputs and outputs on the ES-8, with and without the ADAT self-connection
I mean send out through the ADAT channels and look for a signal on the ADAT inputs.
___tomk
Edited for clarity, hope I'm interpreting your instructions correctly.
When the ES-8 ADAT in and out are connected to each other, I see signal (offset, yeah?) from inputs 1-4 on all ES-8 output channels, but no signal passing from inputs 5-12.
OK. Unless you can think of anything to try reconfiguring in software (or try another computer?), it looks like a repair is indicated.
Email me.
___tomk
Replied via email. For thread purposes - verified same errors occurred while using Reaper on a different Mac.
Vapor
I just got an ES-8 and am having difficulty connecting adat to my focusrite scarlett (or more likely getting the in/outs connected right on focusrite software. My immediate goal is to use the 1/4" inch outs of my focusrite going to my monitors while claiming the ES-8 as my interface on Ableton Live. Need help.
Please don't double-post.
https://www.muffwiggler.com/forum/viewtopic.php?t=200659
